POV-Ray : Newsgroups : povray.binaries.animations : Re: Now with wind! Server Time
12 Oct 2026 17:37:02 EDT (-0400)
  Re: Now with wind! (Message 1 to 13 of 13)
Subject: Re: Now with wind!
Date: 9 Nov 2002 23:58:02
Message: <3dcde75a@news.povray.org>
Neither RealOne nor MediaPlayer will show the clip :-(
"Fernando González del Cueto" <fgd### [at] hotmailcom> wrote in message
news:3dcdbf35@news.povray.org...
> Evidently, many things have changed since the last post:
> - Smooth mesh
> - Wind
> - Adam's-Bashford-Moulton predictor-corrector ODE solver in the code
> Smooth, ain't it? :)
> I'll appreciate any comment and/or suggestion.
> Fernando.
Date: 10 Nov 2002 00:35:11
Message: <3dcdf00f@news.povray.org>
It's beautiful! When can I play?
Had to convert it though... My codec said it was 59.941 fps DivX.
=Bob=
: Evidently, many things have changed since the last post:
: - Smooth mesh
: - Wind
: - Adam's-Bashford-Moulton predictor-corrector ODE solver in the code
: Smooth, ain't it? :)
: I'll appreciate any comment and/or suggestion.
: Fernando.
Date: 10 Nov 2002 00:39:26
Message: <3dcdf10e$1@news.povray.org>
Very nice! Unlike others played perfectly here.
> - Smooth mesh
> - Wind
> Fernando.
Date: 10 Nov 2002 08:21:17
Message: <B9F40C9D.682F%fidel.viegas@artrecognition.co.uk>
That looks really cool. How long did it take to render?
All the best
Fidel.
in article 3dcdbf35@news.povray.org, Fernando González del Cueto at
fgd### [at] hotmailcom wrote on 10/11/02 1:28 am:
> - Smooth mesh
> - Wind
> Fernando.
Date: 10 Nov 2002 12:22:12
Message: <3DCE95C3.5D1B95A5@gmx.de>
> - Smooth mesh
> - Wind
Looks good, of course with that complicated movements the interaction of
the cloth with the air would be much more complicated in fact, it's
probably just simple drag right now.
Last updated 02 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 10 Nov 2002 13:59:36
Message: <3dceac98@news.povray.org>
This is so cool, I can't wait to hear the parsing time for each frame!?
Hugo
Date: 10 Nov 2002 16:40:47
Message: <3dced25f@news.povray.org>
I'm glad you liked it. Actually it IS 59.941 fps... DivX...
I wanted it to have a higher framerate. I don't think that should cause any
problem, or it does?
Thanks,
Fernando.
"=Bob=" <bob### [at] threestrandscom> escribió en el mensaje
news:3dcdf00f@news.povray.org...
> =Bob=
> : - Smooth mesh
> : - Wind
> : Fernando.
Date: 10 Nov 2002 16:41:09
Message: <3dced275@news.povray.org>
"Thomas Lake" <smi### [at] hotmailcom> escribió en el mensaje
news:3dcdf10e$1@news.povray.org...
Thanks!
Fernando.
Date: 10 Nov 2002 16:43:59
Message: <3dced31f@news.povray.org>
I can't remember how much time this animation took... but tipically I'm
getting less than 5 seconds for the creation of the mesh and another 5
seconds for the rendering (for each frame)
Now, I'm adding more detail and textures to the scene, and now it's much
slower the rendering than the simulation :)
I'm happy that you liked it :)
Fernando.
"Fidel viegas" <fid### [at] artrecognitioncouk> escribió en el mensaje
news:B9F40C9D.682F%fid### [at] artrecognitioncouk...
> All the best
> Fidel.
> > - Smooth mesh
> > - Wind
> > Fernando.
Date: 10 Nov 2002 16:51:35
Message: <3dced4e7@news.povray.org>
news:3dced25f@news.povray.org...
: I'm glad you liked it. Actually it IS 59.941 fps... DivX...
: I wanted it to have a higher framerate. I don't think that should cause any
: problem, or it does?
: Thanks,
: Fernando.
My machine is just not capable of playing back that
rate. Had to cut it down, othrwise it drops frames.
Watched it in slo-mo.
=Bob=
Date: 10 Nov 2002 20:57:47
Message: <3dcf0e9b@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> escribió en el mensaje
news:3DCE95C3.5D1B95A5@gmx.de...
> > - Smooth mesh
> > - Wind
Yes, in fact this is very simplistic model of air interaction... the air is
not really modelled as matter but a vector field... it is just a flow which
modifies its surroundings. Anyway, it gives somewhat good results, and it is
MUCH faster than any other realistic model.
Thanks for your comments!
Fernando.
Date: 10 Nov 2002 21:05:15
Message: <3dcf105b@news.povray.org>
As I had posted before, I'm made several experiments, each one with varying
complexity... sometimes I use a finer mesh, sometimes I use smaller time
stepsizes... I can't recall the exact timings of this particular example.
Besides, I coded the simulation in C, because it would be unbearably slow in
POV code, and also in this case it is easier to generalize the code... In
theory I should be able to have cloths in several shapes...
My guess is that for this example the simulation (generation of the mesh)
took about 5 seconds and probably much less for the rendering.
Fernando.
"Hugo" <hua### [at] post3teledk> escribió en el mensaje
news:3dceac98@news.povray.org...
> Regards,
> Hugo
Date: 16 Nov 2002 03:33:35
Message: <3dd602df@news.povray.org>
Mmm... Impressive!
Andrew.
