Some time a go, I posted some anims of my RealFlow experiments (RealFlow is a
stand-alone
program from Next Limit www.nextlimit.com that simulates fluids and gases, amongst
other
things). I modified and imported the RealFlow output into POV.
I decided to dust off this technique, so here are a couple of new animations, hosted
elsewhere
due to file size:
http://www.lunarland.fsnet.co.uk/3D/RealFlow2POV-WaterBox.mpg
http://www.lunarland.fsnet.co.uk/3D/RealFlow2POV-WaterBox_A.mpg
They are 1.3 Mb and 2 Mb respectively.
What do you think?
All the best,
Andy Cocker
Andy Cocker wrote:
> Hi,
stand-alone
other
elsewhere
> due to file size:
> What do you think?
> All the best,
> Andy Cocker
Wow nice!
> Wow nice!
Can't agree more. Now if only RealFlow were not that expensive and we had
some easy means to convert POV-Ray-scenes into something RealFlow could
use...
"Tim Nikias v2.0"
if...if...if...
I prefer writing my own code or using an open source solution for this kind
of stuff....... *if* I find the time to put any effort into it!
The above quote is the crucial part: how often does one have time (and
skill) to write a fully fledged particle-based fluid-simulation which works
near-flawlessly? But doing things yourself is the most rewarding, I agree
with you there.
"Tim Nikias v2.0"
"Thomas Lake" <smi### [at] hotmail com> wrote in message
news:41d1ac4e$1@news.povray.org...
> Wow nice!
Thanks.
Andy Cocker
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> wrote in message
news:41d20d00$1@news.povray.org...
> > Wow nice!
> use...
Absolutely. Just converting the ASCII text files that RealFlow outputs to a form that
my macro
reads can sometimes take all night. It's all a real pain, and is unusable for real
scenes.
Andy Cocker
"Eli" <eli### [at] jehoel net> wrote in message news:41d33be3@news.povray.org...
> if...if...if...
So would I if (a) I were able to code it, or (b) there was one available.
Andy Cocker
news:41d33ce4@news.povray.org...
> with you there.
Yes, I agree about the rewarding aspect, and you've said it before on more than one
occasion
that you like to code everything yourself in SDL. I would do that too, were I able.
Andy Cocker
that my macro
scenes.
Are you doing it by hand? I don't know what the RealFlow output looks
like, but usually Perl is a very powerful tool to solve such conversion
problems.
Cool animation, BTW. I'm not sure if I like it that the two fluids don't
really mix up, I guess my mind thinks that there should be some gradient
between the two fluids once they've touched. Is RealFlow able to do that?
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
