POV-Ray : Newsgroups : povray.binaries.animations : Crazy cloth HA HA HA MPG1 Server Time
27 Nov 2026 17:12:31 EST (-0500)
  Crazy cloth HA HA HA MPG1 (Message 1 to 18 of 18)
Subject: Crazy cloth HA HA HA MPG1
Date: 19 Jan 2002 21:42:21
Message: <3c4a2e8d@news.povray.org>
I was in the quest to program the perfect algorithm, but.... I CREATED A
MONSTER!!!
ha ha ha...
Before, my algorithm didn't consider the conservation of the cloth's
velocity (in each vertex of the mesh), and I thought it should, and I
rewrote major parts of my code to allow this. But obviously I did something
wrong, because this looks AWFUL!
I hope I can be easily fixed...
Fernando.
Download 'newcloth12_telaloca.m1v.mpg' (210 KB)
Subject: Re: Crazy cloth HA HA HA MPG1
Date: 19 Jan 2002 22:35:35
Message: <3c4a3b07$1@news.povray.org>
something
Conservation of velocity? Perhaps this has something to do with this type of
simulation, which I know nothing about, but velocity isn't conserved in the
real world, momentum is though. Or perhaps I should shutup before I make a
fool of myself?:-)
Date: 19 Jan 2002 23:08:48
Message: <3c4a42d0$1@news.povray.org>
LoooooooL
This is a really funny one he he he :))
A nervous cloth ;))
Best regards
Date: 19 Jan 2002 23:48:27
Message: <3c4a4c1b$1@news.povray.org>
That's some wind.
It may not be what you were aiming for, but I find that it's still impressive
in that the integrity of the fabric is maintained, and also, in all its
writhing,
it doesn't pass through itself.
Tom Bates
#macro T(B)#local m=mod(B,8);#local B=floor(B/8);m#end#local C=126981491245202;#
local D=115694168992822;sphere_sweep{b_spline 16#local i=0;#while(i<16)<T(C)-4,T
(D)-4,10-i/10>.1#local i=i+1;#end pigment{rgb 1}}light_source{-10,1} file://Tom
Bates
Date: 20 Jan 2002 00:29:39
Message: <3c4a55c3@news.povray.org>
It's as if it kept all the energy it had instead of it fazing out. I must
also say that I'm impressed at the lack of cross-through.
Date: 20 Jan 2002 01:11:37
Message: <3c4a5f99@news.povray.org>
"Tony[B]" <ben### [at] catholicorg> wrote in message
news:3c4a55c3@news.povray.org...
Well... I'm sorry to dissapoint you but it's pure luck that it doesn't
appear to cross-through, as the algorithm doesn't have those kind of
routines...
I believe it must not be easy to implement that, and would increase the
order of complexity very very much, as it would have to check for
intersections.
Sorry :(
Fernando.
Date: 20 Jan 2002 01:45:43
Message: <3c4a6797$1@news.povray.org>
"Thomas Lake" <tla### [at] homecom> wrote in message
news:3c4a3b07$1@news.povray.org...
> something
of
the
> fool of myself?:-)
I think I did not describe it properly: I'm really not trying to conserve
the velocity. My first algorithm did an estimation of the motion directly
from the forces, not with the velocities. I thought that having explicitly
the velocities would improve the behaviour of the cloth.
I'm still working on this... I'm not sure if it will be helpful.
Thanks for your comments,
Fernando.
Date: 20 Jan 2002 04:55:51
Message: <im4l4ugpvb45knh0ruj5b3p8s191lsk3gv@4ax.com>
On Sat, 19 Jan 2002 20:41:38 -0600, Fernando González del Cueto
Err... it is energy that has to be conserved, and momentum, not
velocity. Of course velocity will be conserved if there are no
external forces, but then the animation will be rather dull, won't it
If I were you, I'd use some sort of feedback to keep the energy and
momentum of the system from growing beyond what is expected from the
influence of external forces. You will thus eliminate most of the
discrete integration errors, which are especially painful in the
forward Euler, which I believe you use (everyone does on their first
try at cloths :) )
Peter Popov ICQ : 15002700
Date: 20 Jan 2002 06:14:31
Message: <3c4aa697$1@news.povray.org>
> MONSTER!!!
> ha ha ha...
something
I hope so - it looks so good to start with, very fluid.
