POV-Ray : Newsgroups : povray.binaries.animations : Re: Gravity Well 3 Server Time
27 Nov 2026 18:01:18 EST (-0500)
  Re: Gravity Well 3 (Message 1 to 24 of 24)
Subject: Re: Gravity Well 3
Date: 1 Jun 2001 09:30:01
Message: <3b1798d9@news.povray.org>
It's looking good.
/* Nekar Xenos */#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);
blob{#while((K-N).x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(
vlength(N-K)<vlength(X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N
,1,1 scale.02}sphere{<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1
scale.01 }#end pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3b179347@news.povray.org...
>     This of course, is our solar system after the Sun has dragged us so much
> closer that the earth has completely fried and only the last traces of
> oxidized copper floating on the molten iron remind us of the blue oceans of
> the past.
>     I intend to get the correct densities and distances today and make the
> whole solar system. Probably with planets artificially enlarged for effect.
Date: 1 Jun 2001 09:41:20
Message: <3b179b80$1@news.povray.org>
effect.
very impressive - much better with the girds
how about making the gravity effects radius larger, so there is a very
slight, yet noticeable impression further away - with perhaps warped rings
appearing round the planets as well as the sun
PGP Public Key
Date: 1 Jun 2001 11:52:28
Message: <3b17ba3c$1@news.povray.org>
news:3b179b80$1@news.povray.org...
the
> effect.
    Actually the planets do have rings that go around their holes, I will
post a more detailed image in pbi. But I would love to make them more
noticeable in the animation. I am trying various things to inaccurately
represent the slope so that it make more visual sense.
Date: 1 Jun 2001 13:01:03
Message: <3b17ca4f@news.povray.org>
Yes, the grid really improves it.  Shows the third dimension better.
I took the snipet of script you posted and made the solar system with
approx. correct masses and distances.  Not much to look at, as you might
guess, because of proportion.
At one point I had a fair gravity well for the Sun when the planets were
closer in and just basically exagerated; it spread wide and shallow.  I
didn't save the setup so now I have to try and go back to that or come up
with some other way.
Used Earth as the basis for units, E=1.  The Sun is so overpowering though
that all the inner planets get engulfed.  The Moon doesn't even show up
within Earth's G-well.
Kept it to a gradient y pigment pattern, just repeated a lot which is part
of the obscuration trouble I think.
I see you have Mars' orbit at 1 revolution to Earth's 2.  I've managed to
get the orbit timings done easily enough but the eccentricity is beyond me
right now so I guessed at it.
As you can tell I'm having fun playing with this sort of thing.
Bob H.
Date: 1 Jun 2001 13:25:44
Message: <3b17d018$1@news.povray.org>
    I find this vastly more interesting than tweaking textures to make the
mountain or the back porch step look "photorealistic".
    I seem to use POV as a cad animation program more than anything else.
Date: 1 Jun 2001 15:05:42
Message: <3b17e786@news.povray.org>
This is very cool.
Is it "mere" rotations, or could you add another particle and have it move just
as if it were a comet under the influence of these bodies?  I tried a technique
that didn't work in creating stable orbits, as it did not conserve energy.
Would such a system conserve energy if one simply moved along at a constant
altitude (no, I don't think so, but how could one do it??)...
> the past.
>    Gwell03.mpg    Type: MPLAYER2 File (video/mpeg)
>               Encoding: x-uuencode
Date: 1 Jun 2001 15:36:52
Message: <3b17eed4$1@news.povray.org>
"Greg M. Johnson" <"gregj;-()56590"@aol.c;-()om> wrote in message
news:3b17e786@news.povray.org...
> This is very cool.
    'Fraid so, I was not intending to model the interactions of the planet's
gravity, but only to display the curvature of space that they cause. I
only -wish- I knew enough to mimic real orbits and gravity...
Date: 1 Jun 2001 15:53:55
Message: <MPG.1582113a1cad53ea9897b0@NEWS.POVRAY.ORG>
In article <3b17eed4$1@news.povray.org>, Bill DeWitt says...
> > This is very cool.
This looks great: how did you get the exact match of the orbits?
I remember a C-program that came with all the sources necessary to
construct a 3-body animation. It could contain the necessara formulas,
but then again I think 3 bodies are not enough for you?
Regards,  Sander
Date: 1 Jun 2001 16:02:06
Message: <3b17f4be$1@news.povray.org>
"Sander" <san### [at] stolscom> wrote ;
    Cheated. They are just arbitrary sin/cos figures.
    Everytime I try to explain this to my wife she gets mad.
Date: 1 Jun 2001 16:23:58
Message: <3b17f9de@news.povray.org>
"Sander" <san### [at] stolscom> wrote in message
news:MPG### [at] NEWSPOVRAYORG...
The galaxy collision program I was trying to convert over from Basic to POV
a while ago does gravity interaction in a sense.  Each particle is the same
mass but I'm sure that is a trivial matter.  The stumbling block was due to
my not knowing how to get the DIM (dimension) arrays changed, among other
things.  Was intended for 2D plotting of the 3D motions.
Really needs to be more a orbit simulator.
Pretty neat web pages here:
http://burtleburtle.net/bob/physics/orbit101.html
Bob H.
