This is a little animation I made based on the 'Stargate' sequence of
CGI fame. The inner bit is just a disc/cylinder with a funny pigment
pattern and nomal waves in phase with the clock.
Subject: Re: Stargate facsimile
Date: 15 Aug 2001 22:00:08
Message: <3b7b2928@news.povray.org>
MPG-1 is the common courtesy for posting here.
I assume this was a gif. I wasn't able to see it on two different PC's: one shows a
broken image, the other a stationary unmoving gif.
> Mahalis wrote:>> This is a little animation I made based on the 'Stargate' sequence of CGI fame. The
inner bit is just a disc/cylinder with a funny pigment pattern and nomal waves in
phase with the clock.> [Stargate]
I see. Do you know of any program that can convert from GIF or AVI to MPG?
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:3b7b2928@news.povray.org...
> MPG-1 is the common courtesy for posting here.> I assume this was a gif. I wasn't able to see it on two different PC's:
one shows a broken image, the other a stationary unmoving gif.
>> > Mahalis wrote:> >> > This is a little animation I made based on the 'Stargate' sequence of
CGI fame. The inner bit is just a disc/cylinder with a funny pigment pattern
> > [Stargate]>
Assuming you're an a MS operating system, have a look at
http://members.home.net/beyeler/bbmpeg.html
It will convert Avi to Mpeg (1 or 2, at your choice, with or without sound)
Thanks! I'll try it.
"Jérôme Grimbert" <jer### [at] atosorigincom> wrote in message
news:3B7CCCF7.4AA0A078@atosorigin.com...
> Mahalis wrote:> >> > I see. Do you know of any program that can convert from GIF or AVI to
MPG?
>> Assuming you're an a MS operating system, have a look at>> http://members.home.net/beyeler/bbmpeg.html>> It will convert Avi to Mpeg (1 or 2, at your choice, with or without
sound)
