POV-Ray : Newsgroups : povray.binaries.animations : Particle System Explosion Server Time
12 Oct 2026 20:25:18 EDT (-0400)
  Particle System Explosion (Message 1 to 27 of 27)
Subject: Particle System Explosion
Date: 13 Feb 2002 11:35:44
Message: <3c6a95e0@news.povray.org>
I've been working on a way to use my particle system to create explosions.
This is the result so far. It took a long while to tweak it to look like
this, and by now I think I've worked so much on it that I can't judge it
myself anymore; I need outside opinions. So what do you think?
The animation is 100 frames long and was rendered at 320x240 AA 0.3 on a
1GHz computer. Try to guess how long it took.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Download 'explode.mpg' (503 KB)
Subject: Re: Particle System Explosion
Date: 13 Feb 2002 12:10:52
Message: <3c6a9e1c$1@news.povray.org>
Hi Rune,
I think the actual explosion/flames/smoke look perfect, *except* for the way
that the building shows through the explosion as solid lines, similar to
what happens in many games (which I think looks terrible). Not sure how this
could be avoided though.
All the best,
Andy
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c6a95e0@news.povray.org...
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 13 Feb 2002 15:29:04
Message: <3c6acc90@news.povray.org>
Looks quite nice, but I'd suggest using isosurfaces or dense media instead to
get a more 3D feel. At the moment it looks a lot like it's just flat polygons
facing the camera, which doesn't really suit pov's abilities, it's only the
early stages of the explosion that you can see the particles are actually media
(and even then I had to pause the animation to be sure).
I'd guess about 5 minutes per frame.... if it is pov...
Actually now I look closer I'm not convinced it is ray traced! Where's the
shadows? Is this just a real-time animation using a pov rendered explosion
texture on each particle?
(apologies if it isn't, but this is just how it looks to me)
Tek
http://www.evilsuperbrain.com
Date: 13 Feb 2002 16:15:33
Message: <3c6ad775@news.povray.org>
Thanks!
> *except* for the way that the building shows through the
> explosion as solid lines, similar to what happens in many
Hmm yes... :(
Rune
Date: 13 Feb 2002 16:15:36
Message: <3c6ad778@news.povray.org>
> dense media instead to get a more 3D feel.
Isosurfaces have sharp edges and are not easy to use to create flame and
smoke IMO.
> polygons facing the camera, which doesn't really
Heh, it looks like flat polygons facing the camera? :p
> it's only the early stages of the explosion that you
> can see the particles are actually media (and even
So it first looked like flat textured polygons, but after a closer
inspection you became sure that it was media after all?
> Where's the shadows?
Arg, you caught me!
> explosion texture on each particle?
No, it's POV-Ray all right. But it *is* textured discs facing the camera.
Ok, so it's not a replacement for good old media as your observations
reveal...
> > at 320x240 AA 0.3 on a 1GHz computer. Try to guess
> > how long it took.
But here's the positive side. It's only 9 seconds per frame, for a total of
15 minutes for the whole animation. Not exactly real-time as you thought,
but quite fast for a POV-Ray animation.
Rune
Date: 13 Feb 2002 17:11:21
Message: <3C6AE427.A8FF1A57@yahoo.com.au>
I like the fire after the explosion, but the way the mushroom cloud disperses
looks a bit odd to me. Maybe if the column of smoke from the fire was thicker
just after the explosion, and dwindled down, it may look better.
My guess is 1.5 - 2 hrs. It really depends on how many particles you have, and
whether you are using media or not. I suspect this is not media (discs perhaps?)
just because, if you make Al chew gum whilst walking, you would surely make
absorbing smoke which would leave a shadow :-)
MJL
light_source{9*(y#macro A(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)
#local V=asc(substr(B,I,1))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{rgb
y}rotate-<90,R>translate-T}#end-z)rgb 9}A(14",6;MWmhryXN3,"60<15,0,8>)box{-99(x+
z)*99pigment{rgb 1}}fog{distance 11}camera{location(y-z)*25look_at 0}A(8"6hiAG=6
"-60x*-10)A(16"/.@VZno=<PLA89/"0x*5) // MJL
Date: 13 Feb 2002 17:14:48
Message: <3c6ae558@news.povray.org>
> reveal...
