Definitely cool, even if it's a bit hard to understand what's going on :)
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov
"Thies Heidecke" <h3i### [at] gmx net> ha scritto nel messaggio
news:3c34f2d4@news.povray.org...
> As suggested by Hartmut Wagener I've made an animated
> Version of my 3D-Mosaic. The Orientation of the Mosaic is
> changing continuously while the object stays in its place.
> Thies Heidecke
Absolute superb ...
I will have a look on it later "frame by frame" to look wat really happens.
What was the rendering-time for this? Good resolution and time,
congratulations ...
Hartmut
"Thies Heidecke" <h3i### [at] gmx net> schrieb im Newsbeitrag
> Thies Heidecke
very impressive :)
PGP Public Key
OK, that's a little scary.
Do that on a poser figure and you have next year's sci-fi effect.
That is quite nice. I'm pleasantly surprised that the shape itself is not
obscured by the motion.
"Thies Heidecke" <h3i### [at] gmx net> wrote in message
> Thies Heidecke
nice ... did you have a look at this ?
http://news.povray.org/povray.binaries.animations/19211/
http://news.povray.org/povray.binaries.animations/19228/
I also tried something lige this ...
But it seems, you got the better shape, to show what happens ..
also nice textures ...
"Somehow what you suggest is like suggesting to add drills \ jan### [at] lzer net
to cars so you can drill for oil when you run out of fuel. \
Sure you could do it, but it might not be the most practical > Jan
solution." [Thorsten Froehlich in p.u.p] / Walzer
Nice animation... But what happened to to the flour and walls? There's
something wrong under the object to the right and on other places too...
#local a=.1sphere_sweep{catmull_rom_spline 18<3,3>a<1,3>a<0,0>a<1,3>a,x*2a
y,a<2.5,1.5>a<3,3>a,x*3a<3,3>a<4.5,2>a<3,1>a,x*4.5a<5.5,3>a,x*6a<4.5,2.5>a
<7,3>a<8,3>a scale a translate<-.35,-a,1>}background{rgb 1} // Artis
> Definitely cool,
I think it would look better if i used more frames and
smaller timesteps, but the rendertime was high enough
already...
Thies Heidecke
> Absolute superb ...
> congratulations ...
happens.
like i posted to JRG already, i should have used more frames...
about 15 minutes per frame (6 minutes parsing, 7 minutes rendering).
alltogether about 20h (on Celeron 266 @ 400 MHz )
(could have been 16h i think if i didn't do anything else with the comp)
Thies Heidecke
> very impressive :)
Thies Heidecke
Yeah, that would be cool =)
Perhaps someone feels like making this.
I'd be interested in the outcome.
Thies Heidecke
> That is quite nice.
Yes, thats what i tried to achieve.
If one doesn't rotate the object back into its original
postition it just rotates while the mosaic-orientation
stays the same and doesn't look so strange.
Thies Heidecke
> nice
Yes, i have seen them.
Probably they were a kind of unconscious inspiration : )
Thanks very much
Thies Heidecke
> Nice animation...
Thanks
I've done this intentionally. I thought it would make the floor more
interesting if it has some minor irregularities.
Thies Heidecke
hmm, i can't calculate anymore : )
it was 6 minutes parsing and the rest raytracing ; )
Thies Heidecke
Very interesting and beautiful!
Congratulations,
Fernando.
> Thies Heidecke
