In my particle system I've just implemented support for user-defined
gravity. One use of that is to simulate the gravity of planets etc. That's
what I've attempted in this animation. (The particles are not attracted to
each other though.)
Comments appreciated as always! :)
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Nov 5)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
Download 'gravityfun.mpg' (511 KB)
"Rune" <run### [at] mobilixnet dk> wrote in message
news:3c0e2e49@news.povray.org...
> each other though.)
What finally happens? Do they all impact a planet? If my mental
simulation is correct, they would all have to...
Of course I haven't tried it, but I think most (maybe all) will impact a
planet but some might leave the system (that happened in some other tests).
Rune
Curiouser and curiouser...
Cool!
- Nekar
http://nekar_xenos.tripod.com/metanoia/
Version: 6.0.298 / Virus Database: 161 - Release Date: 2001/11/13
But be careful with concluding too much from it. After some time the
system might differ quite a lot from the physically accurate one because
inaccuracies of the numerical simulation grow. A standard way of testing
this (and also a method for correction) is to calculate the total energy
of each particle which has to stay constant (apart from collisions).
Christoph Hormann <chr### [at] gmx de>
> After some time the system might differ quite a
I'm not sure I like what I hear. Are you implying that my particle system
may not be good enough for NASA to use?
Rune
Curious about what?
Rune
"Nekar Xenos" wrote:
> Cool!
Thanks!
Rune
news:3c0e39ec@news.povray.org...
tests).
From what I remember, there's no dfinate way to predict particle (planet)
motion around two larger bodies. The orbits of planets around a binary
couple get very chaotic, very quickly. Now where'd I see that article?
In article <3c0e39ec@news.povray.org>, run### [at] mobilixnet dk
says...
Then you have a problem. They should't be able to do this (unless they
have a high initial speed) because of energy-conservation.
I tried a similar thing (in C, but 2D), and had the problem that some
partices that passed the gravity-source in small dinstance tend to gain a
lot of speed, because the gravity force varies very much in a very small
area, so the simulation gets unaccurate.
Or maybe some kind of "adaptive iteration step length" could help here.
Lutz-Peter
Um... I am probably the last person to challenge this, but "evaporation"
of an orbital system is pretty common. Energy is conserved, as it is taken
from other objects. Some things slow down and other things speed up.
> do this (unless they have a high initial speed)
Sure, but what's considered high initial speed? I think the particles have
high initial speed...
> problem that some partices that passed the
> much in a very small area, so the simulation gets
> unaccurate.
My particles collide with the planet before that happens.
> could help here.
Haha, that's completely out of the question with my system. Having each
particle have differently spaced interation steps - that sure would be a
mess, and practically impossible to code into my system...
Rune
In article <3c0e58e2$1@news.povray.org>, bde### [at] cfl rr com says...
Yep, in reality, but this can't be the case here, because in this
particle system, the particles themselves doesn't influence each
other....
Of course that only applies to this animation, not my system in general.
Because the system is so flexible, it's up to the user to make sure unwanted
effects don't take place.
Rune
In article <3c0e5a4a@news.povray.org>, run### [at] mobilixnet dk
says...
I think, they would escape the system immediately if they had sufficient
energy. I maybe wrong though.
Perhaps the effect isn't visible at once, but accumulates?
Yes, it was just an idea, and probably anyway overkill unless you want to
accurately simulate a solar system :-)
Lutz-Peter
"Lutz-Peter Hooge" <lpv### [at] gmx de> wrote in message
news:MPG.16787994d47543659896c6@news.povray.org...
> other....
Ah, I didn't read that in the previous posts. I assumed that they did
inter-react. If not, you are correct, they either have too high an initial
velocity or he has a problem.
It might interest you that NASA once had serious problems with exactly
this problem, but i don't know the precise details, i just heard it
somewhere.
'drift' of the results is a common problem with simulation of such systems
so no need to feel bad about it. ;-)
Not necessarily, in a 3 body system they can collide with one of the
masses even if the speed is very high.
In article <3C0E5F60.E0C56986@gmx.de>, chr### [at] gmx de says...
Thats even possible with a two-body-system:
o---> <-O
> o---> <-O
Yes, but this is one special case, in a 3 body system there are various
situations that can lead to a collision.
Sigh. If only all pov particle systems could do this, the world(s) would be a
better place... Reminds me of a program I had years ago that would simulate a
comet passing by the sun.
