POV-Ray : Newsgroups : povray.binaries.animations : Heathaze (76kb) Server Time
22 Jan 2025 23:57:56 EST (-0500)
  Heathaze (76kb) (Message 1 to 7 of 7)
Subject: Heathaze (76kb)
Date: 16 Sep 2004 08:36:18
Message: <414988c2@news.povray.org>
So, this is a test for an animation. What I want is the heathaze effect you
can see in the distance on hot days. I'm not quiet sure if the effect is a
little too much and too jittery, if anyone has got a link to a RL example
I'd be happy. :-)
Anyways, the technique is simple: I just place a sphere directly on the
location of the camera and apply some normals which are translated to start
at ground-level and fade out to nothing when raising. Since the rays will
only get refracted on angular surfaces, the perturbation only takes place
where the rays hit on a normal, otherwise they just pass through the sphere.
Comments, suggestions?
Tim
"Tim Nikias v2.0"
Download 'haze_test.mpg' (77 KB)
Subject: Re: Heathaze (76kb)
Date: 16 Sep 2004 09:10:45
Message: <414990d5@news.povray.org>
That looks great Tim!
=Bob=
Date: 16 Sep 2004 09:57:37
Message: <41499bd1$1@news.povray.org>
Thanks! I'm not quiet sure if the effect will make it into the IRTC entry,
as it would require a near-ground view. But we'll see. I first needed a
working version before I can consider putting such effects into the
animation, and now that I know that it works, I have a choice.
Tim
"Tim Nikias v2.0"
Date: 16 Sep 2004 17:09:46
Message: <414a011a$1@news.povray.org>
It sure looks like the heated air over a camp fire. Heathaze in the distance
I'm not sure I've ever seen in real life, so I don't know about that.
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 16 Sep 2004 17:48:37
Message: <414a0a35@news.povray.org>
distance
Thanks! At least its recognizable, so I can be sure to be on the right
track. :-)
"Tim Nikias v2.0"
Date: 17 Sep 2004 18:54:26
Message: <414b6b22@news.povray.org>
Looks good, but isn't it easier and probably faster to use a normal in your
camera?
cu!
Date: 17 Sep 2004 18:56:40
Message: <414b6ba8@news.povray.org>
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:414b6b22@news.povray.org...
> camera?
never mind that, I didn't see the object isn't affected :)
cu!
