Because the glow fire works on a black background only I've had to
experiment with a media solution. This is the result so far. It's not
perfect but it's a start.
Media has both advantages and disadvantages compared to glows. Media works
on all backgrounds but it is also slower. With media one have greater
control over every aspect, but that also make it more difficult to control.
Media is more precise (for example the turbulence is really 3D), but because
of the complexity, errors are also more likely to occur. (There are a few
annoying artefacts in the media in this animation and I don't know what
causes it.)
In this animation I tried placing the fire in a simple scene, and I think it
works well. I also tried attaching a light_source to 20% of the particles
(there are about 30 particles alive at a time), but I don't think it works
particularly well. The fire doesn't flicker enough to the sides to make it
worth while.
Anyway, as always I'd really appreciate your feedback!
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated March 29)
/ Also visit http://www.povrayusers.org
Download 'mediafire.mpg' (164 KB)
Quite impressive, as already said some more fire like structures would be
good, meaning sharper border and somehow more splitting it up into
flames. I don't know if that's practicable with the current particle
system approach.
> worth while.
The moving shadows are looking interesting, maybe radiosity (or even only
radiosity lighting) would be worth trying.
Christoph Hormann <chr### [at] gmx de>
This looks like a gigantic candle. Pretty, though.
Maybe my imagination (it *is* late at night right now), but I think I see a
ghostly face in the top of the flames, just for an instant.Strange artifacts
though.
I wonder what the overall effect would be if you had two or three of these
flames side by side, but close enough to look as though they were part of
the same fire, each having different turbulence settings, and each
interacting. AFAIK, fires like the one in your animation don't have a single
flame 'source', instead having their flames distributed over a circular
area.
Just a thought. Good work.
Andy
"Rune" <run### [at] iname com> wrote in message
news:3acb8527@news.povray.org...
control.
because
> causes it.)
it
> worth while.
> Rune
Good work there.
The lighting has quite a striking effect there. Nice.
Maybe if you add smoke the artefacts wouldn't be so obvious, but that
wouldn't really solve the problem...
Real flames are transparent at the centre. Do you think you could try that?
Nekar
control.
because
> causes it.)
it
> worth while.
> Rune
> causes it.)
Yeah, those artifacts are really strange. You're using a blob, right? Have
you tried looking at the shape of the blob in those frames? Is it really
the media being clear, or is it the media being thin in those spots? For
some reason (shape of the spots?), I think it might be the former, and if
so, that can be fixed. If the latter, maybe different turbulence would
help.
> worth while.
I thought the flickers were really nice, personally, especially on the back
stones.
I agree with others about the multiple sources. That might also help the
flicker. However, when doing multiple sources, overlapping might be a
problem (unless they're a single media object, which might not be too bad)
Also, the flames to the outside get drawn in towards the center somewhat,
which might be tricky to model, although an attraction force between the
particles may be sufficient. In fact, that might be something you want to
do anyway, as the current flame is a little too broad at the top. The point
effect is due to the hottest parts rising faster and the surrounding area
getting drawn in, after all.
Geoff
> structures would be good, meaning sharper border and
> somehow more splitting it up into flames.
I suppose I came closer in the "Glow Fire take 3" approach?
This media is difficult to control! :(
> radiosity (or even only radiosity lighting) would be
> worth trying.
No thanks, not right now.
Radiosity in stills is slow enough for me! ;)
Rune
I'll remember when I need to make a gigantic candle! ;)
Rune
> three of these flames side by side, but close enough to look
> as though they were part of the same fire, each having
> different turbulence settings, and each interacting. AFAIK,
> a circular area. Just a thought.
I'll try some of your ideas.
It should all be possible with just a single emitter though.
> Good work.
Thanks!
Rune
"Nekar Xenos" wrote:
> Good work there.
Thanks!
I'm not quite satisfied with it myself.
Are you sure? I mean, a candle light is, but not a camp fire I believe.
Reference images would be great.
Rune
Yeah.
No. I considered using a blob with a blob_pattern density but had to reject
the idea, as it doesn't allow me to assign separate turbulence to the
individual particles, which I need to.
I'm using a merge of spheres. Inside the merge is a single interior with
multiple media statements, one for each particle.
Using a union of spheres forces a whole lot of samples to be taken because
of the many intersections; that's why I use merge.
