Hi all ; )
I would like to show the results of my work on liquid simulation; well,
just a little animation about a breaking dam problem in a complex
environment and the following inflow of water through a pipe from a
higher tank. Physical simulation has been realized using Smoothed Particle
Hydrodynamics. The triangle mesh exported in PovRay for the final
rendering is an approximation (Marching Cubes here), of the isosurface
defined selecting an appropriate value over the global
scalar field generated by the particles. I know... the liquid is a little too
much viscous to be real water, but it's a "problem" of the method (I'm
gonna give some explanations if you're interested in) and I'm investigating
a way to work it out.
What do you think?
Thx all
Claudio
(sorry for my english)
Sry :) Here the link
http://digilander.libero.it/stajaame/index.html
Claudio
> What do you think?
I think it looks awesome! Is it all POV-SDL, or some external program? How
long was the parsing time for the frames? Rendering times? I'm not so much
interested into the inner workings (they're sure interesting, but I don't
have the time right now to wrap my head around that) but more how easy it
could be used by some average guy? Like, do I need to build my scene with an
isosurface, or can I just hand a POV-object to the program? How about
setting up frames/steps?
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Version: 6.0.538 / Virus Database: 333 - Release Date: 10.11.2003
cla### [at] libero it news:3fb25931$1@news.povray.org
Can You please recompress it with some "standard" codec like mpeg-1, divx,
vxid?
Claudio Pozzoli wrote:
> Hi all ; )
> What do you think?
It looks very good. If you wrote the simulation engine yourself i guess
a lot of people here would be interested in it.
Note that you don't need to generate a mesh from the scalar field,
POV-Ray can directly render isosurfaces. I did renders of fluid
simulations before by generating a density file from the simulation data
and using it in an isosurface.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
> vxid?
Uploaded a mpeg-1 compressed video ; )
Claudio
Very, very impressive. I'd be interested in some more information about the
algorithm used. Is it similar to the one used in
http://graphics.stanford.edu/~fedkiw/papers/stanford2001-02.pdf?
-Chris
I've wrote and external program responsible for the physical simulation of the
liquid. Every time step (user defined) it saves in a file the surface of the liquid
in mesh2 format (around 12000 vertex and 22000 triangles for the simulation
posted). All those file are then processed by PovRay for final rendering
(Pov is used only for that purpose). Rendering times are a problem, though:
8 min / frame with radiosity and photons on (~360 frames in the animation
you've seen). Maybe an advanced user could optimize
some parameters and speed up rendering without a loss in quality... :)
> I'm not so much
Right now the program is not user-friendly (well, I was in a hurry to complete
my thesis so I postponed that aspect...). It provides a graphical interface
for preview purposes only but you have to setup your scene through a text
file whose sections define:
-) external time step - frame save time.
-) particles number
-) initial position of fluid blocks (if any).
-) fluid emitters (if any - with start / end time).
-) boundary definition (just planes for the moment)
Just a word: boring : (
Once started the simulation you only have to wait (a lot... : P): 100 secs / frame
for that animation (~100000 fluid particles). Computational time and memory
requirements increase quickly raising the number of particles involved.
The program advance internally by a time step that respect stability conditions
(for example, if the average inner step is 0.0001250s (realistic value), the
program have to update the simulation ~160 times from a frame to another,
if the user defined a 0.02s external time step).
I'm working on a user-friendly editor in my spare time (not that much), so who
knows... :)
Claudio
Ps: I've uploaded another animation (ogl preview of a different simulation).
The simulation is based over Smoothed Particles Hydrodynamics, a
pure lagrangian method introduced in late '70 by Gingold and
Monaghan and originally used to model compressible flows in
astrophysical simulations. Successively it has been adapted to the
simulation of quasi-incompressible - incompressible flows.
The liquid is approximated by a finite number of particles, each carrying
physical informations like density, pressure, speed, viscosity...
