POV-Ray : Newsgroups : povray.binaries.animations : Roller coaster WIP (DivX 6) Server Time
1 Nov 2026 00:17:25 EDT (-0400)
  Roller coaster WIP (DivX 6) (Message 1 to 9 of 9)
Subject: Roller coaster WIP (DivX 6)
Date: 15 Apr 2006 17:21:55
Message: <444163f3@news.povray.org>
There's a roller coaster simulator program named No Limits
(http://www.nolimitscoaster.de - don't be scared by the .de, the site is
in English) that uses beziers for creating roller coasters.  I'm
currently working on a program that will convert a track made by it into
a POV-Ray scene, complete with animation.
This is a test using a very simple "track".  I haven't actually written
the program, but I'm creating it in such a way that POV-Ray itself is
actually generating the coordinates of the spheres using SDL, as well as
calculating all the physics.  By changing just some array declarations
at the beginning that define the beziers that define the track, you can
change the track and POV-Ray renders and animates.
The idea is that all my program will do is read the No Limits track file
  and convert some binary data into some #declares and then add on a
standard SDL code to put it all together into a scene.
-DJ
Download 'bezier.avi.dat' (377 KB)
Subject: Re: Roller coaster WIP (DivX 6)
Date: 15 Apr 2006 18:22:57
Message: <44417241$1@news.povray.org>
I couldn't see it
Date: 15 Apr 2006 18:31:56
Message: <4441745c$1@news.povray.org>
Zeger Knaepen wrote:
> I couldn't see it
Do you have DivX 6?  That's what its encoded in.  I used VirtualDub to
take the image sequence and turn it into an AVI, and I used the DivX 6
codec.
-DJ
Date: 15 Apr 2006 20:32:21
Message: <44419095$1@news.povray.org>
> Do you have DivX 6?
nope, I stopped at the last good version of DivX, which is 4.something, then I
switched to XviD
I can open your animation, but I can't see anything but some weird colored
blocks :)
> That's what its encoded in.  I used VirtualDub to take the image sequence and
> turn it into an AVI, and I used the DivX 6 codec.
that DivX6-thing might not be such a good idea, most people here appreciate it
more if it's encoded in standard MPEG-1
cu!
Subject: Re: Roller coaster WIP (MPEG1 version)
Date: 16 Apr 2006 01:47:15
Message: <4441da63@news.povray.org>
Here's an MPEG1 version.  I cringed as I made it.  MPEG1 is so
dated...why do people still use it when MPEG4 gives so much better results?
-DJ
> -DJ
Download 'bezier.m1v.mpg' (374 KB)
Date: 17 Apr 2006 08:32:54
Message: <44438af6@news.povray.org>
"DJ Wiza" <Kil### [at] sohcahtoanet> wrote in message
news:4441da63@news.povray.org...
results?
a lot of reasons: MPEG1-codecs (or at least, the decoders) are included
with every major OS, so everybody can see it, MPEG4 needs a faster
computer, which not everyone has, and there appear to be a lot of
sub-standards for MPEG4, so even if you have *an* MPEG4-decoder, you
might not be able to see it.
It's more or less the same with MP3.  There are better alternatives than
MP3, OGG Vorbis for instance, but everybody can play MP3 without hassle,
which is not the case for OGG Vorbis, so MP3's what you should use if
you want people to hear your music :(
To comment on the animation: looks good (except for the MPEG-artifacts
of course :)) !  Is it just going to be spheres, or are you planning on
making it a real (customizable) rollercoaster-object?  That'd be cool :)
cu!
Date: 17 Apr 2006 18:39:37
Message: <44441929$1@news.povray.org>
> a lot of reasons: MPEG1-codecs (or at least, the decoders) are included with every
major OS, so everybody can see it, MPEG4 needs a faster computer, which not everyone
has, and there appear to be a lot of sub-standards for MPEG4, so even if you have *an*
MPEG4-decoder, you might not be able to see it.
Yeah...I thought about that...there are so many MPEG4 codecs out there.
  MS has one, plus there's DivX, XviD, and I'm sure many others.  I
think I'll start attaching MPEG1 files with a link to a DivX file.  Or
do you think I should do it the other way around?  Or perhaps upload both?
