Here's a different version, looks very cool when played at full screen :)
Tek
www.evilsuperbrain.com
"Tek" <tek### [at] evilsuperbrain com> wrote in message news:3ff60dad@news.povray.org...
> Here's an animated version of the lace pattern I posted on p.b.i
> The code for it is this:
> #declare fA = frame_number;
> pigment {
> //choose some pretty colours
> bozo scale .3
> pigment_map {
> [.3 bozo translate 7 colour_map { [.5 rgb x/2][.7 rgb .8] }]
> [.7 rgb <.7,.5,.1>] }
> //make it into a kaleidoscope
> #local nCount = 0;
> #while ( nCount < 10 )
> rotate -fA*z
> warp { repeat y flip y }
> #local nCount = nCount + 1;
> #end
> Tek
Download 'warprepeat4000.m1v.mpg' (539 KB)
> Tek
Very cool!
:o)
Remco de Korte wrote:
> Very cool!
Very
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
Very cool :)
How did you compressed the video so much? Which program did you use?
news:3ff62c90@news.povray.org...
> Tek
> > pigment {
> > bozo scale .3
> > pigment_map {
> > #local nCount = 0;
> > rotate -fA*z
> > #end
> > Tek
"Nicolas Alvarez" <nic### [at] hotmail com> wrote in message
news:40ca4912@news.povray.org...
The compression really isn't that good. The animation has a relatively small
amount of movement and lots of smooth gradients, so each frame looks very
similar to the next, which makes it compress well (i.e. I can use low quality
compression and it still looks good). Plus it's very low res.
I use Tmpgenc: http://www.tmpgenc.com/
It's got a lot of settings that can be tweaked to refine the compression, though
IIRC this animation was made with mostly default settings, I just tweaked the
"rate control mode" & quality.
Tek
> Very cool :)
> > Tek
> > > pigment {
> > > bozo scale .3
> > > pigment_map {
> > > #local nCount = 0;
> > > rotate -fA*z
> > > #end
> > > Tek
