POV-Ray : Newsgroups : povray.binaries.animations : PartixGen - Inertia (MPG 278kb) Server Time
27 Nov 2026 16:06:14 EST (-0500)
  PartixGen - Inertia (MPG 278kb) (Message 1 to 15 of 15)
Subject: PartixGen - Inertia (MPG 278kb)
Date: 29 Oct 2002 04:59:26
Message: <3dbe5bfe@news.povray.org>
I'm trying to slap some demonstration scenes together
for my particle-system and on this one I'd like to get
some information. I'm not too sure if it isn't overloaded
with animation, with camera movement and fast paced
particles and all...
This scene is to demonstrate particles that have no initial
speed by themselves (they aren't "shot" anywhere), but
rather only move due to the inertia that is inflicted upon
them by the moving field in which they are born.
You can also see the "standardized" setup of the system's
boundary-box, the "Physics Room" (the system may
calculate the paths very realistic "physics", pretty easy
and quick "simple", or using a "macro").
All comments welcome!
Tim
Tim Nikias
Email: Tim### [at] gmxde
Download 'inertia.mpg' (279 KB)
Subject: Re: PartixGen - Inertia (MPG 278kb)
Date: 29 Oct 2002 05:01:16
Message: <3dbe5c6c@news.povray.org>
> *snip*
> *snip*
Hm... With "standardized" I mean standard for
the demonstration files, not for the system. Just
wanted to make sure that that's clear...
Tim Nikias
Date: 29 Oct 2002 05:28:38
Message: <3dbe62d6$1@news.povray.org>
I like it. No criticism at all.
All the best,
Andy Cocker
"Tim Nikias" <tim### [at] gmxde> wrote in message news:3dbe5bfe@news.povray.org...
> Regards,
> Tim
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 29 Oct 2002 09:18:41
Message: <3dbe98c1$1@news.povray.org>
Tim Nikias wrote:
> I'm not too sure if it isn't overloaded with animation,
> with camera movement and fast paced particles and all
I had to view it a few times, but after that I had no problems to understand
what's going on. The camera movement is a little distracting because it has
nothing to do with the P.S., but I guess it helps to optain a good viewing
angle all the way. Maybe it could move less, though.
It would be great with collision detection between the balls, even though
such a feature would be slow. It would be a great step towards realism and
help separate your P.S. from Rune's. It seems your system is aimed at
simulating solid objects falling around.
Nice work.
Hugo
Date: 29 Oct 2002 09:33:40
Message: <3dbe9c44$1@news.povray.org>
understand
has
I was beginning to think so to. Its a little too much movement
of the camera...
That is actually not possible. Rune's PS works by using I/O, every
next step is based on the last, particles move from their position
with a given velocity and direction, the new position is saved, and
loaded and redone for the next frame.
My system uses no I/O, the path a particle takes is calculated using
the simple graph
Position=Initial_Position+Direction*Velocity+Gravity*t*t
Solving the equation to find certain x, y and z values and recalculating
the graph from there results in what you see as the rebouncing off of
walls.
In this manner, I can't check for every particle, IF and WHEN at
*some* time, two particles *might* collide, and IF they DO, what
to do then...
So, I'm not calculating in iteration steps, but rather as processing the
path through time, which is (when not interacting with other particles
and only with the boundary-box) already quite difficult.
In my case, there's no interaction with the environment, but only with a
mathematical boundary, which *happens* to be like a non-rotated box...
So, solid (spherical) objects falling around is actually Rune's
strength, the particles interact with the environment. My system is
aimed at custom particle effects, more like "Magic Sparkles",
perhaps a splash of water, some fire. But without real interaction
with an environment. The strength of my system is that it can
animate backwards, and fade to a stop (bullet-time). Search the
animation-posts for "Matrix-Effect with PartixGen"...
Tim
Tim Nikias
Date: 29 Oct 2002 09:34:12
Message: <3dbe9c64$1@news.povray.org>
Thanks. So I've already got one satisfied customer... ;-)
Tim Nikias
> All the best,
> Andy Cocker
Date: 29 Oct 2002 09:44:18
Message: <3DBE9EC1.CF63CE0D@gmx.de>
> the simple graph
I don't really understand how this is supposed to work.  Your particles
seem to interact with the ground plane and the walls.  How do you do that
without using discrete time steps and linear movement between those steps?
Last updated 28 Oct. 2002 _____./\/^>_*_<^\/\.______
Date: 29 Oct 2002 09:59:36
Message: <3dbea258$1@news.povray.org>
Nice work.
I must admit however I'm a bit confused as to what's happening.  I'd be less
disoriented if there were some object or other way to get a feel for where
the particles are being generated from.  I was expecting it to be one end of
the railing but am not sure of its purpose.
It's cool that you have squash & stretch: does this limit use of other
particles?
It looks like the particles are intersecting each other.  Is this a
yet-to-be fixed bug, OR is your system more designed for fluids and the
like?
> together for my particle-system
How much will  **yours** cost?
Date: 29 Oct 2002 10:31:42
Message: <3dbea9de$1@news.povray.org>
It seemed clear to me that the particles were reacting to centrifugal force, rather
than any
pre-built-in force (such as being shot from a canon, or water compressed emiting from
a
fountain). Hence the rail.. the motion of the emitter (which travels along the rail)
at any
one point dictating the direction and velocity of the particles at the moment that
they're
emitted.
