I've been looking at a little reference videos (real life, not holywood) and
they didn't have neither flashes nor shock waves, so I haven't added that to
the animation.
I've made the explosion less saturated and made the gravity for the dust
weaker so it fills a larger volume.
Naturally, feedback is still appreciated, only, I don't go for holywood like
effects.
Apart from experts like people in these groups, who are trained in noticing
flaws in CG effects, do you think this animation could fool anyone to think
it's real?
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
Download 'blow_up_2.mpg' (499 KB)
Rune <run### [at] mobilixnet dk> wrote in article
<3c90d136@news.povray.org>...
and
to
> the animation.
like
> effects.
noticing
think
> it's real?
Looks real good, but to be really convincing you'll need some debris, or at
least some movement in the dust/smoke giving the appearance of debris
flying through it...
Otherwise I think it's a really good explosion...especially the slow
settling of the dust/smoke...
The only way you can see shockwaves in this type of explosion is simply by
a front of movement in objects surrounding the explosion emanating out
circlewise from the explosion. The shockwave of compressed air and the
flashes come from nuclear explosions as seen in Hollywood, but also in real
life, and that just wouldn't fit this anim... (as in the building shouldn't
be standing after the explosion if it were a nuclear one)
Very nice work...
Lennard "Lenny" van Ingen
lenny_SPAMSUX_@vestingbar.nl
UIN: 87008669
In my opinion, after the initial explosion, the fire is much too high. It
actually looks more like orange smoke. So I would try to reduce the flames
and increase the black/gray smoke.
But I don't have a reference video like you do, it's just an observation.
There are several minor things I'd adjust.
As someone already mentioned, the fire trails way
too high, ever seen flames about 40 meters high
(with such a little area burning, that is)?
Again, someone mentioned debris. Create some smaller
smoketrails just flying off in several directions and coming
down, and simply make the smoke dissipate.
For a better effect, I'd say you'd have to use
more and smaller particles for the fire, the
initial fireball is really good.
And generally I'd create the camera zoom and
focal-point different. You should have it look somewhere,
suddenly move to the explosion, zoom out quickly, and
then doing the slower movements and zooming like
the camera-man is actually looking and inspecting
the scene.
Tim Nikias
Superb :)
Everyone is talking about a shockwave or flash but I think all it needs is a
little camera wobble or shake a split second after the initial explosion.
This could be attributed to the shockwave reaching the cameraman and the
reaction of the cameraman to the explosion.
Keep up the great work
Dave
Hide a few shingles just below the roof surface to make them invisible;
then when the explosion occurs, blow them back! That would really help a
lot. Just a handful would do the trick.
Cheers!
Chip Shults
> the animation.
The lack of a flash/shock wave is probably a good thing for realism then.
> it's real?
I would say not. This is probably due to a number of small things. Debris is
something others have brought up, but there are other sutble things, like black
staining from the initial explosion on the building. Some sort of orange glow
from the fireball and fire (even if it is not a brilliant flash) might help too.
Also, I think your "viewers" are crying out for some DAMAGE! After that dust
settles, I expected some sort of gaping hole.
Your efforts are superb but an explosion anim that is convincing to non-CG aware
people is a difficult challenge.
MJL
prism{0,.1,30#local I=1;#while(I<30)#local B=asc(substr(// Mark James Lewin
"#K?U_u`V[RG>3<9DGPL.0EObkcPF'",I,1))-33;<div(B,10)-4mod(B,10)+5*div(I,21)-
6>#local I=I+1;#end,-4pigment{rgb 9}rotate-x*90translate 15*z}//POV-Ray 3.5
aware
I think the opposite. There are lots of people who don't know what a
computer is. And actually most people I know have no idea what a computer is
capable of doing, so they'll think an explosion like this is terribly real.
Even I might believe it's real.
Hugo
> aware
> Hugo
People may not know what a computer is capable of doing, but most are able to
see if something is "not quite right", even if they cannot tell you exactly what
is causing this feeling (and these things are often subtle and difficult to
include in CG).