Aha! I was consfused by that but now I see it.
That would be a very effective technique for distant explosions or previewing an
animation, but I'd like to see how good it would look with media!
BTW, if you want to get shadows you could get a second set of discs facing the
light source and use the no_image tag :)
Tek
Rune <run### [at] mobilixnetdk> wrote in message
news:3c6ad778@news.povray.org...
> smoke IMO.
> Arg, you caught me!
> reveal...
> > > how long it took.
> Rune
Date: 13 Feb 2002 17:29:05
Message: <3C6AE8A7.38991E0@gmx.de>
It does look really good, but by what I've seen your particle-system
do before, I was rather disappointed.
Thats just the case when you normally post animations that get
comments like "Jesus! I need to dig into POV a LOT more!" ;-)
As others have mentioned already, it looks 3D-Game-esque,
not POV-RAY. I mean, hey? What did you expect? We're
talking about the one, the only, the freeware raytracer
POV-Ray! Doh!  ;-)
Okay, I do like POV-Ray a lot...
And you post an animation just as I'm about to take the
next two non-computer weeks to work through a printed
version of my Particle-System, and finally get it finished,
now that my IRTC-Entry (my first!) has been sent in...
Hooya! (Starship Troopers Battle Cry)
See ya, and I'll just hope you'll post a media-version in a few
days (hey, you've got two weeks, then I'll be back!) ;-)
Tim Nikias
Date: 13 Feb 2002 17:30:12
Message: <3C6AE890.2D0B36D3@yahoo.com.au>
Just saw your reply to Tek; so they are discs. To make them cast shadows, you
could use a smart combination of light groups, discs and no_image / no_shadow to
make a shadow effect. Keep your camera oriented discs for visuals, and use
light_source oriented discs for shadows.
MJL
Date: 13 Feb 2002 17:31:59
Message: <3C6AE8FF.673EE066@yahoo.com.au>
I am too slow today... (see my 2nd reply to Rune)
Date: 13 Feb 2002 18:01:13
Message: <3c6af039@news.povray.org>
> mushroom cloud disperses looks a bit odd to me. Maybe
> if the column of smoke from the fire was thicker just
Thanks for the tip, I'll see what I can do.
Rune
Date: 13 Feb 2002 18:01:16
Message: <3c6af03c$1@news.povray.org>
> them cast shadows, you could use a smart combination
> of light groups, discs and no_image / no_shadow to make
> a shadow effect.
I know. I could even make it work with multiple light sources by using
bounded_by tricks. However, while the smoke should cast shadows of course, I
don't know much about how bright fire and explosions cast shadows, if any.
Rune
Date: 13 Feb 2002 18:01:18
Message: <3c6af03e@news.povray.org>
> your particle-system do before, I was rather disappointed.
Hmm. I had worked out a system with discs where I was actually under the
impression that I wouldn't have been able to tell the difference myself,
apart from the shadows and the places where the particles are intersecting
with objects. But everyone have very quickly spotted the shortcomings of the
system... I wonder if I had used a non-moving camera if it would have been
as easy to tell?
> 3D-Game-esque, not POV-RAY.
Apard from the shadows, I'd like to know how to make the fire and smoke look
better if anyone have any hints. As i said, I've worked on it for a long
time and am kind of unable to see if it looks wrong, and why.
A printed version of your particle system??? I have no idea what you're
talking about... :)
> and finally get it finished, now that my IRTC-Entry
Good luck with both!
> in a few days (hey, you've got two weeks, then I'll be
> back!) ;-)
Well, I have reasons not to work on a media version right now. Basically, it
will delay the release of my system. I just wanted to have *some* kind of
explosion included in the first version of the package. :)
Rune
Date: 13 Feb 2002 20:30:23
Message: <3c6b132f$1@news.povray.org>
> > a shadow effect.
Ah, well if you did them with media and radiosity you could find out!
...if you don't mind waiting a week for each frame to render :)
Or you could use this as an excuse to watch lots of movies with big explosions,
for research purposes of course.
