Subject: Liquid metal reaction... (352kb MPG1)
Date: 27 Mar 2003 17:47:26
Message: <3e837f7e@news.povray.org>
I've experimented a little with my water-system, and tried
leaving the dampening of the waves out. I would have
thought that the distribution of the wave would take care
of enough dampening, obviously, I was wrong.
But, as a side effect, it is clearly visible that
a) surrounding walls need to be high enough, and
b) that certain sections are saved from the parsing-process.
In all those places where the water pops over the rim and
then drops down to the walls, thats where a node is set
to "off" and isn't parsed at all. It just stays put, since
"normally" it wouldn't be needed (unless serious
problem rise up, like this animation shows).
Well, I found this rather an amusing look (like a cake
in an oven) and thus thought, some might want to see
it... :-)
Tim Nikias v2.0
Email: Tim### [at] gmx de
Download 'water_b4.mpg' (353 KB)
Ah! It cuts off just as it gets interesting. Would it stabilise or get chaotic?
Looks good though, very SF'ish.
Regards
I bet it will get chaotic more and more until there are overflows
(numerically).
Subject: Re: Liquid metal reaction... (352kb MPG1)
Date: 27 Mar 2003 19:34:45
Message: <3e8398a5@news.povray.org>
I'm not quiet sure what would've happened. I'm
rendering another simulation right now, but I want
to use a similiar setup again and see what
actually happened.
For one, I realised that the very first position of the
wave never stopped jiggling about, and sort of
bumped itself upwards. Without dampening, the
reflection of the waves in such a tight corner might
add to itself in such a way, that the smoothing
part of the algorithm can't smooth it away. Dampening
definitely took care of that issue.
What I don't like about that, is that I can't control that.
There's no way, other than telling you to not use no
dampening, to avoid this effect.
Perhaps I'll add the "interesting" part tomorrow, we'll
see.
Tim Nikias v2.0
--------------( oo )--------------
Your simulation are very interresting.
You said that it tooks a lot of calculation to render this. How much time
does it tooks? Is the Parsing is longer than the render time?
guillaumeLaBelle [alias goo©]
"Tim Nikias v2.0" <tim### [at] gmx de> wrote in message
news:3e837f7e@news.povray.org...
> it... :-)
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
It depends on several factors. For the parsing time,
the resolution of the array which holds the heights
is the main factor, along with the amount of steps that
have to be calculated per frame.
After the simulation, my Mesh-Modifying-Macros kick
in to generate the mesh and its surface-normals. These
also take a little time, but very little compared to the
simulation.
The tracing time depends on the features I'm using. The
mesh itself can be traced fairly quick, but if I'm using
a transparent surface, variable reflection and photons,
render time rises of course. Along with that, I use antialiasing
for the the final renders, so that even the large high-quality
MPGs I keep for myself look smooth.
On a render I'm doing right now, I'm using 60*60 Nodes, so
thats 3600 nodes for the simulation. Mind that the simulation
sort of "clips" dead nodes and doesn't touch them. On these
spherical pools, this saves a lot, since the corners are
completely left out. The mesh uses a reflecting surface to get
that liquid metal look. Additionally, I use antialiasing on the
current render.
Thus, on my Athlon 1.4GHz, it parses at about 13 seconds
per frame, and traces with about 23 seconds per frame.
So thats 36 seconds per frame. For 250 frames, this takes
roughly 2h.
Still, parsing time wouldn't go up with more or less waves,
their height doesn't matter. So, thats an advantage, and
can guesstimate fairly good how long an animation
might take. OTOH, it'll take that long for parsing even
if there's no wave present.
Tim Nikias v2.0
Subject: Liquid metal reaction Take 2 (396kb MPG1)
Date: 28 Mar 2003 07:11:44
Message: <3e843c00@news.povray.org>
Here's a longer version. As mentioned before,
it seems that the water juggles itself upwards
in the tight back corner, where smoothening
doesn't "eliminate" height (which is normally
a wanted side-effect). I've stopped the simulation
when the liquid metal reached the clipping-object,
since that's just about where the interesting part
ends. After that, it'll just fill up indefinitely.
Nontheless, the waves look convincing, how
they swirl around the cylinder... I like it. :-)
Tim Nikias v2.0
Download 'water_b4b.mpg' (397 KB)
Subject: Re: Liquid metal reaction Take 2 (396kb MPG1)
Date: 28 Mar 2003 07:31:19
Message: <3e844097$1@news.povray.org>
hey tim
that's really cool. i like espescially the moment just when it reaches the
clipping container, with only the "side walls" of the water visible. looks
really nice.
keep up the good work
florian
So it stabilizes by growing upwards in the shape of the vessel. The last six
frames are intriguing.
Regards
Very cool, but as for a liquid metal, per se, the surface tension is wrong.
Date: 28 Mar 2003 08:41:01
Message: <3e8450ed$1@news.povray.org>
That not really stabilizing, is it? There's a wave
which pushes back and forth between the initial
corner and the first blocking box. Every time it
hits the corner, the higher it rises. This also
happens at the "nozzle", where one section
flows into the other. It would go on rising forever,
I guess, otherwise, it would have stabilized
much earlier.
Tim Nikias v2.0
six
> Regards
> Stephen
Date: 28 Mar 2003 08:42:05
Message: <3e84512d@news.povray.org>
Thanks. I hope to get this system running by next
week, and then I'll probably start something like a
beta-phase or so.
Tim Nikias v2.0
> hey tim
> really nice.
> florian
I don't have any experience with liquid metal, and haven't
seen much aside the VFX shots of liquid metal, so thats
not really something to compare to, right?
And I'm only using reflection to make the surface more
visible, since reflecting looks nicer than gradient colors
for height...
Tim Nikias v2.0
wrong.
On Fri, 28 Mar 2003 14:40:01 +0100, "Tim Nikias v2.0" <tim### [at] gmx de> wrote:
No, I guess not. What value do you normally use for damping? I have been playing
with the "water effect" and I've some peculiar results with different values.
Regards
Date: 28 Mar 2003 19:42:41
Message: <3e84ec01@news.povray.org>
Depends. Most of the time, I'm using .95 as a
dampener, though this error only happened with
1 (no dampening). With .99 it worked fine, though
very fluctuating.
How do these "peculiar" results look like?
Tim Nikias v2.0
playing
values.
> Regards
> Stephen
On Sat, 29 Mar 2003 01:41:42 +0100, "Tim Nikias v2.0" <tim### [at] gmx de> wrote:
I did not keep them when I upgraded my PC, but I will start a new thread called
"Things that went wrong" with a mistake in a heightfield generating programme.
Regards