Even the best modelling of a scene can look generated or fake in some way,
but add area_lights, radiosity, and perhaps some focal blur, and the illusion of
reality is increased because the some of the things that are "not quite right"
(eg. sharp shadows, unnatural shading) are being eliminated.
MJL
noticing
think
> it's real?
Originally, I thought you had taken a real video from some newscast or
something and put your explosion animation on top of it. Unfortunately, the
explosion itself still looks sort of fake; it's too easy to see that you're
using separate objects containing smoke and fire and moving them around.
Try also moving the "helicopter" in some direction a little bit, and make
the camera movement smoother (looks linearly interpolated right now).
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
> the scene.
Heh heh, yeah, you don't want people to get suspicious and say "so how did
you know you had to film that exact area right at that time?"
- Slime
On Thu, 14 Mar 2002 17:27:54 +0100, "Rune"
>it's real?
Maybe if you make the smoke denser so that it hides the lack of
debris, make the flames lower and brighter and make them illuminate
the smoke as well. It's already really convincing.
Oh... and rip a soundtrack off the news <g>
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
I agree with the majority about the debris. But the main thing, in my eyes,
that makes this obviously fake is the -huge- stream of fire -instantly- erupting
from the explosion. We're talking a brick building here, right? Where on earth
is all that fire coming from? Tone it down to barely there, ie -really- short
flames barely visible, that don't appear instantly, and you've got realism.
-Law
> the animation.
> effects.
> it's real?
> Rune
> 3D images and anims, include files, tutorials and more:
> blow_up_2.mpg Type: Wmplayer File (video/mpg)
> Encoding: x-uuencode
> I don't go for holywood like effects.
Party-pooper! :P
noticing
think
> it's real?
Sound would really help. Also footage of a real building, not a maquette,
would help complete the illusion.
Will be difficult to find fitting sound I think, but I'll try.
What is a maquette?
Rune
I'll try to add a little debris-looking stuff.
> But the main thing, in my eyes, that makes this
> erupting from the explosion.
You're right, I'll decrease the amount and height of the fire.
Rune
> from some newscast or something and put your explosion
Well, that's good too. :)
It's a scanned photo of a building.
> Unfortunately, the explosion itself still looks sort
> of fake; it's too easy to see that you're using separate
That's one of the things that's diffiult to prevent, but I'll do my best.
> little bit
That's impossible, as the photo of the building is 2d and thus can only be
seen from one angle. Besides, you said just before that you initially
thought it was from a real video, which I would think indicates that it's
convincing enough... :)
> and make the camera movement smoother (looks linearly
Only the zooming and that's intentional because I think linear zooming is
quite common, though not in professional work. But I could try some smoother
zooming in the next version for a change.
Rune
"Tim Nikias" wrote:
> the fire trails way too high, ever seen flames
> about 40 meters high (with such a little area
> burning, that is)?
You're right, I'll try to fix that.
That too.
> somewhere, suddenly move to the explosion, zoom
> out quickly, and then doing the slower movements
> and zooming like the camera-man is actually
> looking and inspecting the scene.
The current "path" was just a test. Thanks for the suggestion, I'll see what
I can do. :)
Rune
Thanks for the feedback; I agree with you.
Rune
that orange part shoots too high with pieces of it too large to
the scale of the shot. Does that make any sense? I think it
also moves too fase for that scale.
The dust effect is nice.
-peter
Current obsession: "Ballet pour ma fille."
http://www.applesnake.net
You can do it! :)
> What is a maquette?
Those little pretend buildings that architects make out of balsa wood,
plastic, etc. ... like the one in your video... right?
"Tony[B]" wrote:
> > What is a maquette?
> out of balsa wood, plastic, etc. ... like the one in
Not quite right.
The image in the animation is a photo of a real building. Yes, those are
real trees and that's a real car there. And the building is quite real too;
I go there every day and it does look like that.
Sometimes you just demand too much realism from nature... ;)
Rune
POV-Ray Ring: http://webring.povray.co.uk