Tek
Date: 13 Feb 2002 20:38:54
Message: <3c6b152e@news.povray.org>
Well the thing that really makes them look computer game-y is the fact that you
can see lots of seperate identical textures. The big boom is okay (except where
it intersects the box object), but the trail of fire afterwards has so few
particles that they are obviously independent objects. BTW, this would still
look wrong using media!
Plus their motion is such that it gives away where the seperate particles are.
i.e. all the fire is either following one motion or another, none of it is
inbetween.
I suggest you just use more particles, so they overlap more and clues that
they're seperate are hidden better. Maybe also use a variety of textures,
computer games never do that due to a lack of VRAM.
Tek
news:3c6af03e@news.povray.org...
> as easy to tell?
> talking about... :)
> > back!) ;-)
> Rune
Date: 13 Feb 2002 23:12:37
Message: <3c6b3935@news.povray.org>
Nice! Reminds me of Mechwarrior 2, only this looks better. Hope you can
figure out the shadow-casting soon. :)
Date: 14 Feb 2002 17:46:48
Message: <3c6c3e58@news.povray.org>
"Mark James Lewin" <m_j### [at] yahoocomau> wrote in message
news:3C6AE427.A8FF1A57@yahoo.com.au...
and
perhaps?)
make
I suppose your next trick, Rune, will be Al walking along, chewing a fat
smoking joke exploding-cigar...
Mark Hanford
http://www.mrhanford.com/povray
Date: 14 Feb 2002 17:57:08
Message: <3C6C40BF.638CDE73@gmx.de>
> as easy to tell?
Probably not, but as someone mentioned already, exact copies of the
same texture are pretty well recognizable...
One addition would be the rotation of the textures, but that won't work with
discs... If you imagine the great initial fireball as a torus, its easy to
explain:
the inner sides roll outwards and up, the outer sides inward an down...
> talking about... :)
I wanted to take my PRINTER and PRINT the PARTICLE SYSTEM to
go it through BY HAND and look at DECLARATIONS and ALGORITHMS
to find optimisation possibilities (putting five sheets of paper with different
sections
aside of each other isn't that easy to be done on a computer)...
Heh, thinking of it, it's like looking at a hard-coded version... ;-)
Aha. So we're approacing a particle rush? If you post yours, and it gets
popular,
mine won't have a chance... Ah, well.
Tim Nikias
Date: 14 Feb 2002 19:04:51
Message: <3c6c50a3@news.povray.org>
> of the same texture are pretty well recognizable...
Let me straighten this out. I'm *not* using exact copies of the textures!
I'm not sure where you get the exact copies from that you seem to spot in
the animation... ;)
And no, they're not image_maps but procuderal textures.
> that won't work with discs... If you imagine the great
> initial fireball as a torus, its easy to explain:
> inward an down...
I have thought about this myself, but it would be very difficult to
implement as the individual particles don't know if they're on the "inside"
or the "outside".
All I could do would be to apply some random rotation to each particle, but
I'm sure that wouldn't look very good.
> to go it through BY HAND and look at DECLARATIONS and
> ALGORITHMS to find optimisation possibilities
Oh so you mean the *code* of your particle system! Why didn't you just say
that. ;)
The term "particle system" covers IMO everything including the concept, the
theories involved, the demo scenes, the code, the documentation, the
resulting images and animations, etc., so I was confused when you talked
about printing out "your particle system".
BTW, I'd never be able to work with code in printed form...
Not a rush, I've just decided not to implement too many new things and
consentrate on getting the first version ready for release instead.
> If you post yours, and it gets popular, mine won't
Well, I for one would probably use it if it's flexible enough. Does it allow
me to get access to a particular particle's location at any time? For
example I'd like to know particle X's location at clock=0.6 even though the
clock of the scene is currently only at 0.3. That's not possible with my
system but I imagine it could be possible with yours because of the way it
works.
You see, if that's possible, i could use each particle in your system as an
emitter in my own system and that way get some truely interesting effects.
:D
Rune
Date: 14 Feb 2002 19:04:55
Message: <3c6c50a7@news.povray.org>
> chewing a fat smoking joke exploding-cigar...
Um, no... (he doesn't smoke.)
Actually, I'd rather have AL blown away by a nearby explosion - without
getting seriously hurt of course.
