POV-Ray : Newsgroups : povray.binaries.animations : Waterfall (119kbbu) Server Time
27 Nov 2026 18:15:16 EST (-0500)
  Waterfall (119kbbu) (Message 1 to 20 of 20)
Subject: Waterfall (119kbbu)
Date: 22 Feb 2001 16:17:39
Message: <3a9581f3@news.povray.org>
Sorry for the simple scene decoration, but I'm too impatient to model
anything great while I'm still experimenting with the particle system
itself.
Anyway, I've made some improvements. The bouncing is better now and I've
improved the emitting method so that it is independent on the calculation
steps.
And then I tried to make the emitting point into a line.
Like my other recently posted animations, this one is cyclic.
Hope you like it!
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 28)
/ Also visit http://www.povrayusers.org
Download 'waterfall.mpg' (114 KB)
Subject: Re: Waterfall (119kbbu)
Date: 22 Feb 2001 16:31:52
Message: <3A958541.E28895D4@gmx.de>
> itself.
> steps.
> Hope you like it!
Yeah, i would really like to see that flowing over a nice isosurface
cliff...
BTW, would it be possible to add some more smaller particles to the
waterfall, that would look more realistic IMO.
Date: 22 Feb 2001 17:51:00
Message: <3a9597d4@news.povray.org>
That's great..the bounce is better. Can any object be used to obstruct the
particles, not just spheres?
Andy Cocker
listen to my music at:
www.mp3.com/lunarland
'I spilled spot remover on my dog. He's gone now. '
'I went to a restaurant that serves "breakfast at any time."
So I ordered french toast during the Renaissance. '
 - Steven Wright.
Date: 22 Feb 2001 22:23:29
Message: <chrishuff-187A2C.22223422022001@news.povray.org>
I'm interested in what you are trying to accomplish...so far, the
particle_system patch can do all of this, and probably faster. Do you
just want a particle system that can be used in ordinary MegaPOV? Or do
you have a specific goal in mind that the particle_system patch isn't
suited for?
Christopher James Huff
Date: 23 Feb 2001 09:10:08
Message: <3a966f40@news.povray.org>
> far, the particle_system patch can do all of this, and
> probably faster.
I've never used the particle_system patch so I don't know much about it's
features. For example I didn't know that the particles could be glows and
that it supported cyclic animation.
> Do you just want a particle system that can be used in ordinary
> MegaPOV? Or do you have a specific goal in mind that the
> particle_system patch isn't suited for?
Since I haven't tried the particle_system patch I don't know if my system
would have any advantages over it. Anyway, my patch will be *mine*, it will
be made my *me*, it will work exactly as *I* want! :)
> I have tried to design my particle system to be as general as
> possible...I've used it for spraypaint, fountains, smoke, fire,
> and snow...
I didn't know that; it sounds interesting. I think the general awareness of
your particle_system patch and its possibilities could be improved if you
posted some animations showing it's various uses. Or maybe such animations
are already available somewhere?
Rune
Date: 23 Feb 2001 09:10:13
Message: <3a966f45@news.povray.org>
Thanks!
> Can any object be used to obstruct the particles, not
> just spheres?
Yes, any object can be used. The object cannot be animated though, as it
will likely cause particles to "fall through" the surface.
Rune
Date: 23 Feb 2001 09:10:14
Message: <3a966f46$1@news.povray.org>
> isosurface cliff...
It doesn't support flowing (not currently at least), it only supports
bouncing.
> particles to the waterfall, that would look more realistic IMO.
Yes, that would be possible.
Rune
Date: 23 Feb 2001 09:41:46
Message: <3A9676A6.8C26E1DB@gmx.de>
> > isosurface cliff...
> bouncing.
It does not need to flow, even if it's not a very steep cliff, bouncing
would perfectly suffice.  As i understand it you could simulate some kind
of flowing by making the particle lifetime high enough and using a high
energy loss when bouncing.
Date: 23 Feb 2001 11:18:43
Message: <chrishuff-3D0320.11174923022001@news.povray.org>
In article <3a966f40@news.povray.org>, "Rune" <run### [at] inamecom>
The particle_system object itself will render as a blob, but you can
easily just use it as a controller for your own particles, and make them
whatever you want. And it doesn't do cyclic animation...that's one
advantage of your include. I'm not sure how I could enable cyclic
animation...
> system would have any advantages over it. Anyway, my patch will be
> *mine*, it will be made my *me*, it will work exactly as *I* want! :)
That's a good reason... :-)
> awareness of your particle_system patch and its possibilities could
> be improved if you posted some animations showing it's various uses.
> Or maybe such animations are already available somewhere?
I posted some images and animations on these groups a while ago, and
somebody used it in an image of some odd robots spraying stuff at a
mutated rug/chicken thing.
Date: 23 Feb 2001 12:25:05
Message: <3a969cf1@news.povray.org>
> > it only supports bouncing.
> cliff, bouncing would perfectly suffice. As i understand
> it you could simulate some kind of flowing by making the
> particle lifetime high enough and using a high energy
> loss when bouncing.
