POV-Ray : Newsgroups : povray.binaries.animations : AL walking, stopping and turning - Final Server Time
27 Nov 2026 17:12:34 EST (-0500)
  AL walking, stopping and turning - Final (Message 1 to 37 of 37)
Subject: AL walking, stopping and turning - Final
Date: 1 Jan 2002 17:43:15
Message: <3c323b83@news.povray.org>
I've improved the algorithm in my walking system a lot and have made a new
version of the animation that I think is much better than the previous.
I have also rendered it in 320x240 with AA, and the camera angle is a bit
more interesting.
It's up on my website:
http://rsj.mobilixnet.dk/3d/anims/anims.html
Hope you like it. :)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Subject: Re: AL walking, stopping and turning - Final
Date: 1 Jan 2002 17:52:30
Message: <3c323dae$1@news.povray.org>
> more interesting.
Where exactly?
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov
Date: 1 Jan 2002 17:54:16
Message: <3c323e18@news.povray.org>
Ok I found it, but you forgot the link ;)
Date: 1 Jan 2002 17:58:30
Message: <3c323f16@news.povray.org>
Lovely! And impressive.
Date: 1 Jan 2002 18:16:02
Message: <3c324332@news.povray.org>
"JRG" wrote:
> Where exactly?
Strange - I'm sure I uploaded the updated page...
Anyway, it's there now.
Rune
Date: 1 Jan 2002 18:16:04
Message: <3c324334@news.povray.org>
Thanks! :)
Rune
Date: 2 Jan 2002 00:01:17
Message: <3c32941d$1@news.povray.org>
Amazing, Rune! The animation looks very realistic, and the attention to
detail is very impressive. The way the eyes and head rotate before Al turns
is great. Now, can Al walk and talk at the same time? How about chew gum?
-David
Date: 2 Jan 2002 01:33:08
Message: <3c32a9a4@news.povray.org>
Amazing. The start after the stop was a bit jerky, though. I suspect because
you placed the next footstep so close. Still, this is much better than
anything I could ever do. Great job.
Date: 2 Jan 2002 03:43:25
Message: <3c32c82d@news.povray.org>
"Tony[B]" wrote:
> Amazing.
Thanks!
It's not because I don't want criticism, but I truly can't see this. It
looks pretty smooth to me. Could you explain more detailed what you're
referring to?
Rune
Date: 2 Jan 2002 03:43:28
Message: <3c32c830@news.povray.org>
> and the attention to detail is very impressive.
Thank you! :)
> The way the eyes and head rotate before Al turns is
> How about chew gum?
That should not be too difficult.
But some other things like waving the arm are more difficult as it would
require some way to interpolate between the automatic arm movement and
custom arm movement, which is something I have yet not figured out how to
do.
Rune
Date: 2 Jan 2002 05:02:43
Message: <3c32dac3@news.povray.org>
Rune schrieb in Nachricht <3c32c82d@news.povray.org>...
I wouldn't call it jerky, but the first step after the stop is indeed only
half a footlength wide (long?). I think that's not that realistic, 'cause
it's a waste of kinetic energy.
Nevertheless it's a great piece of work!
Marc-Hendrik
Date: 2 Jan 2002 10:00:38
Message: <3c332096@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote :
> Rune
> 3D images and anims, include files, tutorials and more:
________________________________________^^^^^^^^^^
    When are you going to update your sig?
Date: 2 Jan 2002 10:39:24
Message: <3c3329ac@news.povray.org>
Thanks for reminding me! :)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 2)
Date: 2 Jan 2002 13:03:56
Message: <3C334C8B.41E1A720@hotmail.com>
Very good.
Here's a tip that helps make MPGs smaller:
Don't use checker as the pigment for your plane, at least not in the
final rendering.  My first IRTC entry was much smaller (and looked
less like a newby effort) when I replaced the checker pattern with
a granite pattern.
If need be, you can have an if-else-end block to switch between test
renders (because the checker pattern is quite useful for eyeballing
measurements).
John
ICQ: 46085459
Date: 2 Jan 2002 14:03:49
Message: <3c335995@news.povray.org>
> the stop is indeed only half a footlength wide (long?).
> I think that's not that realistic, 'cause it's a waste
> of kinetic energy.
