Subject: 2nd Attempt at Flowing Water... (MPG, 274kb)
Date: 28 May 2003 20:51:04
Message: <3ed55978@news.povray.org>
Another try, now with a longer stream
and some "rocks" (as suggested by
Dave). Had some side-effects, which become
obious somewhat later in the animation.
All in all, it seems to be too much work for
flowing streams using this system. Would
probably be better to use a similiar approach
(node-based calculations for a mesh) and
generate some basic flow data and then
superimpose some random waves onto that
to get a similiar look.
I'll probably still release the little snippet of
code I wrote for this, just in case someone
wants the insight into this and wants to work
on it.
To be honest, I've never expected the algorithm
to be more useful than for non-moving, confined
water-surfaces, so I'm not that disappointed... :-)
Tim
Tim Nikias v2.0
Email: Tim### [at] gmx de
Download 'flowtest_lq.mpg' (275 KB)
Wow! the begining looks very convincing, I wonder why the waves are
multiplying as they go through. Still this is a very clever use of your
system, I think if I wanted to use it in a scene though I would get the
data for one full rotation and then run it in a loop.
Can't wait to see the macros!
Subject: Re: 2nd Attempt at Flowing Water... (MPG, 274kb)
Date: 29 May 2003 02:01:24
Message: <3ed5a234@news.povray.org>
Stunning! If you get your energy to follow a log curve instead, it will
dampen and stay there instead of growing out of control.
Cheers!
Chip Shults
Date: 29 May 2003 05:58:34
Message: <3ed5d9ca@news.povray.org>
I'll put them up on my website sometime this
day (once I get to it). Thanks for the comment!
Tim Nikias v2.0
Date: 29 May 2003 05:59:19
Message: <3ed5d9f7@news.povray.org>
I'm not sure what you're after with "energy" and
"log curve"... Care to explain?
Tim Nikias v2.0
will
> Cheers!
> Chip Shults
> My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
Behold! Ulmo is rising!
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
Date: 29 May 2003 09:56:40
Message: <3ed61198@news.povray.org>
I haven't seen the code you use to produce the waves, but wave height is
equivalent to energy. And since the waves continue to grow behind obstacles
rather unrealistically, it means that your "bookkeeping" of the height has an
error somewhere. Real waves become broader rather than taller, and in some
cases they will spray droplets.
My thought is that if there is too much involved in getting the energy math
right, it may be easier to use logarithms for the height rather than completely
redoing it all, and then the peaks will be severely curtailed instead of growing
so large.
Cheers!
Chip Shults
Date: 29 May 2003 12:42:45
Message: <3ed63885$1@news.povray.org>
So, are you another one of those
LOTR-Fans?
Tim Nikias v2.0
Date: 29 May 2003 12:45:13
Message: <3ed63919@news.povray.org>
The algorithm I use is pretty simple: I store
the heights, smoothen these outward onto neighbouring
nodes. To save parsing time, I leave out nodes which
are inside objects, which seems to produce the
error in this case: since the blocked nodes aren't
processed correctly (and thus aren't set to 0), they
add up and spill over later. Need to check more thoroughly
on that.
If you want, you can have a look at the source-code,
just head on to my homepage, in the downloads-
section.
Tim
Tim Nikias v2.0
is
obstacles
an
some
math
completely
growing
> so large.
> Cheers!
> Chip Shults
Great work, Tim! This may be a misuse of your macros, but it seems like it
could work.
> Would probably be better to use a similiar approach
> (node-based calculations for a mesh) and generate some
> basic flow data and then superimpose some random waves
> onto that to get a similiar look.
Interesting comment. Where can I read about this? I only have a vague
understanding. I think it's possible to precalculate data (one normal vector
for each node) with reference for the wave direction. This means, there will
be an overall direction (the wind) for the waves, and there will be a
sublayer where the waves go in all the directions that is specified by the
precalculated data... But how to push these subwaves around, within a
reasonable time, I don't know...?
Best regards,
Hugo
Date: 29 May 2003 15:27:38
Message: <3ed65f2a$1@news.povray.org>
Okay, without looking at the algorithm directly (which I will do shortly),
here is my take from a physics standpoint. Then I can see what you have and
whether this is useful or not to you.
