I was bored and made this relatively simple animation. But it's not that
interesting. I don't have any specific plans for it, so do you have any
ideas in which direction I could take it (no pun intended) to make it a
cool animation?
No suggestions requiring detailed modelling, please... ;)
Rune
rune|vision: http://runevision.com **updated Jul 25**
POV-Ray Ring: http://webring.povray.co.uk
Download 'tunnel.mpg' (521 KB)
Subject: Re: Underground Tunnel ( mpg 520 kbu )
Date: 13 Aug 2003 10:18:11
Message: <3f3a48a3$1@news.povray.org>
It's Ronald Reagan's colon!
Cheers!
Chip Shults
On Wed, 13 Aug 2003 16:11:17 +0200, "Rune" <run### [at] runevision com> wrote:
What else can I do if faces near camera destroy impression :-)
ABX
I'd like to see a tunnel that was not undergound.
You could improve the smoothness of the camera tracking.
Andrew Wilcox
I'd be interested in knowing your technique for creating the tunnel.
Isosurface, triangles?
What about dimming the light, and let some coloured glows fly around...?
Hugo
Triangles, as ABX correctly noticed... The tunnel follows a spline and
is diplaced by a granite pattern.
I actually tried that exact idea at first, but I didn't manage to make
it look very good for some reason. Technically it worked fine, but it
just didn't have any wow-effect.
Rune
Well, the tunnel is not modelled, it's generated. Making more faces is a
matter of changing a parameter. I could do that...
Rune
Well, that would be a completely different animation...
But out of curiosity, what are you thinking of specifically?
I'll try.
Rune
Heh...
Rune
Triangles, I see! Btw, how did you make the tunnel loop perfectly? A granite
pattern never repeats.
> but it just didn't have any wow-effect.
Oh, well... What about attaching the glows to the rocks? That might look
less confusing.. I don't know about the wow's though.
Hugo
> loop perfectly? A granite pattern never repeats.
Hehe, I hoped you'd ask that question!
If the tunnel was a torus, it'd make perfect sense, right? But the
tunnel is not a torus. However, the mapping is taken from a torus.
The displacement of the tunnel is UV-mapped (and so are the textures).
But instead of taking the mapping from a square in the xy-plane, I took
it from a torus. Well, technically, I made a function which mapped the
pattern on the surface of a torus onto a square in the xy-plane, and
like all uv-mapping, this square was then mapped onto the tunnel. I then
just placed two copies of the tunnel in the scene, one in extension of
the other.
A side effect is that the granite pattern in the tunnel is slightly more
squeezed together in the left side than in the right, but it's so little
that it's not noticeable.
> rocks? That might look less confusing.. I don't
It's an interesting idea.
Rune
"Sir Charles W. Shults III" <aic### [at] cfl rr com> wrote in message
news:3f3a48a3$1@news.povray.org...
> Cheers!
> Chip Shults
> My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
That's weird... that's exactly what I thought... Not
necessarily Ronald Reagan's, but anyway...
Scary indeed...
Best,
S.
Steven Pigeon, Ph. D.
pig### [at] iro umontreal ca
Date: 15 Aug 2003 03:34:30
Message: <3f3c8d06@news.povray.org>
I was just kidding. It's hard to picture a tunnel that's not underground.
How about a tunnel through a swirly mist, a tunnel through space-time (a
worm hole), or a tornado?
Date: 23 Aug 2003 21:52:52
Message: <3f481a74@news.povray.org>
Is the movement a spline or is it artificial intelligence navigating the
interior?
Why don't you put up some more images at zazzle if you're bored?
> intelligence navigating the interior?
It's a spline.
My existing images are not good enough in my opinion, except one, which
will require quite some reworking before it will look good at a higher
resolution. And creating new images requires inspiration...
Rune