PGP Public Key
Date: 20 Jan 2002 07:24:12
Message: <3c4ab6ec$1@news.povray.org>
*lool*
That's indeed a funny one.
For me, it looks like it repells from itself and the surface without any
loss of energy. It has no inner friction anymore, similar to a fluid. Maybe
a little bit of "rubber-cloth" *g*
regards
SY
Date: 20 Jan 2002 12:59:23
Message: <3c4b057b@news.povray.org>
"Peter Popov" <pet### [at] vipbg> wrote in message
news:im4l4ugpvb45knh0ruj5b3p8s191lsk3gv@4ax.com...
Hi Peter,
Tomas Lake made a similar observation, so I'm reposting my answer:
I did not expressed myself properly: I'm really not trying to conserve
After much struggling with the results obtained from this theory I believe I
will return to my old style simulation.
> try at cloths :) )
Yes, I'm using forward Euler. Yesterday I gave a big thought on how to use
other solving methods, but I haven't implemented them. I hope I can find
some time to test these new ideas.
Thanks for your comments!
Fernando.
Date: 20 Jan 2002 17:24:15
Message: <3c4b438f@news.povray.org>
Okay, i don't even know what forward Euler is, but i'll give my intuitive
two cents and risk sounding like an idiot.  What if you multiplied the
velocity of the cloth by a constant x such that 0>x>1 every iteration, or
when the cloth is transmitting energy to itself, so to speak, you did the
same sort of thing?  It looks like it's retaining it all, never coming to
rest.  The initial rippling does have some realism to it, in a way that the
previous animations don't, maybe a fix of that sort would be an effective
middleground?.  in any case, it looks a whole lot like water, which is very
neat.  i like it, realistic or not.
"Fernando González del Cueto" <fcu### [at] yahoocom> wrote in message
news:3c4a2e8d@news.povray.org...
> MONSTER!!!
> ha ha ha...
something
> Fernando.
Date: 20 Jan 2002 18:24:42
Message: <b7km4ucpbklpu7cgfadlbl7mfbj88e21b5@4ax.com>
On Sun, 20 Jan 2002 11:59:49 -0600, Fernando González del Cueto
Try implicit Euler first, as its simplicity is next to that of the
explicit (forward) Euler method, though it's much more stable. I don't
know how this will affect cloths, I know it affects solids in a
realistic way, i.e. avoids unrealistic stress concentrations.
Date: 21 Jan 2002 01:21:01
Message: <3c4bb34d@news.povray.org>
Hi Michael,
I'm glad you liked it, even though it was quite bizarre.
About your suggestion, I also thought of using a similar idea, in which I
would slowly "dampen" the velocity and loose that energy. However, (please
don't kill me) I don't remember very well what where the exact results of
this modification, but I do recall that it didn't solve the problem as I
wanted so I discarded it.
I'll post soon my latest experiments, which I think you will like.
Thanks for your ideas and comments!
Fernando.
Date: 21 Jan 2002 07:18:42
Message: <3c4c0722@news.povray.org>
ahem ???
[Talking about cardriving]
"People are opstacles?
Oh...I always treat them as bonus points..." [Ian Burgmyer in p.o-t]
// Jan Walzer <jan### [at] lzernet>
Date: 22 Jan 2002 13:51:20
Message: <3c4db4a8$1@news.povray.org>
what?
sorry i emailed you on that one, i'm a bad OE user.
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3c4c0722@news.povray.org...
or
> ahem ???
Date: 22 Jan 2002 14:16:26
Message: <3c4dba8a$1@news.povray.org>
> what?
[1]
yeah... it seems so ...
for the email-thingie: You know, that you can customize the toolbars for news
independant...
I, for myself, deleted the ReplyToAuthor-Button, so it won't happen again ...
The other thing with outlook is, that it places the cursor at the top, and
cites the
whole message:
But for us humans is should be possible, even to correct this. Simply go down
with the
cursor, and delete every line, in between, that has nothing to do, with the
answer,
you're 'bout to write.
If you want to answer a special sentence, feel free to do so, in between.
Sorry, if you already knew this, but I think it was worth to mention... no
flames intended
> or
> > ahem ???
[1] I'd prefer to write 0 < x < 1 ... (because 0 < 1, you see ?)
Date: 28 Jan 2002 16:19:54
Message: <3c55c07a@news.povray.org>
> flames intended
no problem, i'm really not feeling the heat.  :)
wow, i didn't even catch that.  i suppose i should pay more attention.