The value of every physical quantity at any point is estimated by taking a
weighted average of the same quantities associated with the particles
located in a surrounding volume. Navier-stockes equations are
"rewritten" as inter-particles interaction laws. I don't have a english
paper based over my work right now but many articles have been
published this year and last one (it seems like the raise in computational
power increased the attention of computer graphics community over this
method, really time-consuming :) ). Here some references (try google
as well, though many papers are mainly focused over astophysical
applications):
http://mec-mail.eng.monash.edu.au/~mct/mct/docs/sph/sph.html
http://www.eg.org/EG/DL/WS/SCA03/154-159-mueller.pdf
http://cggmwww.csie.nctu.edu.tw/images/jwchiu/ModelingLiquid.pdf
How could I do this? I mean: once I've generated a density file, following
the examples in pov documentation, I have to use it as a pattern (media,
pigment-normal) and associate it with a primitive. Do you use an isosurface
as object? densityfile as a media pattern? I would like to test it out! : )
Claudio
Update: use this instead http://graphics.ethz.ch/~mattmuel/publications/sca03.pdf
No ; ) the approach they used is semi-lagrangian (particles + level set method,
they combined a lagrangian approch with a eulerian approch).
Smoothed Particle Hydrodynamics, used (with some changes) in the program
I wrote, is a pure lagrangian method. Fluid evolution is tracked following
the movements of many pseudo-particles during the simulation. Have a look at the
links I've posted in the previous message, you'll find a good description
of the technique there. ; )
Feel free to ask if you need more details.
Wow... è impressionante!
Very very nice. We want to see more :)
Fernando
Thanks for the explanation, i was more referring to the actual program
though. The nice thing about particle based fluid simulation is that
the fluid can move in large areas without excessive memory requirements
that would occur with grid based methods. It could even be worth
considering integrating such a system into POV since for interaction
with the environment you could rely on the raytracing functions.
You can use the density file in an isosurface shape just like any other
pattern:
#declare Fn_Density=
function { pattern { density_file df3 "file" interpolate 2 } }
isosurface {
function { Fn_Density(x, y, z) - 0.5 }
This will show the isosurface with density=0.5.
> What do you think?
That is very very impressive!!
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
cla### [at] libero it news:3fb29804@news.povray.org
>> divx, vxid?
wooow
*realy* nice :) I quess it's nices water I had even seen in pov :)
In short, there are two different computational phases:
1) Compute change rates for every particle involved in the simulation. In detail:
-) fluid-fluid particles interactions (every particle within a fixed distance from
the particle being updated has to be considered in the process. Check
the papers for more details about the equations... you have to update
accel. and density. ~30-40 neighbours / particle).
-) external forces (gravity... simply add them to the accel. vector of the
particle).
-) boundary-fluid particles interactions (for the moment boundary is
modelled introducing fixed particles in correspondence of the solid
surface and adopting a pure repulsive Lennar-Jones interaction force.
Fixed particles are placed really close in order to form a strong
barrier to the penetration of the fluid). It should be easy to replace
particles and to manage directly particles-solid collisions.
Note: 1a) In order to speed up computations, as the interpolating kernel
presents a compact support (only particles within a fixed distance
interact), it could be used (well, it's obligatory ;) ) a suitable
neighbours
finding algorithm. I've used a simple uniform grid: all the
neighbours of the particle being updated are located checking only
few adiacent cells (you can take advantage of the simmetry in
particle-particle interactions to reduce computations).
1b) Current time-step is determined checking the physical properties
associated to every particle (simply check accel. and speed of sound).
2) Update particles position-density-speed (leapfrog scheme, prediction - correction
formulation) using change rates and timestep found in the previous step.
The first one is the more complex and time consuming phase by far...
1661s computation -> 1558s phase 1 vs 102s phase 2... ;)
> pattern:
> isosurface {
Gotta try it but I have to rerun simulation to collect data once again, though.
I'll do it in the weekend.
Very convincing, and good luck with your thesis. A bit of flash always goes
down well!
I can understand that the photons are giving you some very nice caustics,
but I'm not sure radiosity is contributing much. Do you save much time with
it off?
OK, so that's downright cool!
*sigh* Makes me wish I could do stuff like that... but last time I read a
paper on the subject, it was totally over my head. (I'm still trying to
figure out how on Earth cubic Bezier splines work... heh)
Thanks.
Andrew.
> it off?
I'll post some screenshots with and without photons/radiosity as soon as
possible (I've formatted my hd... I've got to reinstall everything :P).
Claudio
Beautiful !
I always were a liquids freak so this is really nice to watch ! I wished I
had time to study this furthermore !
/~\nne
