There are quite some possibilities that I want to try out with this new
technique before I make it into an include file.
Here's a test of simulated wind blowing in the grass. I think it looks
interesting, and yet something's not quite right. Any ideas?
(BTW, I'll work on improving the interaction with the two balls and their
shadows later.)
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring: http://webring.povray.co.uk
Download 'fgrass2_test3.mpg' (481 KB)
it spoils the illusion
PGP Public Key
"Rune" <run### [at] mobilixnet dk> wrote in message
news:3ca45c6d@news.povray.org...
I think the areas of little gusts are too small.
As Bill said, the wind gusts cover too small areas, also, the
actual movement is quiet to fast and jerky IMHO.
Tim Nikias
To me it looks like the grass is dancing. :)
It has the potential, but the problem is simple- the grass looks too
"constrained". Real grass would move more slowly and gracefully, and in wider
swaths. However, you have a great start on getting it to do what you want.
On reviewing it, the animation shows that the blades appear rigid and they
seem topivot from their bases. Actual grass blades bend in the middle. Is that
possible with your texture?
Cheers!
Chip Shults
> also, the actual movement is quiet to fast and jerky IMHO.
Thanks Bill and Tim, I'll try to fix that.
Rune
> the grass looks too "constrained". Real grass would
> move more slowly and gracefully, and in wider swaths.
Thanks for the tip, I'll try to fix that.
> what you want.
> blades appear rigid and they seem topivot from their
> that possible with your texture?
*thinks for one second*
Yes! :)
Rune
Weeeeell - in one way I guess it is ... if you want to be poetic! ;)
Rune
In what way?
Rune
> In what way?
the movement just looks flatter than previous anims
PGP Public Key
After watching it a few times over, it looks alot more like static
electricity making the hair on my arm move then grass blowing in the wind..
8-) I'd guess that it's becouse everything looks to be going the same way,
the same amount, all at once, without any sort of chaotic behavior..
*shrug.. That make sense?
> shadows later.)