I think in reality the first step is indeed often a bit shorter because it
takes the body a little while to get in momentum. However, probably not as
much as this animation. I'll try to figure out why my algorithm places that
step so close to the previous one.
Thank you!
Rune
Subject: Re: AL walking, stopping and turning - Final 2
Date: 2 Jan 2002 14:03:53
Message: <3c335999@news.povray.org>
I've slightly changed the animation. Nothing big - I haven't yet been able
to make that short step longer - but a few minor changes.
I've made AL chew a gum as Dave suggested, I've made a slight breathing
motion for him which isn't really noticeably, but which nonetheless makes
him seem slightly less stiff, and I've modified the ground texture to avoid
checker pattern moiré patterns.
The new version has replaced the old one on my website, so it's available
from the same place.
Rune
Date: 2 Jan 2002 14:18:09
Message: <3c335cf1@news.povray.org>
"John VanSickle" wrote:
> Very good.
Thanks!
> least not in the final rendering.  My first IRTC
> entry was much smaller (and looked less like a newby
> effort) when I replaced the checker pattern with a
> granite pattern.
Thanks for the tip! I presume it's the checker pattern seen at a distance
that's the problem? If so I've already updated the animation with a
workaround for that.
Rune
Date: 2 Jan 2002 15:35:18
Message: <3c336f06$1@news.povray.org>
    Ah! I was finally able to see this one, thanks to a complete destruction
of my QuickTime installation... again...
    Very nice, I see a little extra bounce in the tips of the toes, and he
seems a little heavy, but otherwise -very- nice.
Date: 2 Jan 2002 16:51:27
Message: <3c3380df@news.povray.org>
> tips of the toes
Well spotted. It's a side effect of using cubic splines for the movement.
They always want to go a bit too far and then back before they stop. Using
more control points may or may not reduce/solve the problem - I never can
remember.
> and he seems a little heavy
Heavy in what way? He's supposed to look a little heavy, like many toons do.
Does it look wrong somehow?
Thanks! :)
Rune
Date: 2 Jan 2002 17:36:19
Message: <3c338b63@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in :
> Heavy in what way?
    The feet seem to hit hard.
    No, probably fixing the feet will fix it, if it really needs to be
fixed.
Date: 2 Jan 2002 18:09:39
Message: <3c339333$1@news.povray.org>
Wow ... extremely nice ... missing words ...
but now: Nitpicking ! *g
have you seen closely the feets in the frames 160-170 ?
when he turns, it seems, that the inner foot moves into the outer one ...
at least it seemes so ...
Jan Walzer <jan### [at] lzernet>
Date: 2 Jan 2002 22:16:55
Message: <3c33cd27@news.povray.org>
He seems to have a purposeful, but casual, step about him. I can easily imagine
him carrying a padd and stopping to check on some equipment, starting to move on
to the next checkpoint, then spotting someone he would like to get better
acquainted with <wink> and changing direction to pursue.
Very well done.
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 3 Jan 2002 12:24:33
Message: <3C3494D4.262F30E8@hotmail.com>
> > Very good.
> Thanks!
> > granite pattern.
(I'd like to mention here that I did use a checker pattern for
my entry-winth-an-entry in the Robots round, but that was a
deliberate effort at being lame.)
> distance that's the problem? If so I've already updated the animation
> with a workaround for that.
If the anti-aliasing is good, the distance is usually a mix of the two
colors, and isn't really a problem.
The problem with checkered patterns in MPG files is the sharp edges
between the squares in the foreground.  Either you get a lot of
artifacts or you have a huge file.
John
ICQ: 46085459
Date: 5 Jan 2002 06:06:04
Message: <3c36de1c$1@news.povray.org>
"Dave Blandston" <gra### [at] earthlinknet> wrote in message
news:3c32941d$1@news.povray.org...
> How about chew gum?
It looks like he is. Watch very closely when he's stopped or turning and
you'll see his jaw moving up and down, up and down.
Date: 5 Jan 2002 17:07:16
Message: <3c377914$1@news.povray.org>
> more interesting.
Awesome!!!   :o)   This is the best character animation I've seen in Pov and
maybe because I never see such modern toons, it's so smooth like I can't
even imagine.
Hugo
Date: 5 Jan 2002 19:30:10
Message: <3c379a92@news.povray.org>
> I've seen in Pov and maybe because I never see such modern
> toons, it's so smooth like I can't even imagine.
