POV-Ray : Newsgroups : povray.binaries.animations : Re: Flight over PCB SE Server Time
13 Oct 2025 00:13:59 EDT (-0400)
  Re: Flight over PCB SE (Message 1 to 8 of 8)
Subject: Re: Flight over PCB SE
Date: 15 Jan 2004 19:18:54
Message: <40072dee@news.povray.org>
> if THS posts a flight over a PCB I post one too :-)
> See also the image in p.b.i wich shows the whole PCB and the camera path.
> Originaly 1000 frames at 800x600 (took about 16h to render)
> Now 500 frames at 320x240.
OMG this is so good!
It looks like an advert for a chip company or something.
Version: 6.0.561 / Virus Database: 353 - Release Date: 13/01/04
Date: 16 Jan 2004 05:47:51
Message: <4007c157$1@news.povray.org>
Really impressive, the best flight over PCB till now!
Now the question is if it can be "topped" by THS or if that was the end
--Theo
Distributed Network-Rendering or Local SMP-Rendering. With SMPOV and
POV-Ray 3.5. * Download free at: http://www.it-berater.org/smpov.htm
Date: 16 Jan 2004 07:45:02
Message: <web.4007dc02b07a0e0a7ad5432e0@news.povray.org>
=?ISO-8859-1?Q?Matthias_Wei=DFer?= wrote:
very cool indeed, but maybe you could turn on banking in the fly through....
Date: 16 Jan 2004 08:50:55
Message: <4007ec3f$1@news.povray.org>
Hi Matthias,
very nice, I like it too !
But it is not the end ;o))
regards
Thomas (THS)
www.th-schwarz.de
news:400705ca@news.povray.org...
> Hi
> mat### [at] matweide
> http://www.matwei.de
Date: 16 Jan 2004 09:18:09
Message: <4007f2a1@news.povray.org>
Hi
for those of you with high bandwidth internet access here is a high
resolution file available
http://www.fh-furtwangen.de/~mweisser/modsmega_animation_highres.mpg
(10MB, 40s, mpeg1)
Date: 16 Jan 2004 16:47:12
Message: <40085B76.5AD99B2A@onwijs.com>
Cool! Looks a bit like a chemical plant.
> Hi
>    modsmega_animation.mpg    Type: WMPLAYER File (video/mpeg)
>                          Encoding: base64
Subject: Re: Flight over PCB SE * Eagle-3D
Date: 18 Jan 2004 04:03:14
Message: <400a4bd2$1@news.povray.org>
Hi Matthias,
I wanted to see how you all do these impressive PVB-Flights, so I downloaded
your
Eagle-3D.
Installed it, uninstalled it, installedEagle 4.10 (lite) first, installed it
again ....
Ok, after a lot of trial and error it finally works.
My last PCB was at the times when we all have been drawing it with a black
Marker
and using "Eisen-III-Chlorid" to get the result.
So to make it run was not easy, if not to say I would have liked more
instructions for
"non-eagle-experts" how to get the first picture.
However the results of your Eagle 3D-Program are REALLY impressive.
(Once you manged to understand where to put what and how to start it.
Especially the quality of the resulting 3D Pictures are impressive
- without any manual changes.
And of course the resulting POV-Files can be rendered with SMPOV easily
after putting those ".inc"-files in the "COM/INI"-folder.
(I think THS added one more CPU yesterday for his next strike .-)..
--Theo
Date: 18 Jan 2004 04:29:42
Message: <400a5206$1@news.povray.org>
After looking in the Internet a while, I must say that all these PCB's I
found are really SMALL.
A network-card, a MPEG Player ist the biggerst I think.
Taking note of the fact that we have too do with virtual electronics that
must not be paid for each resistor,
I would like to see a really BIG Layout with hundreds of transistors, IC's,
Resistors.
After all its not important that this would really do something usefull, it
should look good for the flight ...
--Theo
