POV-Ray : Newsgroups : povray.binaries.animations : Flowing particles - take two (144kbu) Server Time
27 Nov 2026 18:15:13 EST (-0500)
  Flowing particles - take two (144kbu) (Message 1 to 12 of 12)
Subject: Flowing particles - take two (144kbu)
Date: 17 Mar 2001 17:53:26
Message: <3ab3eae6@news.povray.org>
After having been away from home for a week, I'm back now and I'm working on
my particle system again.
I have made linear interpolation of the particle locations, which means that
the particles now move smoothly also when the calculation frame-rate is not
a multiple of the render frame-rate. For example this animations has a
render frame-rate of 30 frames per clock-unit and a calculation frame-rate
of 20 frames per clock-unit.
This is an advantage for example if you have set up a particle system that
behaves perfectly in your test renders. For your final render you want a
higher render frame-rate but you want the particle system to behave exactly
the same, so you don't change the calculation frame-rate. The particles will
still move smoothly because of the interpolation.
I have also changed this preview animation mainly by using many more
particles, by making the blob elements more blobby and of course by
rendering at a higher resolution.
As always, comments appreciated!
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 28)
/ Also visit http://www.povrayusers.org
Download 'flow2.mpg' (145 KB)
Subject: Re: Flowing particles - take two (144kbu)
Date: 17 Mar 2001 21:44:41
Message: <3ab42119@news.povray.org>
Good work! I'm really looking forward to the code... (This is a subtile
hint.;-) )
Bugs74
"Rune" <run### [at] inamecom> schreef in bericht
news:3ab3eae6@news.povray.org...
on
that
not
exactly
will
> Rune
Date: 17 Mar 2001 21:51:12
Message: <3ab422a0$1@news.povray.org>
looking much better, although i would still say it neads many many more
smaller blobs :)
very impressive how you have managed to get it perfectly cyclic.
does a blobs behavour change acording to its size? - ie smaller blobs
bounder more and higher than larger fatter blobber blobs?
not sure i am 100% keen on the way the blobs stretch out, but maybe thats
just me..
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 18 Mar 2001 04:31:25
Message: <3AB4806E.2801B46C@gmx.de>
Nice, but is a bit unnatural.  The viscosity seems more like honey, but
the flowing behaviour not, honey would flow in lines and not form single
droplets.  Of course that's a matter of inter partcle forces.
It would be nice to see a version, where a lot of additional particles are
added at the between position, something like a still combining all the
particles of all animation steps.
Date: 18 Mar 2001 06:33:13
Message: <3ab49cf9@news.povray.org>
> many more smaller blobs :)
That will be later! :)
Thanks! It was quite a headache to implement, but it seems to work now.
No.
> - ie smaller blobs bounder more and higher than larger fatter
> blobber blobs?
No, but I don't think it would be correct anyway. Theoretically if there's a
large object and a small object with the same "springiness" and the two
objects hit a surface with equal velocity, they should bounce equally much,
shouldn't they?
But anyway, I don't think a particle system can be compared to real water
that directly. Real water doesn't consist of particles. And when a water
drop hits a surface it may divide into several smaller drops and generally
behave in very complicated ways.
I hope my particle system will be cool-looking, but it's not supposed to be
used by scientists! ;)
> maybe thats just me..
Do you mean the pseudo motion blur that stretches out the particles in the
direction of movement? I personally like it, but it can be made stronger or
weaker or turned completely off.
Rune
Date: 18 Mar 2001 06:33:15
Message: <3ab49cfb$1@news.povray.org>
"Bugs74" wrote:
> Good work!
Thank you! :)
> (This is a subtile hint.;-) )
I will release the complete particle system package eventually, but there's
still a lot of work to do before that...
Rune
Date: 18 Mar 2001 09:42:36
Message: <3ab4c95c@news.povray.org>
i can well imagine!
> No.
> > blobber blobs?
a
much,
> shouldn't they?
no, with water there is a sliding scale, large blobs are more likely to
fragment more on impact that very very small droplets witch are more likly
to either bounce almost whole, or simply stick. - this in one of the reasons
that when models are used on films for the obligatoy damn breaking scene it
dosnt look real.
i think in may ways it can be compared, and yours with thousands of
incredably small particals should be quite close (then of course we will
want you to add a detergent feature for froth & bubbles)
be
well, if its any consolation, one of the great unsolved problems are the
mathematical formulas for motion of fliuds like water, and turbulance in
general (hence the continuing use of wind tunnels and smoke) - skicky fluids
(like syrup) are aparently no problem, but you dont get vortex's in syrup :)
or
yes, could you add real mega pov motion blur?
Date: 18 Mar 2001 10:25:20
Message: <3ab4d360@news.povray.org>
> like honey, but the flowing behaviour not
I'm aiming for water, not honey, but I know I'm not very close at this
point.
How can I make it look like the viscosity is like water?
(I know the texture should be different, but I've made it solid in these
test renders so it renders faster and so it's easier to see exactly where
the particles are.)
> additional particles are added at the between position,
> something like a still combining all the particles of
That's just a matter of using more particles. It's a bit slow for my
computer, so I will wait with that for later...
Rune
Date: 18 Mar 2001 11:05:02
Message: <3ab4dcae@news.povray.org>
> likely to fragment more on impact
Yes, but I can't make the particles fragment!
The closest thing I can do is to use so many particles that they blob
together, so several particles look like one big one.
> very very small droplets are more likly to either bounce
When a big water drop fragments into several smaller, do those smaller drops
bounce less than a drop that is small in the first place?
> - this in one of the reasons that when models are used on
> films for the obligatoy damn breaking scene it dosnt look real.
What models and which braking scene???
> > to real water that directly.
> thousands of incredably small particals should be quite close
Hmm, maybe.
> (then of course we will want you to add a detergent feature
That might be difficult. Anyway, what do you mean by front?
No, I think that's impossible since the particles are moved not by the clock
value but by an I/O system. But of course you can use regular post-rendering
motion blur...
Rune
Date: 18 Mar 2001 13:33:42
Message: <3ab4ff86@news.povray.org>
Smoooth... Nice. :) Good job, Rune! I hope you had a great time in France.
Did you see the Eiffel Tower? (You must have... :)
Date: 19 Mar 2001 05:38:19
Message: <3ab5e19b@news.povray.org>
Thank you! :)
Yeah, it was great!
I did see the Eiffel Tower and a bunch of other things and it was very
interesting.
However, there's nothing like sleeping in one's own bed again! ;)
Rune
Date: 19 Mar 2001 17:12:14
Message: <3ab6843e@news.povray.org>
> Yeah, it was great!
Cool!
> of other things and it was very interesting.
Cooler!
Coolest! :)
