It's an amazing accomplishment.
I'm "bothered" by the ball hitting the floor and then bouncing clear out of
the tub.
Perhaps you really mean viscosity rather than surf tension?
Have you seen Stoke's Law?
http://www.science.ubc.ca/~geol256/notes/ch7_sedmov_intro.html
http://www.phys.virginia.edu/classes/152.mf1i.spring02/Stokes_Law.htm
"Christoph Hormann" <chr### [at] gmx de> wrote in message
news:3CE291FC.E1C0909C@gmx.de...
> The second one is with balls lighter than water (800 kg/m^3), the balls
> floating leads to quite some problems as you can see. The water
> disturbance, although speed dependant meanwhile, is still too strong and
> there is no good representation for water surface tension.
> Does anyone know a good method for modeling water surface tension? I right
> now only use a simple model that slows down the balls according to the
> energy required for increasing the (flat) surface area, but there probably
> are other important effects that are not covered by this.
> Apart from that i added realistic calculation of drag in water and air, i
> also modeled friction during the environment collisions, but without
> rotation this does not really improve realism much. And the animations
> are in real time now.
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
> Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
See also:
http://sis.agr.gc.ca/cansis/glossary/stokes_law.html
and what I mean is that your viscosity is way too low.
Thank you.
> the tub.
No, i mean surface tension. Drag is already modelled correctly although i
was surprised by the effect not being very strong too. I use a kinematic
viscosity of 1e-6 m^2/s which seems a reasonable value for water. Maybe i
should change to some kind of oil...
About that ball: don't forget the balls in that animation are fairly
light, the surface tension effect is fairly strong in means of bodies
sticking to the surface in such situations. Without it the balls are
simply jumping back.
Yes, this is what i use.
> See also:
That page does not give a value for water, but a formula for terminal
velocity isn't useful anyway since buoyancy prevents the balls from
sinking.
I have my value from:
http://scienceworld.wolfram.com/physics/KinematicViscosity.html
Its really strange that in #3 the balls in the water lose energy much
slower than the ones on the right side...
Lutz-Peter
news:3CE29CC1.2B05A590@gmx.de...
But it:
1) hits the bottom: suggesting heavy density
2) bounces right out: suggesting such low density that it gets a huge
boost from bouyancy.
When the looks don't match expectations of reality, change your parameters.
If you're not applying the drag instantaneously but rather frame by frame,
you lose the 'real' effect of the forces on your particle!
> But it:
No, just high kinetic energy.
The model should be changed in that case. Could be that stronger drag in
water is a convenient model for surface tension.
The drag is part of the movement equation just like all other forces.
Even cooler. :) Great work so far. Good luck with the surface tension
physics.
You have to take into account that due to buoyancy the influence of
gravity is more than compensated under water.
Thanks!
In article <3CE2C221.AD4ABAFA@gmx.de>, chr### [at] gmx de says...
Thats why they don't sink permanently... but nevertheless they should
slow down much faster, since the (parmanent) friction of a moving ball
under water should be much higher then the one of an elastic ball
bouncing on the ground - unless it is not water but some exotic liquid
with extremely low friction (like liquid helium).
I looked at the animation again, and it seems the balls are suddently
accelerating when they go through the water surface from inside the water
to the outside. A bug perhaps?
Lutz-Peter
news:3CE2B6C2.16B9C494@gmx.de...
Acquired from a fall from such a small height??
What I meant before is if you're using textbook values for forces, but then
applying the forces frame by frame instead of some kind of integration over
time, then you will not mirror reality, and you'll have to change your
values from those in the textbook.
I am fairly sure the calculations are quite correct mathematically. Just
to clarify, i'm using 33 integration steps per frame with 0.00111 seconds
per step wich should give real time results with 30 fps.
I made another version showing better the lack of surface tension and how
drag in water works, this time without the water movement. The balls are
only slightly heavier than water.
http://www-public.tu-bs.de:8080/~y0013390/files/ball_sim4.mpg
Excellent algorithm, cool realistic setup, but I guess I'm still bothered by
how the balls move.
How about a bit deeper water and all ***stationary*** at frame 0?
I was amazed when i saw this, but the i saw a small mistake. When the balls
hit the water (or are in the water), the surface of the water should raise.
For as far as i can see it doesn't happen. The rest of the animation looks
realy good.
> I have improved the model, fixed several errors and tried different
> configurations.
> Here are two results, the first is with medium heavy balls (2000 kg/m^3)
> and contains a flaw with the water. The first ball hitting the water at
> fairly high speed does not leave a trace at all. ;-) This is fixed
> meanwhile.
> Christoph
