POV-Ray : Newsgroups : povray.binaries.animations : Re: Realflow 2 POV-Ray Server Time
12 Oct 2026 18:29:17 EDT (-0400)
  Re: Realflow 2 POV-Ray (Message 1 to 18 of 18)
Subject: Re: Realflow 2 POV-Ray
Date: 25 Apr 2002 18:26:03
Message: <3cc8827b@news.povray.org>
I'm truly impressed. I like the smooth dynamics of the final part of the big
blob, just moments before it splashes on the floor.
Amazing,
Fernando.
Date: 25 Apr 2002 20:35:50
Message: <3cc8a0e6$1@news.povray.org>
Wow.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 26 Apr 2002 08:59:48
Message: <3cc94f44$1@news.povray.org>
ye gods thats good
PGP Public Key
Date: 26 Apr 2002 15:02:17
Message: <3cc9a439$1@news.povray.org>
Ya, whatever.  My particle simulation has been able to do this for years.
Except the fluid part.  That's a nice touch.
And the lighting.  I can't do that either.
But I've been able to move the camera through a static scene before.
Happy rendering :-)
"Andrew Cocker" <big### [at] mariner9fsnetcouk> wrote in message
news:3cc86312@news.povray.org...
> Hi,
> I used Next Limit's Realflow (www.nextlimit.com). I set up my scene in
> Andy Cocker
Date: 26 Apr 2002 16:21:53
Message: <3cc9b6e1@news.povray.org>
Thankyou
"Fernando Gonzalez del Cueto" <fcu### [at] yahoocom> wrote in message
news:3cc8827b@news.povray.org...
big
> Amazing,
> Fernando.
Date: 26 Apr 2002 16:22:02
Message: <3cc9b6ea$1@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3cc8a0e6$1@news.povray.org...
> Wow.
Andy
Date: 27 Apr 2002 07:03:48
Message: <3CCA8566.6F5F2B3E@gmx.de>
Hi.
Though I do think the animation looks awesome, its, like,
well, not POV-Ray at work. I mean, you probably had an
incredible amount of work adjusting the output-file for use
to POV-Ray, and tracing it all in POV-Ray makes it
show off POVs qualities as well.
But its really something external, right?
I hope you don't take this as a bad comment, its just that
I like and appreciate hand-done work better than some
companies Plug-In for some 3D-Modelling Package like
Cinema4D or Lightwave.
Finally, it does look great...
Tim Nikias
Email: Tim### [at] gmxde
Date: 27 Apr 2002 15:25:05
Message: <3ccafb11@news.povray.org>
Well, it's rendered in POV, so it 'is' POV at work! Is it wrong to use data
from another source, and incorporated it into my scene? I do understand what
you are saying though....
Yes, it's an amazing program that simulates liquid dynamic stuff far better
than I could ever hope to, as I can't code as well as people like yourself,
who's work I greatly admire.
Not at all. Your comments are appreciated. I regarded the project as an
option for others to use an external prog should they wish to do so. BTW,
Realflow is actually a stand-alone program, not a plug-in, though it could
be argued that I used it as a plug-in for POV :-).
Granted, there are POV purists who would regard anything other than pure
hand coding to be heresy, and there are others who make use of all the tools
at their disposal, be they POSER, or MORAY or other peoples particle systems
etc.
All the best,
Andy Cocker
Date: 27 Apr 2002 19:23:03
Message: <3CCB32AF.531C5354@gmx.de>
That's good. I hoped you wouldn't misunderstand.
Why, thank you! But, and I think it isn't pointed out often enough,
it always uses time, patience and HELP to get to know enough
about POV in order to code some useful stuff (macros which
you'd reuse in other scenes, for example). And to that sort of
help you belong, too. If you'd give a little inside information about
how the data was saved...Positions by frame? That sort of stuff
is bothering me in the moment, how to keep track of mesh-vectors,
e.g. for animation, or for particle effects.
> etc.