I thought so too at first, but it doesn't appear to work that way. The
particles come very quickly to a complete stop. :(
Rune
Date: 23 Feb 2001 12:57:57
Message: <chrishuff-1BD532.12570223022001@news.povray.org>
In article <3a969cf1@news.povray.org>, "Rune" <run### [at] inamecom>
You need to give the particles a very *high* rebound in order for them
to keep going...I think the only good way to do this will require
inter-particle forces and/or particle-ground forces. I've done a system
like this before which didn't do any collision detection, just
avoidance: I had the ground repel the particles, so they hovered
slightly above it and constantly slid downhill, taking the easiest path.
Date: 23 Feb 2001 14:03:37
Message: <3a96b409@news.povray.org>
Hi Chris, I downloaded MegaPovPlus, the documentation and the sample files.
The executive worked fine, but more than half of the particle_system sample
files generated errors and the help files were in an unknown file format; I
presume they are not for Windows.
Is there any chance of getting the scene files working and have
documentation for Windows made (html will be fine) ?
My cache doesn't go back that far. Is there anywhere else I can see sample
animations?
> and somebody used it in an image of some odd robots spraying
> stuff at a mutated rug/chicken thing.
Yes, I remember that one. By Margus Ramst IIRC.
Rune
Date: 23 Feb 2001 14:24:48
Message: <3a96b900@news.povray.org>
> order for them to keep going...
Yes, but then it wouldn't be flowing.
Not an option in this case.
I've experimented a little with this. So far with no success, but I still
have a few ideas to try out.
Does the particle_system patch support flowing? If yes, how is it
implemented?
Rune
Date: 23 Feb 2001 14:51:59
Message: <chrishuff-AE5FFE.14510023022001@news.povray.org>
In article <3a96b409@news.povray.org>, "Rune" <run### [at] inamecom>
> sample files generated errors
Yeah, I know...I was getting rather sick of the particle system patch,
and didn't have time to even test all the demo files. :-(
I'm writing new ones for the next version, those were more of feature
tests for the in-development versions.
> and the help files were in an unknown file format; I presume they are
> not for Windows.
They are plain text files, the problem is that Mac and Windows have
different line endings.
Well, you can find a decent text editor that can handle the different
line endings, or wait for the new version which will be in HTML to get
around this problem.
> sample animations?
I'll put some more up when I update my web page, sometime soon
(hopefully this weekend). The only images on my web site now are:
http://homepage.mac.com/chrishuff/images/particleFountain.jpg
http://homepage.mac.com/chrishuff/images/particleFountain2.jpg
(and just uploaded this one)
http://homepage.mac.com/chrishuff/images/Particles1.jpeg
Yeah, that's it. Titled "Absurd".
http://www.hot.ee/margusrt/eng/absurd3.html
Date: 23 Feb 2001 14:58:15
Message: <chrishuff-554873.14572023022001@news.povray.org>
In article <3a96b900@news.povray.org>, "Rune" <run### [at] inamecom>
If you have a large enough number of particles, they can appear to flow.
It works best when the particles are going downhill, though. And you
have to start them out close to the ground, and keep the bounce height
from decreasing too much, but if they bounce too high, they won't look
right.
I know...I once did a particle system with inter-particle forces in
plain POV-Script...I gave up after a couple multi-hour *parses*. The
thing was impossible to test, because it took so long to see any results.
I'll look around, maybe I still have that scene file around.
Not yet.
> If yes, how is it implemented?
I'll probably implement a kind of force based on object proximity...that
should allow flowing to work.
Date: 23 Feb 2001 16:21:28
Message: <3a96d458@news.povray.org>
> patch, and didn't have time to even test all the demo files. :-(
Sounds good.
> have different line endings.
That was not the problem, I just didn't know that they were plain text
files, since they had no extensions.
Thanks.
I've been looking at the particle_system patch documentation and I'd say
that my system is currently more flexible. However, when some of your
planned features are added, I think they will be much the same. And your
patch is much faster. But still the "user-interface" is very different and I
personally prefer mine, so I'll keep working on it... :)
Rune
Date: 23 Feb 2001 16:40:32
Message: <chrishuff-282ADA.16393823022001@news.povray.org>
In article <3a96d458@news.povray.org>, "Rune" <run### [at] inamecom>
Oh...file name extensions. Those silly things. ;-)
> say that my system is currently more flexible. However, when some of
> your planned features are added, I think they will be much the same.
In what ways do you think it could be improved? I'm just fishing for
ideas...
BTW, one of the changes I plan on doing is separate environment objects,
each with their own elasticity and other particle interaction
characteristics. You could have portions of what appears to be a smooth
wall but is really a pair of objects, one with more "slippery"
characteristics, the other with "sticky" characteristics, so particles
would stick to some parts of the wall but not others. You could spray
paint the wall and have an invisible message appear.
> And your patch is much faster. But still the "user-interface" is very
> different and I personally prefer mine, so I'll keep working on it...
I'll be interested in the results...
Date: 23 Feb 2001 17:57:03
Message: <3a96eabf@news.povray.org>
in the words of my significant other - looks like slime :)
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 27 Feb 2001 01:30:37
Message: <3a9b498d@news.povray.org>
I think this could work with collision detection.
Date: 27 Mar 2001 09:09:54
Message: <3ac09f32@news.povray.org>
Rune wrote in message <3a9581f3@news.povray.org>...
>Hope you like it!
Oh, yeah!
I got it looping on my other box right now.
You definitely have 'something' happening here.
I have to check your other posts and peoples responses, as
well as your web site.
So much to do and only a lifetime to do it.
Thanks,
Peter