Imagine the body of undisturbed water as a set of blocks. Each block will
have a height. Now, no matter what is done (without adding or removing water),
we know that the average height of all blocks must remain constant at all times.
Now, let's look at waves and ripples. You can model them as an array of
scalars, and each location of the array is applied to the array of blocks to
alter their heights. This array describes how the water surface will change
from moment to moment.
But now, we see that a third array, one that modifies the scalars, is
needed. It controls the viscosity (as a single parameter for the whole body of
water at once) and the damping factor and it stores the modifiers for the
scalars. This second derivative is where the action would be.
But when we turn it on its head, this array is really the "water" so to
speak, and the scalars are its first derivative, and the water surface is the
second derivative, and it is completely dictated by it. If you make fixed
points in this third array, it will automatically "fix" the overflows, I would
think.
I am going to continue to consider this and see if I can make a useful
"wireframe" animation in realtime first. Then it should be written in C or
something and done on the computer screen directly. Then the addition of water
becomes a volume added to a point and its velocity or energy, and the rest will
follow from there.
Or maybe I am a complete loon...
Cheers!
Chip Shults
Date: 29 May 2003 18:49:59
Message: <3ed68e97@news.povray.org>
The technique you describe assumes a volume-preserving
attempt at modelling the water. This isn't done in this
algorithm. All it does is raise some nodes of the mesh,
aka the wave-height. This height is spread out using a
smoothening step. In order to not just smooth it out, but
create wave-fronts, I subtract the waves of one step
ago. Thus, only the newly smoothened heights, passed onto
neighbouring nodes, stay unaffected of the following
subtraction, as they have nothing to subtract. This technique
is then done once per frame, and thus I get waves travelling
from some origin onward until the smoothening and
dampening process has taken care of removing the wave.
The problem that seems to appear here is that although
waves are moved downstream by moving the data of the
nodes "downstream" (remember, I'm not moving the nodes
themselves, just the data contained therein), waves do
spread out in all directions. It seems that behind the boxes,
I add no height from former waves (as waves have zero
height inside the blocking objects), but spreading waves
will still move there. But I'm actually not too sure about
the origin of the side-effect. Could be this, or some
other thing, like waves adding up inside the blocked nodes,
and finally emerging behind them... I have an idea how
to check that though, but otherwise, it seems a pretty
difficult thing to achieve with this algorithm...
But I'm interested in what you get cooked up, so
please keep me (and others) updated! :-)
Tim Nikias v2.0
shortly),
and
will
water),
times.
of
to
change
body of
to
the
would
> think.
or
water
will
> follow from there.
> Cheers!
> Chip Shults
Date: 29 May 2003 18:59:15
Message: <3ed690c3$1@news.povray.org>
> could work.
Thanks, but no, its no misuse. Its using the system for something it
wasn't originally designed for, and thus requires more testing and
fiddling. And since the Pre-Processing-Macro is an "inbuilt" part
of the LSSM, its more like an unstable first attempt, than a misuse... :-)
vector
will
I actually have no idea where you could information on this. I tend to
cook some stuff up myself most of the time. In this case, I'd say I'd
go create the nodes, check which ones are blocked, and then decide
which ones are the "front blocking nodes", meaning the nodes into
which the moving water crashes head-on. Then I'd find the contour,
and try to create some surrounding waves based on the
info I have on stream-direction, blocking nodes, etc. With this
approach, one could also easily try to reproduce those waves which
appear in shallow regions, where the masses move on top of some
boulder and cause a peak on the surface...
Anyways, once the basic flow (which would actually be more like a still
frame from a river) has been generated, I just take some height-data
(probably generated using a function-image of a pattern or such) and
add it onto the nodes' heights. This added height-data may be translated
along some direction and thus add a moving effect onto the base-waves,
and when slightly modifying the function-slice itself, the waves would
also seem to change and move on...
Parsing-Wise, the first generation of the base-flow would be time-consuming
I guess, after that, you just need to generate the mesh for each frame by
parsing through each node and adding the appropriate function-value...
Tim Nikias v2.0
On Thu, 29 May 2003 18:41:43 +0200, "Tim Nikias v2.0"
>LOTR-Fans?
Yep, just went into Akalabêth for the umpteenth time :))
