http://www.sohcahtoa.net/videos/amazinggrace.m1v
This roller coaster is called Amazing Grace. It was designed by RiscIt,
one of the admins of CoasterSims.com. The actual track looks FAR better
in No Limits, because he uses terrain and 3DS objects, both of which I
have not implemented yet. Also, the lack of supports kind of takes a
bit away from the feel of the ride.
That said, this represents the fact that I've fixed my banking problem
in that corkscrews and loops work (See my post on p.general), though
loops with little lateral movement will show a glitch, which shows
itself in one of the loops in this ride.
I need to change the method of interpolation though...through the
corkscrews, the ride kind of wobbles because the interpolation is
linear. I know that No Limits uses some sort of bezier interpolation,
but I'm not sure how exactly to implement it for banking. I might
settle for 3rd order b-spline interpolation. While it may end up being
very smooth, it won't be as accurate to the original track.
-DJ
Subject: Re: Roller Coaster WIP 6 (MPEG1 Link: 4.7 MB)
Date: 1 May 2006 16:57:39
Message: <44567643@news.povray.org>
Simply amazing... There's something to be said for framerates, and
having a constant one :) My computer is, unfortunately, old enough that
the coaster sims struggle a lot. I also like the shadows. Overall, it
gave me a much more favorable impression than RCT does. Good job!
...Chambers
> ...Chambers
Currently re-rendering it using 600 fps...the plan is to turn it into 60
fps with 10-sample motion blur. Its gonna look SMOOOOOOOOTH.
Meanwhile, I'll be working on getting supports going.
-DJ
> -DJ
I've cancelled this render. Its going to take too long. I'd rather
save that kind of render for when I get terrain and supports done, that
way it looks perfect.
-DJ
If you require any rendering done I have a lot of CPU time I could
spare. Also I get to see how you are working things ;)
Let me know.
Dave.
DJ Wiza wrote:
>> 60 fps with 10-sample motion blur. Its gonna look SMOOOOOOOOTH.
>> -DJ
> -DJ
Man! This track is insane! 8-O
If anybody will ever build this please let me know :D
I'm glad you could fix the corkscrew problem and i hope you'll get this loop
thingy fixed as well!
Would it be a problem to provide another Divx version of that one like you
did the last times? it just looks much better that way.
If you need a few extra frames to be rendered (or webspace for divx versions
;)) i could help you with that as well. Just let me know.
Waiting for more to come!
Regards Roman
> -DJ
Got any barf bags? That was kind of fun.
As a note, you have a kink in your track, ascending the loop at about the
38sec mark.
-tgq
>>-DJ
> 38sec mark.
> -tgq
I know about the kink, that's why I noted above that vertical loops with
very little lateral movement will show a glitch.
The problem is with vertical track. If a track is exactly 90 degrees
down, how do you know which way is up? To make an up vector, I use
VPerp_To_Plane to find a vector that is perpendicular to a plane defined
by a vector that points "foward" along the track and the vector y. This
creates a vector pointing right. I then use vaxis_rotate to rotate that
by the amount of banking defined by the track.
Of course, this creates the problem that as track gets closer and closer
to going 90 degrees either straight up or down, you get rounding errors
that result in those kinks.
The author of No Limits found a way around it by allowing the user to
specify that a banking angle is "relative" to the previous control
points banking. Not sure how I could implement that though. I might
have to do a lot of reworking.
-DJ
Date: 2 May 2006 14:38:47
Message: <4457a737@news.povray.org>
> Let me know.
> Dave.
Test renders are quick. Because I'm using spheres/cylinders rather than
sphere_sweeps, it only takes about 6 seconds per frame, and most of my
test renders are just single frames to make sure something is being
calculated correctly.
-DJ
Date: 2 May 2006 15:42:22
Message: <4457b61e@news.povray.org>
I've once written a small script to create a mesh-tube running along a
spline, and ran into similiar problems. What was suggested to me then by
Rune and someone else who's name I've forgotten (sorry) to update the
up-vector successively, instead of independantly for each frame (in my case,
for every ring of the tube, in your case, it's the frames).
I start with the initial direction I'm heading to, and an initial up vector.
On the next frame, use the old up-vector, and double vcross it with the new
direction to get the new up-vector.
#local Up = vnormalize(vcross(vcross(New_Direction,Last_Up),
New_Direction));
Since the new direction and the old up-vector aren't perpendicular, you'll
create a new up-vector that is aligned along the plane defined by the old
up-vector and new-direction... Quite simple, once you think it through.
Additionally, since this only affects corkscrew or other loopings, you could
create a parsing step that'll just do that when it's needed. Needs a little
more though, but would be worthwhile in case you plan on distributing the
render and making the animation independant of former frames.
Tim
aka "Tim Nikias"
> New_Direction));
> Regards,
> Tim
Hmm...If I understand you correctly, then what I'd be doing is starting
with an up vector of simply y, double cross it with the new direction
with each frame, and pass it to the next frame (Just like I pass the
current location and speed with each frame). On every frame, I'll do
all my banking calculations based on that vector, rather than using y
every time.
Correct?
-DJ
Date: 3 May 2006 02:20:14
Message: <44584b9e@news.povray.org>
Ok no problem. If things get a little more drawn out with your intended
landscape and 3DS objects my offer still stands. That is if you can
split the animation down into sections?
Keep the animations coming
Dave
>> Let me know.
>> Dave.
> -DJ
Date: 3 May 2006 03:42:01
Message: <44585ec9@news.povray.org>
> every time.
> Correct?
Yup.
Tim
aka "Tim Nikias"
> Dave
You can and you can't split the animation.
At every frame, it tries to read two variables from a text file. These
two variables tell my script the current location and speed. If it
can't find this file, it starts from the beginning.
So by creating this file yourself, you can make it start somewhere in
the middle.
-DJ
> the middle.
> -DJ
So you have to run the simulation up to the point in the track you wish
to render from so it has the correct location and speed. That makes sense.
Patiently waiting for next render ;)
Dave.
>> These two variables tell my script the current location and speed. If
>> it can't find this file, it starts from the beginning.
>> the middle.
>> -DJ
> Dave.
Its going to be awhile. I've gotten the banking to be smoother by using
a spline for up vectors, which fixed the kink in the track, but I
haven't implemented the double-crossing of the up vectors to make
vertical track work right, so really its just luck that the track
appears and banks correctly. A track tie still appears wrong, showing
that it still isn't right, it just looks right in most cases.
I've also fixed the spine rail. It no longer goes up and down, causing
track ties to appear in the bottom of the spine. This was being caused
by rotating the vector y over the vector of the direction of travel, so
track that had a slope caused the spine to be closer to the bezier
defining the track.
In any case, I don't really think its enough change to warrant a new
upload. I thought of making a 60 fps 10-sample motion blur render, but
that would take almost 4 days, and I'd rather have the CPU time devoted
to test renders of the support track, which I haven't even begun working on.
-DJ
