![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
So, this is a test for an animation. What I want is the heathaze effect you
can see in the distance on hot days. I'm not quiet sure if the effect is a
little too much and too jittery, if anyone has got a link to a RL example
I'd be happy. :-)
Anyways, the technique is simple: I just place a sphere directly on the
location of the camera and apply some normals which are translated to start
at ground-level and fade out to nothing when raising. Since the rays will
only get refracted on angular surfaces, the perturbation only takes place
where the rays hit on a normal, otherwise they just pass through the sphere.
Comments, suggestions?
Tim
"Tim Nikias v2.0"
Download 'haze_test.mpg' (77 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That looks great Tim!
=Bob=
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks! I'm not quiet sure if the effect will make it into the IRTC entry,
as it would require a near-ground view. But we'll see. I first needed a
working version before I can consider putting such effects into the
animation, and now that I know that it works, I have a choice.
Tim
"Tim Nikias v2.0"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It sure looks like the heated air over a camp fire. Heathaze in the distance
I'm not sure I've ever seen in real life, so I don't know about that.
Rune
rune|vision: http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
distance
Thanks! At least its recognizable, so I can be sure to be on the right
track. :-)
"Tim Nikias v2.0"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Looks good, but isn't it easier and probably faster to use a normal in your
camera?
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x) // ZK http://www.povplace.be.tf
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Zeger Knaepen" <zeg### [at] student kuleuven ac be> wrote in message
news:414b6b22@news.povray.org...
> camera?
never mind that, I didn't see the object isn't affected :)
cu!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