MJL
light_source{12*(y-z)rgb 2fade_distance 9fade_power 2area_light x,z,5,5}#macro A
(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)#local V=asc(substr(B,I,1
))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{red 1}rotate-<90,R>translate
-T}#end A(16"/.@VZno=<PLA89/"0,5*x)A(14",6;MWmhryXN3,"60<15,0,8>)camera{location
25*(y-z)look_at 0}A(8"6hiAG=6"-60,-10*x)box{-99(x+z)*99 pigment{rgb 1}} // MJL
"Mark James Lewin" <m_j### [at] yahoo com au> wrote in message
news:3C0E8B64.1860CEB5@yahoo.com.au...
be a
simulate a
> MJL
Back when I was going through university for engineering, we had to write a
program for a calculus course that calculated the movement of one planet
around another using some sort of series (I can't quite remember). I
thought I was pretty slick writing one in VB with a nice GUI, graphics and
laser printouts, I should've done it in POV.
-tgq
news:3c0e4d03@news.povray.org...
> > Cool!
> Thanks!
Almost looks like Bueharia ...*hint, hint*
- Nekar
Its hypnotic :-/ and I feel dissapointed(sp?) that after managing to
follow a particle - it ends - too soon :-(
Alf
> managing to follow a particle - it ends - too soon :-(
Actually I feel/felt the same way, but I had to end the animation at some
point...
Rune
What is Bueharia?
Rune
> each other though.)
I love the way they just 'stick' :)
PGP Public Key
ummmm wow...... Does the one on the left have stronger gravity?
Rune <run### [at] mobilixnet dk> wrote in message
> each other though.)
> Rune
> 3D images and anims, include files, tutorials and more:
Scientific American? A few months ago there was an artivle about
a solved n-body problem. Rune's bodies start in the way that could
be stable but soon it drifts off.
Markus
Rune wrote:
> What is Bueharia?
Check out the "Binary Planets" thread in povray.off-topic
signature{
"Grey Knight"
contact{ email "gre### [at] yahoo com" }
site_of_week{ url "http://www.esite-host.com/~rocketmg/" }
news:3c0f6363@news.povray.org...
> What is Bueharia?
... and I thought Bueharia was the inspiration for this anim... ;)
- Nekar
"s1631001" wrote:
> Rune wrote:
> > What is Bueharia?
Aha, got it now.
But all your messages with attachments have been cancelled, so I couldn't
see them.
Rune
Not at all - if there's any resemblance, it's a pure coincidence...
I came up with it this way:
I had implemented user defined gravity, and was considering possible demo
animation ideas. Gravity is space seemed like an obvious idea and in order
to make it more interesting I used two planets instead of one...
Rune
I considered making them bounce (high), but that would have been really
confusing.
I also considered making them bounce just a tiny amount, but that seemed to
cause unstable results, so I dropped that idea...
Rune
No, but it's closer to the camera. :)
BTW, you don't need to quote my entire message (including my sig even!), and
especially not *below* your own reply... Just quote the part that you're
actually replying to, or if you're replying to the whole message in general
you can leave out the quote entirely. And then place your own reply below
the quote, as if it is a conversation (which it is!).
Rune
Rune wrote:
> All your messages with attachments have been cancelled, so I couldn't
> see them.
Yeah, I cancelled them after Ken pointed out that I was doing too much
binary posting. I can send you the relevant files if you want? Nekar can
probably supply you as well.
signature{
"Grey Knight"
What if you made the large masses recoil from the impact? What would
that look like?
signature{
"Grey Knight"
> was doing too much binary posting. I can send you
> the relevant files if you want? Nekar can probably
> supply you as well.
No thanks to both of you.
I have a slow and expensive connection so I don't like getting large files
per e-mail where I have no option of canceling the download if I should for
some reason want to do that.
Rune
news:3c0f8cea$1@news.povray.org...
and
general
Yeah I know, I've found out that people don't like it when you reply above
the original message. ahhh well, I do try though.
Gary
news:3c0fd5fc@news.povray.org...
> > supply you as well.
I don't think Grey Knight will mind me doing this. I've uploaded the files. If
you have a download accelerator and you want to, you can download them from
here:
http://nekar_xenos.tripod.com/sitebuildercontent/sitebuilderfiles/orbits1.zip
and here:
http://nekar_xenos.tripod.com/sitebuildercontent/sitebuilderfiles/orbits2.zip
Grey Knight - if you want me to I'll take it off the site.
- Nekar
> What would that look like?
My particle system has no support for two-way interaction.
Rune
Thanks, I'll have a look later. Please don't take them down right away. :)
Rune
"Markus Becker" <bec### [at] aicoss de> wrote in message
news:3C0F6782.876491D3@aicoss.de...
(planet)
I'm not sure. I think it may have been a book from Time.
Thanks, I've got them now. :)
I see that they're made with POV-Ray, so why they weren't posted to the
respective correct groups in the first place is beyond me...
Rune
Because I'm an idiot who didn't know what he was doing. I think that
about sums it up...
signature{
"Grey Knight"
site_of_week{ url "http://enphilistor.users4.50megs.com/" }
