POV-Ray : Newsgroups : povray.binaries.animations : Test1 - Objects and Water (206kb MPG1) Server Time
27 Nov 2026 15:40:19 EST (-0500)
  Test1 - Objects and Water (206kb MPG1) (Message 1 to 3 of 3)
Subject: Test1 - Objects and Water (206kb MPG1)
Date: 4 Apr 2003 10:31:17
Message: <3e8da545@news.povray.org>
This is the first attempt at objects interacting with the
water surface. It works fine so far, still, you can see some
noise introduced: its trailing the sphere. I've also got to
take care of some smoothening issues with the initial
wave-emitters caused by objects, because their edges
are too sharp and cause interfering nodes which jump
out of the regular flow. This isn't visible on the animation,
cause the smooth-triangles hide that pretty fine on such
small resolutions.
I'll work a little more on the macro for this part, and then
create some tests with more complex objects.
Another issue is Mesh-Support, cause the inside() function
doesn't work on those. I've already got a solution for
this, but it needs to be implemented... :-)
Anyways, just some small bit to show off that I'm working
on it... Enjoy!
Tim
Tim Nikias v2.0
Email: Tim### [at] gmxde
Download 'water_obj_test1.mpg' (207 KB)
Subject: Re: Test1 - Objects and Water (206kb MPG1)
Date: 4 Apr 2003 11:54:53
Message: <3e8db87a.173300462@news.povray.org>
Getting better and better, but please stop rotating the camera it makes me
seasick.
Regards
Date: 6 Apr 2003 22:05:58
Message: <3e90dd06@news.povray.org>
Didn't want to cause some sickness! Sorry for that.
I used a rotating camera to see if waves weren't
distorted in some direction. Since they aren't and
haven't been until now, I'll stop with that. :-)
Tim Nikias v2.0
> seasick.
> Regards
>         Stephen