> It's more or less the same with MP3.  There are better alternatives than MP3, OGG
Vorbis for instance, but everybody can play MP3 without hassle, which is not the case
for OGG Vorbis, so MP3's what you should use if you want people to hear your music :(
I don't use OGG Vorbis for that reason, pretty much.  I don't think Nero
supports OGG when I want to create an audio CD, and converting to WAV
manually is a pain.
> To comment on the animation: looks good (except for the MPEG-artifacts of course :))
!  Is it just going to be spheres, or are you planning on making it a real
> cu!
I'm currently in the process of rendering a new version with an actual
track, complete with 2 running rails, a center spine, and track ties.
It looks similar to a style Schwarzkopf used in his roller coasters.
Eventually, I'll have all the track designs that No Limits supports.
Although some, like the Intamin and B&M track styles, will require some
extra coding.  B&M has a boxy design for their track, and Intamin's
track ties actually connect forward in their design.
This picture shows the Schwarzkopf style I'm creating:
http://www.rcdb.com/ig2264.htm?picture=38
(Except my implementation doesn't have those small bars between the ties)
This is a typical B&M design:
http://www.rcdb.com/ig2528.htm?picture=45
Note the faceted spine shape.
And here's Intamin's design:
http://www.rcdb.com/ig594.htm?picture=9
Of course, there are many other designers, but they'll be easy to
implement.  They just need different diameters/offsets for the rails and
a different meshes for the ties.
For example, Arrow Dynamics:
http://www.rcdb.com/ig25.htm?picture=17
Premier:
http://www.rcdb.com/ig593.htm?picture=22
And more...
To see how all these designs look in No Limits, go to the screen shots
section at http://www.nolimitscoaster.de/
(Of course, Ole Lange, the author of No Limits, doesn't use the company
names, probably due to copyrights, with the except of Gerstlauer, who
he's actually been working with to create their train/track designs.)
-DJ
Date: 17 Apr 2006 19:48:12
Message: <4444293c@news.povray.org>
news:44441929$1@news.povray.org...
there.
both?
I think you should post MPEG1 files here, and post a link to an
XviD-file :p  But if DivX is your thing, then by all means, go for DivX
wouldn't post them both here though.
Nero
> manually is a pain.
hmm, you know, I listened to an audio CD this weekend, only one track,
and it suddenly hit me: I hadn't listened to a real audio CD for about 5
years :)
some
amazing, I'm looking forward to your next animations :)
ties)
that one's high!! :)
and
> Premier:
> And more...
company
really interesting stuff, didn't know there were so many kinds of tracks
cu!
Date: 17 Apr 2006 20:12:08
Message: <44442ed8$1@news.povray.org>
> I think you should post MPEG1 files here, and post a link to an XviD-file :p  But if
DivX is your thing, then by all means, go for DivX :)
In terms of Xvid vs DivX, from what I can see, they're about equal in
terms of quality.  I only use DivX because I already have it and it can
decode Xvid.  I don't have an Xvid encoder.
> hmm, you know, I listened to an audio CD this weekend, only one track, and it
suddenly hit me: I hadn't listened to a real audio CD for about 5 years :)
I don't have an MP3 CD player, or any other MP3 player for that matter,
except for my computer.
As I said in my other message, I'm rendering a version with an actual
track, though I'm thinking I should have done it without AA since its
still only a "test" render.  3 1/2 hours of rendering and its only on
frame 201 out of 400.
Not really...its only 310 feet tall.  I rode it 56 times in 2002.  The
drop is still fun, but it has completely lost the amazement factor.
If you want a doozy, check out Kingda Ka at Six Flags Great Adventure in
New Jersey.  Its 456 feet tall.  It doesn't have a lift hill, but rather
uses a hydraulic launching system to accelerate you from 0-128 mph in
3.8 seconds.
tracks :)
In case you couldn't already tell, I'm a roller coaster fanatic.  I've
ridden over 100 roller coasters and have been to about 20 parks.  While
that may seem like a lot, it really isn't.  I've met people at events
that have ridden over 500 coasters, been to 50+ parks, and have even
gone to other countries just to go to the theme parks.
Enjoy your ride.
-DJ
