POV-Ray : Newsgroups : povray.binaries.animations : isohedral dodecahedron Server Time
12 Oct 2025 10:39:23 EDT (-0400)
  isohedral dodecahedron (Message 1 to 3 of 3)
Subject: isohedral dodecahedron
Date: 10 Jun 2005 10:17:20
Message: <42a9a0f0@news.povray.org>
A simple animation of an interesting object:
the polyhedron has 12 congruent irregular pentagons
for faces.  The only lighting is from inside the object.
There is slight transparency.
I'm pretty new to all this so I have one question:
the animation is intended to loop.  But there is (in
all viewers I have tried) a slight hesitation when it
passes start.  I have the +KC parameter on the POV
render line, but it still has this problem. Is there
a way to avoid this?  Is there a viewer that runs it
smoothly?
Jim Buddenhagen
http://home.earthlink.net/~jbuddenh/
Download 'iso_dodec.m1v.mpg' (354 KB)
Subject: Re: isohedral dodecahedron
Date: 10 Jun 2005 12:49:14
Message: <m2hja1tugbqfbtepqcngg5uo6ge34gl6sr@4ax.com>
On Fri, 10 Jun 2005 09:24:18 -0500, "James Buddenhagen"
>smoothly?
Nice animation. It loops fine for me on windows media player.
Regards
Date: 13 Jun 2005 10:45:01
Message: <web.42ad9bb3792d141f9bddaa230@news.povray.org>
> smoothly?
> Jim Buddenhagen
You may want to check to see if the first frame and the last frame are the
same rendering.  Try building your animation w/out the last frame and see
if it still skips.
--Eric
