POV-Ray : Newsgroups : povray.binaries.animations : Flight: Air turbulence Server Time
13 Oct 2026 00:42:08 EDT (-0400)
  Flight: Air turbulence (Message 1 to 7 of 7)
Subject: Flight: Air turbulence
Date: 31 May 2001 02:54:28
Message: <3b15eaa4@news.povray.org>
Whoops... didn't wanna upload... trying again...
Download 'out.avi.dat' (250 KB)
Subject: Re: Flight: Air turbulence
Date: 31 May 2001 03:01:02
Message: <MPG.15800a8f419ce2bb9897ab@NEWS.POVRAY.ORG>
In article <3b15eaa4@news.povray.org>, PatchWerk says...
OK, got it, sorry!
Regards,  Sander
Date: 31 May 2001 03:04:18
Message: <MPG.15800b5d748bda869897ac@NEWS.POVRAY.ORG>
Maybe a little fast and a bit small, but to me it seems to quite
naturally represent what happens to a plane in bad weather :)
Regards,  Sander
Date: 31 May 2001 06:01:16
Message: <3b16166c@news.povray.org>
"Sander" <san### [at] stolscom> wrote in message
news:MPG### [at] NEWSPOVRAYORG...
I've only flown a dozen times but the turbulence always seemed in a up-down
motion without any sway side to side (guess that would be called yaw in
pilot speak).  That doesn't mean I know if it really does or not.
The motions looked reasonable to me besides, as if a model plane for
example.
Bob H.
Date: 31 May 2001 10:55:56
Message: <3b165b7c@news.povray.org>
up-down
> example.
> Bob H.
Thanks. Actually, I used to fly little single-engine biplanes Waco's, and
they would yaw quite a bit at low level, because of their massive tail
area... and I am exagerrating the motion quite a bit for dranmatic effect. I
just wanted to know if the motions looked natural. Thanks again for the
feedback! =)
Date: 31 May 2001 11:28:06
Message: <3b166306@news.povray.org>
"PatchWerk" <pat### [at] hotmailcom> wrote in message
news:3b165b7c@news.povray.org...
> up-down
> > example.
Okay, I was thinking of jetliners which is what the animation plane reminded
me of (should have realized about the straight wings).  Besides that I'm
always near the wings, probably the pivot point for yaw.  I recall once my
brother told me about a small plane ride in a friends father's plane.
Expressed an opinion of constant movement in every direction, guess that
applies.
For constructive criticism I'll add that maybe you can get some hesitation
into the motion, that would improve it I think.  By that I mean it currently
moves continously in sweeps, so with some near stopping mid-way through a
few of those motions maybe could increase realism.
Should be as simple as using a #switch with #range and making a variable
drop to zero which you'd multiply by your motion equation(s).
#switch (clock)
#range (1/4,1/3)
  #declare V0 = abs(clock*(2/7-clock))
#break
#range (2/3,3/4)
  #declare V0 = abs(clock*(5/7-clock))
#break
Guessing so anyway.
Bob H.
Date: 31 May 2001 11:37:03
Message: <3b16651f$1@news.povray.org>
Uh, nevermind my feeble switch range attempt there.  I can see it would have
to be far more to it first.  Each time it has to start at 1 and subtract to
0 then return to 1 again.  I've done it before but looking for it would
prove futile for the near future.
Bob H.
