POV-Ray : Newsgroups : povray.binaries.animations : Flowing particles again! ( 608 kbu ) Server Time
27 Nov 2026 16:30:29 EST (-0500)
  Flowing particles again! ( 608 kbu ) (Message 1 to 20 of 20)
Subject: Flowing particles again! ( 608 kbu )
Date: 27 May 2002 19:49:06
Message: <3cf2c5f2@news.povray.org>
My particle system has had support for flowing for quite a while (since
March 2001), but it used a rather awkward approach. If the particles
collided with a surface with a velocity higher than a certain threshold
value, they would bounce, and otherwise they would flow. This could
produce acceptable results but the method was not very good, nor easy to
use because the user had to find a fitting threshold value.
Now, based on the feedback in my latest thread in povray.advanced-users,
I have changed my particle system to use a different collision method,
which unifies bouncing and flowing into a single simple model. So far,
it seems to work very well. Here's an animation I made with it. Hope you
like it. :)
(The reason that a few of the particles disappear is that I didn't set
their lifespan to be very high.)
And yes, I know, I should use more and smaller particles... ;)
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated May 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Download 'flownew.mpg' (609 KB)
Subject: Re: Flowing particles again! ( 608 kbu )
Date: 27 May 2002 20:25:22
Message: <3CF2CE8F.F7430E35@yahoo.com.au>
I took this sort of approach in my particle system too, and it works. My
particles only ever bounce, never slide or roll (though they can have very
shallow bounces which makes them look like they are sliding). I don't think that
this will model friction with any great accuracy, which is a drawback.
Is there a noticable speed difference between the two methods?
MJL
Date: 27 May 2002 23:45:19
Message: <3cf2fd4f$1@news.povray.org>
Verrrry nice. Set it up with more particles so we can see what the liquid
really looks like, 'cause i bet it'll be cool =)
(BTW, i assume this is a bunch of blob components scaled in a certain
direction?)
 - Slime
[ http://www.slimeland.com/ ]
Date: 28 May 2002 05:45:20
Message: <3cf351b0$1@news.povray.org>
> My particles only ever bounce, never slide or roll (though they can
> have very shallow bounces which makes them look like they are
> sliding). I don't think that this will model friction with any great
I think that rather quickly the particles will begin to bounce in every
calculation step because the bounces become so small.
The problem is that while the particles bounce, a certain energy loss
should happen per bounce, but when they slide, the energy loss should
happen not per bounce but per time unit, so that the friction is the
same no matter if many or few calculation steps are used. But when there
is no distinction between bouncing and sliding, it can be difficult to
handle. Maybe some fixed threshold based on the incoming angle could be
used, so that when it is very small the particle is considered to be
sliding?
I haven't compared, but I don't think the difference is very big. The
amount of calculations is much the same as before, so I don't know if
the new method is slower or faster.
Rune
Date: 28 May 2002 05:45:22
Message: <3cf351b2@news.povray.org>
> liquid really looks like, 'cause i bet it'll be cool =)
I think it's much the same, but I'm rendering with more particles now.
> scaled in a certain direction?)
Yep! Scaled longer in the direction of movement. It's not very
realistic, but it resembles motion blur a little. :)
Rune
Subject: With 5 times the particles ( 608 kbu again )
Date: 28 May 2002 07:40:14
Message: <3cf36c9e@news.povray.org>
Here's the same animation but with 6000 particles instead of 1200. On my
Athlon XP 1700 the last frame took 10 seconds to parse and the total
parse time for the 120 frames were 20 minutes. (Note to self: There's
somthing wrong. This means that all the frames took 10 seconds to parse
each, but the first frames should be much faster because of the fewer
active particles. Something to investigate.)
The total time for parsing plus rendering was 3 hours.
Rune
Download 'flownew2.mpg' (609 KB)
Date: 28 May 2002 07:47:00
Message: <3CF36E34.6175906B@gmx.de>
It looks good, but i think more important than the number of particles
would be cohesive and adhesive forces, of course modeling these would
result in an extreme slowdown.