When talking about POV-Ray, I think, its heresy to do work on
programs BASED upon POV-Ray and then SELLING it.
But I guess us POVers are gathering quiet a bunch of programmers,
so its just a question of time until some sit together and create a
free modeller which looks cool, is intuitive to use, and as
"expandable" (like macros and such) as POV-Ray itself.
Just my 2 pence worth...
See ya,
Tim Nikias
Date: 27 Apr 2002 22:23:56
Message: <3ccb5d3c@news.povray.org>
povray is JUST a render engine, nothing more nothing less. it does not
matter what you feed it for the results to be 'POV-Ray at work'.
PGP Public Key
Date: 28 Apr 2002 04:14:19
Message: <3CCBAF33.73D2B112@gmx.de>
He, I knew someone would say that...
I know. But the SDL of POV is capable of
so much and doesn't even need "outside" tools,
though the real modelling is kinda difficult,
you're right on that one.
But for animation of particle effect, like this
magnificient RealFlow animation,I just can't
find as much respect and admiration for as
someone who wrote the particle-system himself,
may it be with POV, or with C++. That's all
I meant.
Tim Nikias
Date: 28 Apr 2002 05:40:20
Message: <3ccbc384@news.povray.org>
>> not matter what you feed it for the results to be 'POV-Ray at work'.
I would be happy if the SDL was separated from the render engine, taking the
role of a compiler & feeding povray a binary scene file. (and essentially
making itself optional in the process)
> I meant.
but its the end result that counts, not how much you did/didn't struggle
reinventing the wheel. when someone looks at your image in 6 months time are
they likely to notice (or even care) that you did it the hard way?
PGP Public Key
Date: 28 Apr 2002 06:52:03
Message: <3ccbd453@news.povray.org>
> did/didn't struggle reinventing the wheel.
Of course that's not entirely true. Even if an effort doesn't matter to
others, it can still matter very much to oneself. And the experience
gained by solving a complex task oneself should not be underestimated
either. Using other people's solutions is fine if you're just after a
quick results, but if you intent to challenge yourself and learn from it
in the process, it just isn't the same to use an already existing
solution.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Apr 14)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 28 Apr 2002 08:10:05
Message: <3CCBE677.5382420B@gmx.de>
That's what I mean. If you're not able to write such programms,
I don't complain. But I think its much more awesome if someone
here can say: Look what I have done!
I mean, some complex modellers supply trees, fern, vegetation
etc. When just given a few optional floats and the programm
creates the remaining bit, how much would you appreciate the
work the User has done, rather than the programmer?
Thats what I'm after.
> solution.
> Rune
Tim Nikias
Date: 28 Apr 2002 09:06:34
Message: <3ccbf3da$1@news.povray.org>
As soon as I can find the time, I am going to attempt my own particle
system. Then I'll be able to hold my head up once more in the POV community.
Andy
Date: 28 Apr 2002 10:02:32
Message: <3CCC00D1.DC61728F@gmx.de>
Hm, just so you know:
I've made some I/O-Macs available on my homepage. Perhaps
you'd need those for a particle-system, but you can always
write your own, of course.
> Andy
And your work with RealFlow really is something neat, so no need
to keep your head down...
Tim Nikias
Date: 28 Apr 2002 16:41:14
Message: <3ccc5e6a@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3CCC00D1.DC61728F@gmx.de...
Yes, I saw, and have downloaded them (although not yet had time to play).
Will certainly be of use to me..
Andy Cocker
Date: 28 Apr 2002 18:21:36
Message: <3CCC732D.F356D395@yahoo.com.au>
Nice work!
This looks similar to some of the samples on the Realflow website. Though I've
never used it, Realflow appears to be capable of some amazing stuff, but it's
such a pity that it (a) costs more than nothing, and (b) looks like you've got to
jump through hoops to get its output into POV.
I'll stick to my own particle system, and dream of getting close to Realflow
someday :-).
MJL