Date: 1 Jun 2001 16:45:57
Message: <MPG.15821d668afa8e8e9897b3@NEWS.POVRAY.ORG>
In article <3b17f4be$1@news.povray.org>, Bill DeWitt says...
I should have said: heavenly bodies...
Regards,  Sander
Date: 1 Jun 2001 16:52:58
Message: <3b1800aa$1@news.povray.org>
    That would be even better...
Date: 1 Jun 2001 21:54:07
Message: <3b18473f@news.povray.org>
> Bob H.
When I did a simulation, it looked exactly like the next to last one in the
link you shared here. My simulation was simply my flocking algo:  at time t,
calculate the gravitational forces on every particle, and use this acceleration
to modify the current gravity.  I spent weeks and never got a stable system, I
think, because I didn't conserve energy. This, I think would take calcs at
infinitely small delta t's.   Or maybe something about potential energy,  but
I'm confused.  Your model would never decay, and allow a stray "Jupiter" to
wander into it?  If so, what's the algo?
Date: 2 Jun 2001 04:40:29
Message: <MPG.1582c4e0fd3058929897b4@NEWS.POVRAY.ORG>
In article <3b1800aa$1@news.povray.org>, Bill DeWitt says...
I _knew_ it would :)
Regards,  Sander
Date: 2 Jun 2001 08:33:15
Message: <3b18dd0b@news.povray.org>
    But I should mention that it is not strictly necessary.
Date: 2 Jun 2001 08:47:55
Message: <3b18e07b@news.povray.org>
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:3b18473f@news.povray.org...
POV
the
t,
acceleration
system, I
but
to
Egads.  I never said those were my web pages  :-)  Sorry, I didn't think
about the URL saying "bob" in it.
I can only dream to wish I could come up with the math for those myself.
And the galaxy collision simulation was copied from a magazine years ago.
Bob H.
Date: 2 Jun 2001 09:50:59
Message: <MPG.15830da2f1ae4bc9897b8@NEWS.POVRAY.ORG>
In article <3b18dd0b@news.povray.org>, Bill DeWitt says...
I know...
Regards,  Sander
Date: 2 Jun 2001 12:06:47
Message: <3b190f17@news.povray.org>
I didn't think it was yours.  But if you took the algorithm for your GCS, and
applied it to a solar system, would you get stable orbits?   Mine did not.
Bill's looks supercool but as he says it's just sin & cos.
Date: 2 Jun 2001 13:51:48
Message: <3b1927b4$1@news.povray.org>
    I wonder if you can use trace or something to get the angle of slope of
my isosurface and use that to calculate the speed necessary to maintain
orbit?
Date: 3 Jun 2001 01:07:35
Message: <3b19c617@news.povray.org>
news:3b1927b4$1@news.povray.org...
of
> orbit?
Interesting idea, perhaps so in a reverse way.  You're unlikely to start
with the angle of slope and get to the correct orbital velocities, simply
because that isosurface would be probably be difficult to conform to the
real gravity well(s).  This is all inexact science when dealt with in
POV-Ray I'd say.
Answering Greg, no, I bet it wouldn't remain stable.  The program is based
on going into chaos in the first place, not meant for long duration orbits.
Besides, it's the same case in a way.  You specify mass, velocity and
direction vector.  To me that means hit or miss.  :-)
I think a lot to do with that is why planetary simulators use things like
double precision math and constantly fine-tined equations.
Bob H.
Date: 3 Jun 2001 21:37:20
Message: <3B1AE4C6.F8BCBE0F@yahoo.com.au>
Nice anim. For a really nice effect, try making the surface transperent, keep
the grid (maybe even make it a little finer), and place a starfield in the
background. Have you tried a square grid?
MJL
Date: 3 Jun 2001 22:07:34
Message: <3b1aed66@news.povray.org>
I had the particles operating under a simple attractive force to the sun.  I
then played with hundreds (thousands) of values for the gravitational constant
and tweaks to the starting velocity.
The problem is that instead of calculating the force every "infitesimal"
second, I'd set it up to do say every 10 weeks, 10 days, 10 hours, 10 secs or
whatever.  Consider a rock tied to a string that is swung.  If you tried to
model that system by only applying the force at every *HUNDREDTH SECOND*
instead of CONSTANTLY, then the direction of the force isn't going to be
perfect for keeping it on a perfect ellipse.  Hence as Bob says double
precision and mega crunching to get less orbit decay.  The brick wall I ran
into was being forced into one of these choices:
1)  Sin & Cos and no stray particles, or no shooting stray comets at Earth and
seeing how well Jupiter protects it.
2)  Orbits that decay every "year".
But I'm intrigued that there could be some kind of "field effect" solution that
would be based  on Bill's isosurface.
> orbit?
Date: 3 Jun 2001 22:31:40
Message: <3b1af30c$1@news.povray.org>
"Mark James Lewin" <m_j### [at] yahoocomau> wrote in message
news:3B1AE4C6.F8BCBE0F@yahoo.com.au...
keep
    I tried the square grid and didn't like it, but I should try the
transparent thing, it sounds like it would be cool.
Date: 3 Jun 2001 22:52:05
Message: <3b1af7d5$1@news.povray.org>
    Tried it and didn't like it either. The other edges of the iso shows up.