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Subject: Re: With 5 times the particles ( 608 kbu again )
Date: 28 May 2002 10:51:49
Message: <3cf39985$1@news.povray.org>
> my Athlon XP 1700 the last frame took 10 seconds to parse and the
> total parse time for the 120 frames were 20 minutes. (Note to self:
There's
> parse each, but the first frames should be much faster because of the
> fewer active particles. Something to investigate.)
looks mcuh better, especially the first 'splash', how about an over nighter
with 120000 :P
PGP Public Key
Date: 28 May 2002 14:03:26
Message: <3cf3c66e@news.povray.org>
Thanks!
> how about an over nighter with 120000 :P
Sure, I'll send you the scene files... ;)
Rune
Date: 28 May 2002 18:36:40
Message: <3cf40678$1@news.povray.org>
Better, but it still looks a little flawed. You know what might be an
interesting thing to do? Give the blob's strengths that are less than the
threshold. That way, when blobs go off by themselves, they'll be invisible,
but the only place you'll see liquid is where there's a significant amount
of it in one place.
 - Slime
Date: 28 May 2002 20:09:34
Message: <3cf41c3e@news.povray.org>
Amazing. Could you do a waterfall with lots of tiny particles? I'd really
like to see something like that. :)
Date: 28 May 2002 20:19:15
Message: <3cf41e83@news.povray.org>
Question: have you been able to code a "filling" algorithm? So you could
pour particles into a container and have the level of the liquid rise
proportionately?
Date: 29 May 2002 11:56:11
Message: <3cf4fa1b@news.povray.org>
> particles would be cohesive and adhesive forces, of course
> modeling these would result in an extreme slowdown.
This is from an FAQ that comes with my particle system documentation:
Can I get the particles to interact with each other?
No. This particle system does not support particle interaction. It would
be very difficult to implement in a satisfying way in a system aimed at
so different uses as this system is. Particle interaction is better
suited for more specialized systems that are aimed at specific goals,
like for example simulating liquids. Besides, particle interaction would
not be compatible with all features of this particle system, such as
cyclic animation.
Rune
Date: 29 May 2002 11:56:12
Message: <3cf4fa1c@news.povray.org>
> tiny particles? I'd really like to see something
> like that. :)
Depending on your definition of "tiny", yes I could do that... :)
You could also do it yourself if you want to be a beta tester of the
system...
Rune
Date: 29 May 2002 11:56:13
Message: <3cf4fa1d@news.povray.org>
> algorithm? So you could pour particles into a
> proportionately?
Hehe, this is from an FAQ I wrote which is included in the documentation
for the particle system:
Why can't I fill an object with particles, for example a glass of water?
See the next question.
cyclic animation.
Rune
Date: 29 May 2002 11:56:15
Message: <3cf4fa1f@news.povray.org>
Slime wrote:
> You know what might be an interesting thing to do?
> threshold.
Interesting? Yes.
But it would require a very high amount of particles, of which some
won't even make a difference.
Still, I may try it out sometime... :)
Rune
Date: 29 May 2002 12:09:13
Message: <3CF4FD29.874D4203@gmx.de>
Of course.  You have mentioned multiple times that you don't want to
include inter particle forces in your system, but as you also said this
would be quite essential for simulating liquids.
BTW, adhesion could be modelled without interacting particles, maybe it's
worth trying.
Date: 29 May 2002 18:27:37
Message: <3cf555d9@news.povray.org>
Yay! :)
> system...
As much as I would love to do that, I just don't have the time any more,
buddy. :( I haven't poved in quite a while... :_(
Date: 29 May 2002 18:29:55
Message: <3cf55663@news.povray.org>
> documentation for the particle system:
<snip>
Aw. :( Too bad. I was thinking of something "simple" like keeping each
particle outside of the radius of other particles. That should do the
trick... but I guess it would be slow.
Date: 29 May 2002 18:36:33
Message: <3cf557f1$1@news.povray.org>
might take a little longer than all night on my p3-650, send away :)
PGP Public Key
