POV-Ray : Newsgroups : povray.binaries.animations : even more balls Server Time
27 Nov 2026 18:01:16 EST (-0500)
  even more balls (Message 1 to 19 of 19)
Subject: even more balls
Date: 1 Jun 2001 13:51:11
Message: <3b17d60f@news.povray.org>
I fixed some more bugs in the physics, so I decided I'd give them a thorough
test. I left this one running overnight and today while I was at work, that's 17
hours, just to see how it ran with a much larger number of balls. It's pretty
convincing apart from a couple of balls getting pushed through the walls :)
Next I think I might have a go at varying the radius and weight of each ball.
Tek
http://www.evilsuperbrain.com
Download 'MOTION.MPG' (335 KB)
Subject: Re: even more balls
Date: 1 Jun 2001 14:39:10
Message: <3b17e14e$1@news.povray.org>
After about the 5th ball dropped (or so) a couple of balls seem to "slide"
to the left in midair before they hit the ground.
news:3b17d60f@news.povray.org...
thorough
that's 17
pretty
ball.
> Tek
Date: 1 Jun 2001 16:02:10
Message: <MPG.1582131d224653b69897b1@NEWS.POVRAY.ORG>
In article <3b17e14e$1@news.povray.org>, Patrick Dugan says...
I looked at all the images in detail (the motion blur made that
difficult), but as far as I can see it is all OK, the 'slides' you see
were 2 balls falling and hitting each other in mid air - I think.
To me it is astonishing real: excellent!
Regards,  Sander
Date: 1 Jun 2001 17:49:10
Message: <3b180dd6@news.povray.org>
I hate to contradict you, but I think Patrick might be right. I have a slightly
dubious piece of maths that alters the effects of gravity after a collision
(well I /thought/ it worked). I guess those two balls are just created too close
together then they fall constantly colliding. I've now fixed it in a low-tech
way by making sure balls aren't created so close together ;)
Thanks :D
Tek
Date: 1 Jun 2001 19:37:09
Message: <3B182911.26012826@qwest.net>
watched it for about five minutes straight looping...
noticed balls would pick up energy sometimes almost as
if the floor were "sprung."  sorta eat- also noticed
one ball in back right corner got "caught" somehow and
gained energy somehow until it winked out or stopped
cold- couldn't tell.
overall VERY neat simulation!
CG images, *obscure* home-brewed graphics utils, and
animation
http://www.users.qwest.net/~dearmad
Date: 1 Jun 2001 19:49:03
Message: <3b1829ef@news.povray.org>
wow - how about doing these higher res - (like double)
PGP Public Key
Date: 1 Jun 2001 23:39:19
Message: <3b185fe7@news.povray.org>
Hmm... I think that's just when there's a series of collisions (so whilst one
ball may gain loads of energy some others should lose it). Every
collision -should- lose a little energy. Still, I'll look for that.
> also noticed
Yup, I spotted that one. it's fixed now :)
Thank you!
Tek
Date: 1 Jun 2001 23:42:21
Message: <3b18609d@news.povray.org>
I would do, but my computer's been having problems recently due to overheating
(one of the many fans broke). I don't fancy leaving it on for too long until
I've fixed it.
Besides, I'm still improving the simulation. I'll do a high-res one once I'm
finished, if I ever am ;)
Tek
Date: 2 Jun 2001 04:43:20
Message: <MPG.1582c587e1cf94489897b5@NEWS.POVRAY.ORG>
In article <3b180dd6@news.povray.org>, Tek says...
OK, I'll stop defending your work in future :)
Regards,  Sander
Subject: bigger version (555k)
Date: 2 Jun 2001 14:03:28
Message: <3b192a70@news.povray.org>
I changed my mind! Here's a bigger render, from a nicer camera angle.
Unfortunately the motion blur isn't quite high enough quality for this
resolution, but other than that I'm very happy with it :)
A change to the physics now means that the balls can escape through the open
side of the box, which means the render has less things to draw, so this 200
frame higher-res version took a /mere/ 6 hours!
Tek
Download 'MOTION.MPG' (556 KB)
Subject: Re: bigger version (555k)
Date: 2 Jun 2001 17:29:42
Message: <MPG.158379281102f28f9897ba@NEWS.POVRAY.ORG>
In article <3b192a70@news.povray.org>, Tek says...
> Tek
Even more impressive! A pity that rendering an animation still is so
very time consuming; I would like to see more of it :)
Regards,  Sander
Date: 2 Jun 2001 19:49:06
Message: <3b197b72@news.povray.org>
Well, I've rigged it up so I can continue renders from any frame. Now I'll just
run it in the background whenever my computer's on :) I'll post the results once
I have some (or a link if the file's too big).
Tek
Date: 2 Jun 2001 20:28:35
Message: <3b1984b3$1@news.povray.org>
That's superb! - fascinating how the balls seem to collect in one corner (or
is that your physics model :)
PGP Public Key
Date: 2 Jun 2001 21:17:44
Message: <3b199038@news.povray.org>
> That's superb!
Thank you!
I think that's just coincedence. I'm continuing the render at the moment, it's
got 36 frames further than the last one I posted, and it looks like that clump
of balls has moved now :)
Tek
Date: 2 Jun 2001 23:44:50
Message: <3b19b2b2@news.povray.org>
Purty!
Date: 3 Jun 2001 01:21:52
Message: <3b19c970$1@news.povray.org>
Liked this thing from the beginning.  Are rotations involved at all?  Seeing
as how several of those fall, bounce off the wall and exit nearly
identically it would seem they don't have rotational friction.  Or at least
not randomized rotation.  Or you already are and I missed that fact.
Bob H.
Date: 3 Jun 2001 07:38:30
Message: <3b1a21b6@news.povray.org>
Nope, you're right. Well spotted. In fact there's no rotation or friction in the
system at all. I figured I could get pretty good results without it.
Tek
Date: 4 Jun 2001 06:00:00
Message: <3b1b5c20@news.povray.org>
Great ... and now, make it loopable ;-)
background{rgb 1}camera{location<1,5,-2>look_at 0}#macro m(a,b,i)#local d=(b-a)
/8;#local e=vcross(d,y);#if(i)m(a-e,a+e+2*d,i-1)m(a+e,a+2*d-e,i-1)m(a+3*d-e,a+e
+3*d,i-1)m(a+3*d-e,a+5*d-e,i-1)m(a+6*d-e,a+e+6*d,i-1)m(a+8*d-e,a+e+8*d,i-1)#else
cylinder{a,b,vlength(d)/3 pigment{rgb 0}}#end#end m(-4*x,2*x,4) // Jan Walzer
Date: 4 Jun 2001 08:09:54
Message: <3b1b7a92$1@news.povray.org>
Very nice!
There is something wrong with that ball, which rests in the corner, while it
got hit by several other balls. It jumps up at the end, but I really think
it should get some impulses from the other balls. Perhaps, it's just me,
though ...
I like the atmosphere of the colors used!
Marc-Hendrik
Tek schrieb in Nachricht <3b192a70@news.povray.org>...
open
200
>Tek
