Here's my first test of using Elastolab to output POV spline data. It was
quite a job to construct the environment from polygons and spline data, but
worth the effort I feel.
Any comments welcome.
All the best,
Andy Cocker
Download 'Elastolab_Test1.mpg' (607 KB)
On Wed, 14 Nov 2001 13:16:34 -0000, "Andrew Cocker"
nice, how long did you develop this (without rendering)
and what is the strange tick of box at the end of anim?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
"Andrew Cocker" <big### [at] mariner9 fsnet co uk> wrote in message
news:3bf2704d@news.povray.org...
> Hi,
> All the best,
> Andy Cocker
Oh. Wow. I am completely dumbfounded. Well, almost.
That's great! I might have to get that.
Michael
#declare R=<8,4,.6>/3;#declare C=function{pattern{object{text{ttf"crystal.ttf"
"MDJ"1,0translate-R/4}}}}camera{location-z*30}box{-R,R pigment{rgbf 1}interior
{media{emission.1density{function{C(x,y,z)}density_map{[0mandel 50color_map{[0
rgb 0][.2rgb x][1rgb x+y]}interior 1,1.5scale 60translate<-33.75,2.85>exponent
4][1rgb<2,2>]}}}}scale 24hollow}// (c) 2001 MDJohnson red### [at] wv adelphia net
I can explain the tick of the box. The box is modeled with particles connected
by rods. There's a known problem when two particles connected by a rod are in
resting contact with a barrier. The simulation treats them as two independent
particles and doesn't realize that moving one causes the other to move. The way
to solve this is to re-formulate the problem and solve a system of linear
equations inside a loop. This is a lot of work and I'm not certain that it would
run in real-time. Without that approach, there's a little bit of jitter when two
particles connected by a rod are sitting on a barrier. I may address that later,
but I felt that it wasn't a big problem for now.
David Buck
Simberon Inc.
> Hi,
but
Nice scene -- does it uses radiosity?
"ARTis" <art### [at] aaa apollo lv> wrote in message
news:3bf2e719@news.povray.org...
Thanks. Yes, it does use radiosity.
Andy Cocker
OMG! love the bouncy thing in the middle.
G
Andrew Cocker <big### [at] mariner9 fsnet co uk> wrote in message
> Hi,
but
> All the best,
> Andy Cocker
Nice.
IIRC Elastolab only does 2d physics. Is that correct? If it does 3d physics, I
have another Q: is it free and where can I get it?
-Nekar
> Hi,
> All the best,
> Andy Cocker
Version: 6.0.286 / Virus Database: 152 - Release Date: 2001/10/09
"Nekar Xenos" <j-p### [at] citywalk co za> wrote in message
news:3bf358f1@news.povray.org...
> Nice.
Thanks.
physics, I
Only 2D I'm afraid. :-(
All the best,
Andy Cocker
"blessing" <ble### [at] icefog net> wrote in message
news:3bf32d84@news.povray.org...
Me too ;-)
All the best,
Andy Cocker
Nekar Xenos wrote:
> Nice.
> -Nekar
It's 2D physics because it's aimed at a different market. It's intended to be a
kids application (age 9 and up) to let them play in a world with simulated
physics. 2D is much easier to deal with in that environment.
If there's enough interest and the market is large enough, I may consider a 3D
version. So far, sales are slow because I'm not promoting it much yet. After I
get more sales, I'll decide on a strategic direction for future versions based on
interest from the user base.
You can get it from www.simberon.com.
David Buck
Simberon Inc.
Nice. It reminds me of an old game by Sierra (wasn't it The Incredible
Machine or something like that?...)
Jonathan.
"Andrew Cocker" <big### [at] mariner9 fsnet co uk> ha scritto nel messaggio
> Hi,
but
> All the best,
> Andy Cocker
Amazing. I have been unable to "do the physics of" a ball that is BOTH able to
bounce AND does not fall through the floor when it comes to rest. I probably
end up with a particle whose surface is say 1E-7 from the floor but is
plummeting toward the ground at 1E-5, or something like that.
Andrew Cocker wrote:
> Hi,
> All the best,
> Andy Cocker
> Elastolab_Test1.mpg Type: Wmplayer File (video/mpg)
> Encoding: x-uuencode
The secret is to detect resting contact and switch modes to Dynamic Constraints.
Dynamic constraints calculate the forces required to nullify the normal
acceleration of a particle in order to avoid breaking constraints like falling
through the floor. Once resting contact has been determined, the system calculates
the acceleration of the particle then calculates the force necessary to prevent the
particle from falling through the floor. It applies the force, then calculates the
physics.
For all the gory details, check out:
http://www-2.cs.cmu.edu/afs/cs/user/baraff/www/pbm/pbm.html
David Buck
Simberon Inc
www.simberon.com