When using merge I can't place the media inside the individual spheres (that
doesn't work correctly). So I place all the media statements in the parent
object (the merge).
Using this method is fairly fast.
> especially on the back stones.
I think it would be both faster and prettier to use just one light_source
(possible area_light) and manually moving it around a little and change the
brightness.
Instead of using multiple sources I could use one source that moves around
in a circle really fast (currently possible) or a source that is an object
(not yet implemented).
> when doing multiple sources, overlapping might be a problem
I'm already using overlapping media if that's what you mean, and I've used
it often before. Could that be causing the artefacts?
> center somewhat, which might be tricky to model, although
> an attraction force between the particles may be sufficient.
Sorry, I've decided not to implement any kind of inter-particle forces in my
system.
> In fact, that might be something you want to do anyway,
Real camp fire isn't necessarily cone-shaped is it?
Thanks for the feedback!
Rune
> Yeah.
Ok, I thought those artifacts looked like spherical shapes. I really think
if you do a fast anim of the spheres themselves (opaque, in other words)
that you'll find the same holes in the surface.
Yeah, and it should work, with some fine tuning.
> brightness.
Hmm, maybe take a weighted average of the particles' locations would work.
Ie, weight based upon the strengths (amount of emission) of the individual
bits.
Or maybe use two lights (areas), one large one near the bottom as above, but
one up higher that only uses the highest points. That is where most of the
flicker comes from, anyway.
Same effect, really.
No, the artefacts are caused (well, assuming I'm right) by places outside
the container.
> system.
Drat. :/
Not really, no. More of a teardrop.
Geoff
i like it. except that i think the hotter areas (yellow and white)
would be located 'on' the burning object, not above it. looks great
though!
> causes it.)
> worth while.
> Rune
> mediafire.mpg Type: WMPLAYER File (video/mpg)
> Encoding: x-uuencode
Two here Rune. A street bonfire in Guingamp some years ago.
Hope these are some help.
dav### [at] hamiltonite com
http://hamiltonite.com/
Download 'GuingampFire1.jpg' (78 KB)
Download 'GuingampFire3.jpg' (41 KB)
Preview of image 'GuingampFire1.jpg'
Preview of image 'GuingampFire3.jpg'
With glows it can be reasonably fast. I remember i made a short
animations with glows and radiosity:
Subject: New Glow (296k)
Date: Tue, 12 Sep 2000 16:47:54 +0200
Newsgroups: povray.binaries.animations
I have some bonfire photos on my website too.
Check out the last 5 images here...
http://www.xlcus.co.uk/photos/1999-11-06-fireworks/
TTFN,
Jonathan Hunt
Thanks, they're great reference images!
Rune
> I really think if you do a fast anim of the spheres themselves
> (opaque, in other words) that you'll find the same holes in
> the surface.
No, I think they're caused by a low number of samples being used.
More specifically, one sample...
Good idea! I'll try that.
Exactly.
Well, I think it's often more irregular in the shape.
Rune
"Ryan Constantine" wrote:
> i like it.
Thanks!
I'll try moving the fire a bit downwards.
Rune
Well, I'm not using glows...
Rune
Rune wrote in message <3acceeac$1@news.povray.org>...
>> the surface.
When I first saw the artifacts, it immediately reminded me of a tute on
halos in the 3.0 docs: declaring a halo in a unit sphere with turbulence of
.5 caused artifacts like this. Declaring the container as 1.5 and the sphere
pattern at 1 prevented the clipping effect. IOW maybe your
turb/particle-placement values are extending outside the boundaries of your
merge object. It would make sense since they mostly occur near the top where
you are likely increasing the amount of chaos.
P.S.
The flickering light looked just fine to me as is. <shrug> And yes, it's
still cool!
Batronyx™ ^"^
bat### [at] cadronhsa com
> me of a tute on halos in the 3.0 docs: declaring a halo
> in a unit sphere with turbulence of .5 caused artifacts
> like this.
I should have been more specific. The problem you and others are referring
to is not the same artefacts I'm talking about. What I'm talking about is
some very abrupt transparent cracks and holes in the media.
> Declaring the container as 1.5 and the sphere pattern at
There's probably a bit of the clipping problem too, but that should be easy
to fix, like you describe.
> P.S.
Well, not to me. I'll try a different approach in the next anim.
Rune