And I like the camera motion, though I would agree that it's not strictly neccessary.
All the best,
Andy Cocker
Date: 29 Oct 2002 10:33:23
Message: <3dbeaa43@news.povray.org>
> Your particles seem to interact with the ground plane
> and the walls.  How do you do that without using
> steps?
By using several functions with different coefficients, where a particle
follow a new appropriate one every time it bounces. It is easy to check
if the x, y or z value of the position of a particle is below or above
certain values, so it is possible to simulate what appears to be
interaction with a non-rotated box. It would be possible with other
shapes too, but it would be way too advanced and inefficient.
I can't tell about it in details of course, but the technique is not a
new one, since the same basic technique is used in Chris Colefax' Liquid
Spray Include File from 1998, though that one only supports a single
ground plane instead of a box.
( http://www.geocities.com/SiliconValley/Lakes/1434/spray.html )
Rune
rune|vision:  http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
Date: 29 Oct 2002 11:23:42
Message: <3dbeb60e@news.povray.org>
Haha! Its interesting how I replied a post and covered
the technique you used, and you replied a post and covered
the technique I used... Thats amusing! :-)
And yes, the technique is similiar to Chris' Spray,
but when implementing this with a box (instead of just
one plane), it gets quiet difficult. Just a few days ago
I had to fix a bug where particles still dropped through
a wall: It hit one hall, and the new impact-position from
which the next path is generated was so close to the
wall, that it fell through the time-calculation of impacts...
(If any of that makes sense... Would be nice to think
it makes some sense! ;-)
Tim Nikias
> Rune
Date: 29 Oct 2002 11:32:51
Message: <3dbeb833@news.povray.org>
> Nice work.
Thanks!
less
of
Hm, that would probably be of use. In some cases, the emitter
need not be visualized, because particles are present in the first
frame, but when particles appear, it might be better. I'll add it.
> particles?
Nope. The effect may even be applied to other particles, though
that will most probably look strange. Its achieved by stretching
the particle along the z-axis and rotating it appropriately. So this
is best used with single-colored spheres, as then this method isn't
obvious.
Rebouncing takes place by calculating impacts of a spherical-field
with the box, so differently and uneven sized objects may look strange when
rebouncing, but that's a problem all general particle systems suffer
in POV (at least those I've seen so far).
> like?
Its not a bug, its a feature! :-)
To be honest, it cannot be overcome, and the system thus is best
used for liquids, smoke, fire etc. Efficiently and expertly used it
may not be obvious that particles intersect (when they're spaced far
enough apart and move around, you'll hardly notice one or two
intersections). After all, its not a real physical simulation. I'd like
to do that one day, but using pure POV-script this is just toooo
slooooow.
Tim Nikias
Date: 29 Oct 2002 15:21:27
Message: <3DBEEDC7.AC0B1A11@gmx.de>
> one plane), it gets quiet difficult. [...]
I wonder if it's worth the efforts.  Of course it's very nice to be able
to calculate the state of the system at several arbitrary points of time
but for most purposes this is not necessary since you either calculate a
complete animation or you just want one final result.  And your method
can't calculate any more complicated influences like wind, friction etc.
BTW, you gain quite some speed advantage if you use a hardcoded system.
If you turn off collisions between masses in Sim-POV and use method 2
environment
collisions you can use quite large time steps without problems and will
have quite negligible simulation times with particle counts like in your
sample.
Date: 29 Oct 2002 17:59:20
Message: <3dbf12c8$1@news.povray.org>
Well, I've begun this project just about more than two
years ago, so I was hardly thinking about implementation
issues, but rather my own skills at that moment. I just moved
from there, and at some point decided to stay non I/O.
Also, I'm a purist kind of artist, modelling and creating
with the intention of being able to say that "absolutely
everything you see is made by me", thus for particle effects
(which shall be used for explosions, smoke, etc) I needed
my own particle system.
I can still remember the day I began: A few spheres scattered
randomly across a disc, moving from their initial location to
a given end-location in a given time. It all evolved from there...
> environment
> sample.
I know that "hardcoding" calculations with C++ or even make a
custom version of POV increases the speed with which it is
calculated. Still, I like to use "original" packages, so I use POV-Ray
in its "pure" state. I only downloaded MegaPOV once, after
I knew that isosurfaces would get implemented, to have a look
at that.
And this way, my script can be run by anyone using POV-Ray,
no recompiling necessary. I like this aspect very much, which
is the same reason why I personally like Java, though C++ is
much more effective and AFAIK faster in many situations.
And regarding parsing times... I'm a very patient kind of guy, if
there is need for it. I do like getting things as quick as possible,
but if the ability of saying "that picture is MINE! *grin*" requires
a few more hours of tracing, no problem. I'm about to build
a second PC from former, updated parts, in order to have a
single PC just set up to trace images once I'm finished with
one...
Tim Nikias
Date: 30 Oct 2002 08:44:18
Message: <3dbfe232$1@news.povray.org>
news:3dbf12c8$1@news.povray.org...
>  POV-Ray in its "pure" state.
See my boids algorithm, which uses I/O, and was "free" from day one.
http://www.geocities.com/pterandon/boids.html
I haven't used it since 3.5.