Rune
Date: 14 Feb 2002 20:12:56
Message: <3c6c6098$1@news.povray.org>
> game-y is the fact that you can see lots of seperate
> identical textures.
I'm not sure what you mean by that. Of course all the textures are made from
the same pattern, but unique turbulence is added for each particle, so
they're not identical. Maybe I should also vary the colors a bit?
> seperate particles are. i.e. all the fire is either
> following one motion or another, none of it is inbetween.
I don't understand this either. I don't have a set of predefined paths, all
the particles react the same way on (inverse) gravity and wind, and besides
that some randomness is added.
I tried using more particles, but it just made the fire and smoke much more
blurred, because more textures were averaged...
Rune
Date: 14 Feb 2002 20:13:00
Message: <3c6c609c@news.povray.org>
Thanks! Never tried Mechwarrior 2 though...
> Hope you can figure out the shadow-casting soon. :)
Should be ready in the next animation!
Rune
Date: 15 Feb 2002 07:06:19
Message: <3C6CF9B0.228C2AE9@namtar.qub.ac.uk>
...whilst doing the Dirty Bird[tm]...
signature{
Date: 15 Feb 2002 15:52:58
Message: <3c6d752a@news.povray.org>
> > identical textures.
Are they? Oh, I must be wrong about that!
Okay, well looking at it paused it's harder to spot the individual particles
than I thought, the only hint is that each texture has fairly uniform density
across it, so where they overlap that density is doubled and you can spot the
individual bits. If the texture was more transparent towards the edges then it
would hide this effect better.
I don't mean a pre-defined path, I just mean each particle moves seperately, so
where two particles move relative to each other you can see that they're
seperate. You see a parallax effect that immediately gives away the fact that
they're seperate.
That sounds like it would probably make the individual particles harder to see
BTW, it's still a very nice effect, and anything better would take many times
the render time.
Tek
Date: 16 Feb 2002 16:19:20
Message: <3C6ECCD6.8015B90C@gmx.de>
Why not? It's like reading a book... Well, okay, like reading ten
related books alongside each other - but hey, we're all up
to multi-tasking, or not? ;)
Well, then you'll also have to keep backward-compability in mind... Not
that I'd think you'd forget that, but just in case you need a reminder...
> works.
> :D
You know, another interesting thingy about the way my system works:
I can calculate one set of particles, save their data, reload it as
emitters for another set of particles... But since my system can't keep
track of existant particles constantly (it would be very parsing and
calculating intensive, to know for each particle, which particle has caused
it, and when...), yours and mine could make a very good combination...
Perhaps when yours is out, we can have a combined look at how we can
make them fit together well and easy?
Tim Nikias
Date: 16 Feb 2002 18:31:39
Message: <3c6eebdb@news.povray.org>
One things is reading it - making changes to it is a different matter. I
wouldn't be able to keep track on lots of small changes without coding them
little by little and testing that they work on the way.
> in mind...
Only if I want to... I think it'll cause too many problems to really ensure
backwards compatibility.
> my system works: I can calculate one set of particles,
> save their data
One time for every frame, or once and for all for the entire animation?
> how we can make them fit together well and easy?
We'll see - I'm pretty sure the interfaces are completely different from
each other.
Rune
Date: 16 Feb 2002 19:59:18
Message: <3C6F0065.7644A36A@gmx.de>
I wasn't really thinking about making major changes, just some
simplifications on certain algorithms, or variable-usage (there are
tons of them right now, and I probably don't need THAT many)
to save some RAM. And testing afterwards is of course a must.
I could go both ways, either for every frame, or once and for all,
though the emitting-objects wouldn't move then (I can only save
a certain time-frame, not actual animations, at least not yet)
> each other.
I agree to that, but nontheless I could look at your system in order
to make my macros fit yours, and perhaps vice versa? Just that
someone could put your system in a macro of mine, and my
system in a macro of yours (in case your actually supporting
that many macros, I've made it possible for EVERYTHING to
be user-defined with a macro... but I'm not sure if that was
a good idea...)
When I'm back from my civil service course, I'll probably work
on some images and the particle system (docs, algorithms, examples),
so expect some funky (and crappy) ideas when I'm back... ;-)
Tim Nikias
