POV-Ray : Newsgroups : povray.binaries.animations : Yet another Media Sky [WIP] Server Time
12 Oct 2026 16:20:08 EDT (-0400)
  Yet another Media Sky [WIP] (Message 1 to 16 of 16)
Subject: Yet another Media Sky [WIP]
Date: 18 Aug 2002 04:42:30
Message: <3d5f5df6$1@news.povray.org>
This is my first try to make (more or less) realistic
media-clouds. The cloud-media is contained by two
parallel planes which form the cloud-layer. At ground-
level i've placed a reflective plane for now. Additionally
there is an atmospheric media to blend the horizon smoothly
into a white color. The cam's location moves along a straight
line, starting above the clouds and ending nearer to the ground
(I know, it's not very spectacular :)
I am not satisfied with the cloud-shape yet and the horizon-effect
is a bit too strong, too.
Rendertime was about 2 - 3 minutes per frame at 256x192 on my
700MHz-machine
Comments and Criticism are welcome :)
Thies
P.S.: video-files are appended in replies
Subject: Re: Yet another Media Sky [WIP] - MPEG [503 kb]
Date: 18 Aug 2002 04:44:52
Message: <3d5f5e84@news.povray.org>
Download 'cloud_flight.mpg' (503 KB)
Subject: Re: Yet another Media Sky [WIP] - DivX [541 kb]
Date: 18 Aug 2002 04:47:39
Message: <3d5f5f2b@news.povray.org>
Download 'cloud_flight.avi.dat' (541 KB)
Date: 18 Aug 2002 14:36:54
Message: <3d5fe946@news.povray.org>
This is beautiful!
Maybe the Sky above the clouds could be darker (leaving atmosphere) or
more blue to increase the contrast. But this could be a thing that got
lost in video compression...
Sebastian H.
Date: 18 Aug 2002 15:16:30
Message: <3d5ff28e$1@news.povray.org>
The clouds look convincing from a distance. But flying through the plane
makes them appear too thin.. I would also be interested in a direct
fly-through a dense cloud, which is not possible with planes.. Anyway, the
render time is very reasonable and that matters a lot!
The DivX version looks almost like mpeg1 so try compressing it to 80 kB next
time.  ;o)  DivX is SO good..
Hugo
Date: 18 Aug 2002 15:36:24
Message: <3d5ff738$1@news.povray.org>
"Sebastian H." <seb### [at] webde> wrote in news:3d5fe946@news.povray.org...
> This is beautiful!
You're right, the Sky is too dark. This is caused by the sky_sphere which
already has a blue->white gradient towards the horizon plus an athmospheric
media which produces a similar effect. Combined they don't look too realistic.
In the new version I've fixed that problem by making the background completely
blue and letting the atmospheric media create the bright horizon.
Perhaps I'll post a still image of it soon.
> Regards,
> Sebastian H.
Greetings,
Thies
Date: 18 Aug 2002 15:43:25
Message: <3d5ff8dd$1@news.povray.org>
"Hugo" <hua### [at] post3teledk> wrote in news:3d5ff28e$1@news.povray.org...
Thanks!
> But flying through the plane makes them appear too thin..
Yes, you're right. I made the clouds so thin firstly because of render-time
and secondly i had problems with thicker clouds getting too greyish like
some rainclouds.. Perhaps i can get the look right with different extinction-
values..
Yep, i'll try to make a flythrough in the next animation.
> Regards,
> Hugo
Greetings,
Thies
Date: 20 Aug 2002 08:05:57
Message: <3d6230a5$1@news.povray.org>
Very cool.  It's even neater that it's animatable.
Date: 20 Aug 2002 13:43:32
Message: <3d627fc4$1@news.povray.org>
Very impressive, good render time too.
I was thinking of doing a 'from orbit' picture of a skyhook descending to
it's docking station - your picture reminded me of the final stages of that
descent.
What are you going to do with it?
                  == John ==
"Thies Heidecke" <h3i### [at] gmxnet> wrote in message
news:3d5f5df6$1@news.povray.org...
> Hi,
> 700MHz-machine
> Thies
Date: 20 Aug 2002 13:59:45
Message: <3d628391@news.povray.org>
"Greg M. Johnson" <gregj:-)565### [at] aolcom> schrieb im Newsbeitrag
news:3d6230a5$1@news.povray.org...
Thanks! I'm already rendering the next animation =)
Greetings,
Thies
Date: 20 Aug 2002 14:21:14
Message: <3d62889a$1@news.povray.org>
"John D. Gwinner" <jgw### [at] dazsicom> schrieb im Newsbeitrag
news:3d627fc4$1@news.povray.org...
Thanks! though i fear that the rendertime increases as the clouds get more
detailed
and higher res.
> descent.
Yeah, that would be a possible use of it, but for greater distances, e.g from
space, one probably had to blend into an other method, i think.
I plan to make the clouds look more realistic and detailed and to write a
macro around it for easier handling (like in Jaime Vives Piqueres' stsky.inc),
more different cloud-types (cirrus, stratus, cumulus) for simultaneous use,
improved atmosphere (best would be with physically correct color-gradients
for sunsets and such..) and support for sphere-shaped atmospheres for planets
(currently it's an endless plane).
Quite some work before me =) (This could take some time...)
At the moment the media-density pattern for the clouds and the right
absorbtion
and lighting gives me headaches.. hopefully i'll get it right soon.
>                   == John ==
Greetings,
Thies
Date: 20 Aug 2002 17:00:53
Message: <3d62ae05@news.povray.org>
If you do all that :-) I can wrap it up into a plug in for Moray.
                  == John ==
news:3d62889a$1@news.povray.org...
> detailed
> and higher res.
to
that
> > descent.
from
stsky.inc),
use,
planets
> absorbtion
> >                   == John ==
> Greetings,
> Thies
Date: 21 Aug 2002 21:31:18
Message: <3d643ee6@news.povray.org>
Grrr... Another DivX anim I can't view...
Pandora/Scott Hill/[::O:M:C::]Scorpion
Software Engineer.
http://www.pandora-software.com
Date: 22 Aug 2002 05:56:28
Message: <3d64b54c$1@news.povray.org>
"Pandora" <pan### [at] pandora-softwarecom> schrieb im Newsbeitrag
news:3d643ee6@news.povray.org...
Thats the reason why I posted the animation as mpeg, too.
Their content is equal.
> Software Engineer.
Greetings,
Thies
Date: 4 Sep 2002 01:48:42
Message: <3d759eba$1@news.povray.org>
Could you post your latest code, please?
Grim
Date: 4 Sep 2002 07:06:38
Message: <3d75e93e@news.povray.org>
"GrimDude" <gri### [at] cox-internetcom> schrieb im Newsbeitrag
news:3d759eba$1@news.povray.org...
Sure, i had planned to post it, but i first wanted to clear it up
a bit first and do some more research to make them more realistic.
But if you are interested i'll post the current version. i have to
add though, that my current Version doesn't look as good as the
anim in this post imho.
I'll post the source in p.b.s-f and my latest anim in p.b.a
> Grim
Greetings,
Thies
