Sources in pbsf.
I also desribed there how it was done and also
some discussion.
Andrel
Download 'atalanta.mpg' (485 KB)
You have to light sources in it, one of them should not have shadows.
Mit freundlichen Grüßen
Bernd Michler
"andrel" <a_l### [at] hotmail com> schrieb im Newsbeitrag
news:402### [at] hotmail com...
> Sources in pbsf.
> some discussion.
> Andrel
Sure, if I wanted to do a realistic outdoor scene.
In this case I did not :).
I wanted my source to be as simple as possible
and only show the use of my macro to animate
this butterfly.
Hmm, in retrospect, I think I should have used
one light and ambient lighting. That would have
been even more basic. Thanks for pointing out.
Andrel
Next you should try making a looping animation with some acceleration and
deceleration near the end points.
#macro animSin(C) sin(2*pi*C)
#macro animSin01(C) (animSin(C-0.25)+1)/2
I assume you have some place in your code that does:
rotate <0, 0, 90*clock>
try:
rotate <0, 0, 90*animSin01(clock)>
oh, and double your frame count, if you do this.
AW
"andrel" <a_l### [at] hotmail com> wrote in message
> Sources in pbsf.
> some discussion.
> Andrel
That is an interesting way to make a cosine ;)
No, I have not (see source in pbs-f)
I am afraid it was a lot more work than that.
> try:
No:
Atalanta(animSin01(clock))
It looks reasonable. I am sure the wings do not
move like a sinusoid, but my brain does not
object to this movement as unrealistic.
I probably would have tried something more
complicated then a pure sinusoid myself, so
thanks for preventing another level of complexity.
No to make it even remotely behaving like a butterfly
I have increase the framerate and then at 32 frames
30 frames per second it still is in slow motion.
Thanks for your comment.
Andrel
