POV-Ray : Newsgroups : povray.binaries.animations : Stiffer cloth (less wrinkles!) MPG1 Server Time
12 Oct 2026 20:25:54 EDT (-0400)
  Stiffer cloth (less wrinkles!) MPG1 (Message 1 to 25 of 25)
Subject: Stiffer cloth (less wrinkles!) MPG1
Date: 19 Jan 2002 02:45:11
Message: <3c492407@news.povray.org>
I tried to simulate a stiffer cloth, but I believe this time it may have
been too stiff! I think everything goes well until the final frames, in
which the cloth sort of "springs" quickly, seemingly in order to extend the
cloth as flat as possible and tries to go under the sphere... which
obviously does not happen with ordinary cloths!
What do you think of this new stiffness? Maybe something intermediate would
be much better, I think.
Also, I'm still not satisfied with the air resistance...
Well... I must get some sleep because tomorrow I have to wake up early. But
I'll be very happy to receive your comments and suggestions,
Fernando González del Cueto.
Mexico City, Mexico.
Download 'newcloth09.m1v.mpg' (300 KB)
Subject: Re: Stiffer cloth (less wrinkles!) MPG1
Date: 19 Jan 2002 03:01:14
Message: <3c4927ca$1@news.povray.org>
I think it looks better now it's is not melting anymore but, but it should
have at least some wrinkles in the end of the animation.
Maybe another object - a little sphere/box, which rests under the cloth. The
cloth shouldn't be flat as a plane in the end, IMHO.
cukk
Date: 19 Jan 2002 06:09:21
Message: <3c4953e1$1@news.povray.org>
the
would
I think something closer to the wrinkly cloth would be better - this like a
sheet of rubber, while the other looked quite realistic IMO
PGP Public Key
Date: 19 Jan 2002 06:16:11
Message: <3c49557b@news.povray.org>
"Fernando González del Cueto" <fcu### [at] yahoocom> wrote in message
news:3c492407@news.povray.org...
the
I like the 'spring'. I was going to comment on the previous version because
it looked like there was too much friction between the sphere and the cloth
as the cloth finally falls to the 'ground'
Brilliant!!
T
Date: 19 Jan 2002 12:02:32
Message: <3c49a6a8@news.povray.org>
It's getting better. Keep trying. You'll find the right mix of parameters
eventually. :)
Date: 19 Jan 2002 12:04:20
Message: <3c49a714@news.povray.org>
Um, hello, sir. I notice you use the name "Tony B". Due to the fact that
I've been on these groups since 1998, and this is the first time I've seen
you around, I would like to politely request that you come up with a
slightly different name so people don't confuse us. For a moment, I thought
I'd checked the newsgroups in my sleep and replied to this animation and
didn't remember a thing! :)
Date: 19 Jan 2002 12:46:39
Message: <3c49b0ff@news.povray.org>
Hi "Tony[B]" <ben### [at] catholicorg>, you wrote in message:
3c49a714@news.povray.org...
RTFM:
section 6.2.2.3:  "Identifier Name Collisions".
;-D
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov  //New: Kitchen scene WIP
Date: 19 Jan 2002 14:59:37
Message: <3c49d029$1@news.povray.org>
I would have expected it to fold over on itself and stay folded (but not
tightly) in its resting position.
I laid down a face-cloth and folded over the corner to visualize what I was
thinking.
Tom Bates
#macro T(B)#local m=mod(B,8);#local B=floor(B/8);m#end#local
C=126981491245202;#
local D=115694168992822;sphere_sweep{b_spline 16#local
i=0;#while(i<16)<T(C)-4,T
(D)-4,10-i/10>.1#local i=i+1;#end pigment{rgb 1}}light_source{-10,1}// Tom
Bates
Date: 19 Jan 2002 15:36:11
Message: <3c49d8bb$1@news.povray.org>
It looks like it's afraid to fall onto itself, like it's repelling itself or
something.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 19 Jan 2002 16:53:22
Message: <3c49ead2@news.povray.org>
But
*g* I know this problem ;-)
It looks like the cloth gets "sucked" rather than "blown" underneath the
sphere.
Does your simulation take care abouth the thinckness of the cloth? It looks
like it is infintively thin?
regards
SY
Date: 19 Jan 2002 17:41:21
Message: <3c49f611@news.povray.org>
"KalleK" <kal### [at] gmxde> wrote in message news:3c4927ca$1@news.povray.org...
would
The
> cukk
Yes, as you said, the melting is gone, but it looks like an invisible iron
is desperately flattening the cloth!
I already fixed this, I think, because the last run looked very good...
however I mistakingly didn't make enough frames, so I didn't want to post
it. Now, I'm trying a bit more complex algorithm, but I f****d the code and
can't see where is the bug... argghhh...
But I'll post soon my latest results.
Thanks for your comments,
Fernando.
Date: 19 Jan 2002 17:43:00
Message: <3c49f674$1@news.povray.org>
news:3c4953e1$1@news.povray.org...
> the
> would
a
Yes, I agree. I would also choose the other one. However I believe an
intermediate level of wrinkliness would look more natural. I'm working hard
in an alternate approach to the simulation and I'll post the results as soon
as they look good :)
Fernando.
Date: 19 Jan 2002 17:45:41
Message: <3c49f715@news.povray.org>
"Tony B" <ton### [at] sentienchomechoicecoyuk> wrote in message
news:3c49557b@news.povray.org...
> the
because
cloth
> Brilliant!!
> T
Thanks Tony! I also believe the other one looked like it had a lot of
friction. As I recall having posted in another reply, I think this is caused
because the sphere was "pushing" the cloth outwards, without really changing
the internal forces, and that's why it looked like it didn't want to fall
down. Now I've changed this, but I haven't been really able to see if it
fixed this particular phenomenon.