Gee, thank you! :)
Rune
Date: 5 Jan 2002 19:30:19
Message: <3c379a9b@news.povray.org>
> stopped or turning and you'll see his jaw moving up
Because I implemented Dave's suggestion! :)
(I updated the animation after Dave sent his message.)
Rune
Date: 5 Jan 2002 19:30:20
Message: <3c379a9c@news.povray.org>
Thank you! :)
The best part!
> the outer one ... at least it seemes so ...
That's probably right. I hadn't seen that. Hmm, now to find out how to avoid
that...
Rune
Date: 5 Jan 2002 19:52:41
Message: <3c379fd9@news.povray.org>
> that...
Making the feet 100 units distant from each other should do the trick.
Don't bother to thank me.
Home: http://digilander.iol.it/jrgpov  //New: Kitchen scene WIP
Date: 6 Jan 2002 16:28:47
Message: <3c38c18f@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote:
news:3c379a9c@news.povray.org...
> Thank you! :)
no problem ...
> The best part!
of course ...
avoid
> that...
Hmmm ... How 'bout constructing Al as a Particlesystem ...
with:
 - _many_ small blobs ...
 - _many_ forces between these particles ...
 - these particles forming the body of Al ...
 - and: ..... Particlecollission-detection ..... *tataaa* ?
"Somehow what you suggest is like suggesting to add drills \ jan### [at] lzernet
to cars so you can drill for oil when you run out of fuel.  \
Sure you could do it, but it might not be the most practical >          Jan
solution." [Thorsten Froehlich in p.u.p]                    /        Walzer
Date: 6 Jan 2002 18:21:13
Message: <3c38dbe9@news.povray.org>
> with:
Hmm, not such a bad suggestion, especially since I already have a particle
system which I could, with some minor modifications, adapt do be able to
handle that. I'll get started right away!
A bonus will be that the particle system can then also be used to simulate
rotating gears and other mechanical components with collision detection. It
will require quite some particles though...
Rune
Date: 6 Jan 2002 18:25:12
Message: <3c38dcd8@news.povray.org>
After some work on the project, it appears that the particle system would
also be suited to model non-moving things like kitchen-inventory, landscapes
and medium-sized wall mirrors.
Rune
Date: 7 Jan 2002 07:57:01
Message: <3c399b1d$1@news.povray.org>
You have access to a fast computer ?
Date: 7 Jan 2002 22:46:23
Message: <3c3a6b8f$1@news.povray.org>
That's how God did it .. but his computer is pretty big ...
I mean, look how many particles are in my finger!
                  == John ==
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3c399b1d$1@news.povray.org...
jan### [at] lzernet
Jan
Walzer
Date: 7 Jan 2002 22:51:43
Message: <3c3a6ccf$1@news.povray.org>
I guess someone has to ask - going to post the source? <G>
Impressive!
                  == John ==
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c335999@news.povray.org...
avoid
> Rune
Date: 8 Jan 2002 01:40:59
Message: <3c3a947b$1@news.povray.org>
yeah ... capable of Realtime-Raytracing ...
How many ? I can't see them  ...
Date: 8 Jan 2002 17:28:36
Message: <3C3B6E80.77D6111A@yahoo.com.au>
Wow, great movement!
I give two suggestions to help Al achieve realism (or as real as an alien can get
:-) The first is to make him blink every so often. You did this when he talked
and it really makes a difference. The second is to make him do something when he
stops walking. He becomes so rigid at this point (only his mouth moves) that it
is unnatural. If he swayed side to side, or scratched his head, etc. instead of
freezing, it would look so much better.
I do not mean to sound critical here, but rather point out that well done major
movements (like the walking that Al does) still needs those little things to help
it _really_ shine. If you have the talent (and by the looks of it, you do) you
may as well take it all the way.
MJL
light_source{12*(y-z)rgb 2fade_distance 9fade_power 2area_light x,z,5,5}#macro A
(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)#local V=asc(substr(B,I,1
))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{red 1}rotate-<90,R>translate
-T}#end A(16"/.@VZno=<PLA89/"0,5*x)A(14",6;MWmhryXN3,"60<15,0,8>)camera{location
25*(y-z)look_at 0}A(8"6hiAG=6"-60,-10*x)box{-99(x+z)*99 pigment{rgb 1}}   // MJL