Thanks for your comments!
Fernando.
Date: 19 Jan 2002 17:47:25
Message: <3c49f77d@news.povray.org>
"Tony[B]" <ben### [at] catholicorg> wrote in message
news:3c49a6a8@news.povray.org...
> eventually. :)
I hope so! The problem is that I've now messed up the code while trying to
add new features, so I really have a double problem: fix the current code
and then search for the right mix of parameters!!!
Fernando.
Date: 19 Jan 2002 17:49:39
Message: <3c49f803$1@news.povray.org>
"Tom Bates" <tho### [at] shawca> wrote in message
news:3c49d029$1@news.povray.org...
was
> thinking.
Hi Tom. I agree with you: it is an unnatural movement. I think it was caused
because I gave too much emphasis to the stiffness of the cloth. I'm now
experimenting with new settings to see if this gets fixed.
Thanks for your suggestions!
Fernando.
Date: 19 Jan 2002 17:51:00
Message: <3c49f854@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3c49d8bb$1@news.povray.org...
or
> something.
Hi Slime,
Yes, it looks like it wants to flatten itself out. You can see a very strong
repulsion against folding.
Fernando.
Date: 19 Jan 2002 18:09:32
Message: <3c49fcac@news.povray.org>
"Jürgen Scharfy" <sch### [at] surfeuat> wrote in message
news:3c49ead2@news.povray.org...
> But
> sphere.
looks
> regards
> SY
Hi Jürgen,
Yes, the cloth is modeled as a triangular mesh, so topologically is a
surface of two dimensions, that's why it appears to have no thickness.
I spent some time trying to see how could I simulate some thickness in it...
at lease visually, but I didn't get anywhere.
You are from Austria? One year and a half ago I visited Salzburg and 6
months ago I visited Graz and Wien (Vienna) and I loved Austria! It is a
beautiful place.
Dank für Ihren Kommentar (computer translation :)
Fernando.
Subject: My newsreader is drunk!
Date: 19 Jan 2002 18:09:34
Message: <3c49fcae@news.povray.org>
It seems that my newsreader has placed my replies in the wrong places... I'm
sorry for any inconvenience this may cause...
Sorry...
Fernando.
Subject: Re: My newsreader is drunk!
Date: 19 Jan 2002 18:20:43
Message: <3c49ff4b$1@news.povray.org>
Ooopss... I restarted it, and it seems that it was a temporary problem
because they are now where they belong.
Sorry for the false alarm... :/
Fernando
news:3c49fcae@news.povray.org...
I'm
> Sorry...
> Fernando.
Date: 19 Jan 2002 18:29:36
Message: <3c4a0160$1@news.povray.org>
Fernando González del Cueto <fcu### [at] yahoocom> wrote in message
I'm
> Sorry...
> Fernando.
I know you've complained about that before, but
they seem correct to me (reading with MS-OE5).
Tom Bates
C=126981491245202;
#local D=115694168992822;sphere_sweep{b_spline 16#local
,T(D)-4,10-i/10>.1#local i=i+1;#end pigment{rgb
1}}light_source{-10,1}//T.Bates
Date: 19 Jan 2002 18:46:54
Message: <3c4a056e$2@news.povray.org>
> Tom Bates
Hi Tom, I'm using MS-OE6. Sometimes, after replying a post, the reply is not
placed in the correct place. But I discovered that if I restart the
newsreader, everything is corrected. Strange, but true...
Thanks,
Fernando.
Date: 19 Jan 2002 19:19:33
Message: <3c4a0d15@news.povray.org>
I think the animation looks perfect in its first half.
In the second half, the cloth acts weird.
It still feels like the cloth its a little too stiff than it should be, just
a little bit.
But I think you are getting there :))
You are getting closer every time.
Good work.
Best regards
Date: 19 Jan 2002 21:27:55
Message: <3c4a2b2b$1@news.povray.org>
"JPGargoyle" <jpg### [at] clixpt> wrote in message
news:3c4a0d15@news.povray.org...
just
> a little bit.
> Good work.
Thanks JPGargoyle!
But I think now I'm getting farther away... you'll see why in my next
post.... sniff sniff
Fernando.
Date: 20 Jan 2002 07:38:43
Message: <3c4aba53@news.povray.org>
Hi Fernando,
it...
Maybe it can be simulated by giving more stiffness to the small wrinkles but
decreasing it for larger scales.
> beautiful place.
Yes I am (I think you gessed it from the .at in my e-mail?). It's nice that
you had a good time in Austria. I live approx. 60km south of Vienna, very
close to the hungarian border. Fortunetaly it doesn't matter for writing
e-mails *lol*
The translation is quite ok, it just missed an "e" since it is called
"Danke" in this phrase. :-)
Can it translate backwards as well?
Gern geschehen, mir gefällt Ihre Animation und ich freue mich schon auf neue
Simulationen!
regards
Jürgen
Date: 20 Jan 2002 12:52:18
Message: <3c4b03d2@news.povray.org>
news:3c4aba53@news.povray.org...
> Hi Fernando,
that
> e-mails *lol*
neue
> Simulationen!
The computer translated it as "Gladly occurred, me your animation and I
please already look forward to new Simulationen!" which is enough to give me
an idea of what you meant. Normally the translations are better, perhaps
there is some ambiguity in the sense of the sentence?
Danke!
Fernando.
ps. The only two main phrases that I learned were "Ich sprechen kein
Deutsche" and "Sprechen sie English?" (Don't know if I spelled that
correctly!)
ps. the translating service that I use is http://babelfish.altavista.com
