Ok, this animation was done eintirely in Pov, mostly bu hand. I did use
Moray to help lay some things out, but the objects generated in Moray were
then heavily modified in the pov script. It's a little big, so I'm not
posting here, but giving a URL.
http://darwin.cwru.edu/~wedig/ship/u2.mpg
So, what do people think?
Geoff
"Geoff Wedig" wrote.
OMG. That beats the hell out of my blob & glow starship. Blown away! Took a
while to download on a 56k modem but worth it, that's for sure. Now there's
something for me to aim for
Beautiful! At first when the shield thing started to appear I thought it was
supposed to be re-entry smoke, but then a second later it became more
obvious what it was. It looks great!
-Dave
we think we like it, we think we like it a lot :)
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
I'm really proud of that shield. Was kinda tricky to get right (not really
done, yet. Still some tweaking to do)
Geoff
Entirely done with CSG. No meshes or anything funky. Only non primitive
would be the pods on either side, which are Bez patches.
I'm not good with blobs, and I find they're too slow to render, so I don't
use them much.
Geoff
Took a
there's
> use them much.
Heh, I'm just a newbie at a lot of this. The only Benzier patch I've used
was in the pov help file. Oh well, I'll keep reading and learning. At the
moment I'm trying to do a shuttle craft for the starship.
www.geocities.com/dafrahn/pics/nornfleet2.gif - 159k and a newer look.
The old look was a 759k gif. (it's still up as nornfleet1.gif if you can
spare the bandwidth)
I should start looking through some of the files I've been downloading to
see how things are done.
You're right, blobs can be slow to render, especially on a Cyrix machine. I
do like the smooth, streamlined look, though.
"Rick [Kitty5]" wrote.
Lol, master of the understatement
> Took a
> there's
>> use them much.
I don't hand code beziers like Rune or some others. I use Moray to do that
kind of thing. I do a lot of pre-modelling in Moray. By Pre I mean I set
up basic shapes and positions, but then take what Moray does and hand code a
lot on top of it. Too much of what I do requires Megapov, for instance, or
the ability to do iterations, and the like. But I find Moray really useful
for textures and basic layout of CSG style objects.
At the
There are other ways to get that, though. It's a matter of *how*
streamlined you want things. I think my image is pretty streamlined, though
there are hard edges in places. Working with CSG to get streamlined objects
isn't always easy though, unless you're really good with math.
Geoff
"Geoff Wedig" wrote .
used
that
a
or
useful
Had a look at Moray. I don't know why, but I find wireframes diffcult.
Though I did have a look - there's a pointy shuttlecraft made with a benzier
patch on my art site
to
machine. I
though
objects
True, yours is most definately streamlined :) And CSG would make adding
windows a lot easier, plus a cockpit on smaller craft. They both have uses
Data
Version: 3.12
G!>AT d? s:+ a-- C+++ U?>+++ P? L>++ E? W++ N++ o? K? w+ O! M! V? PS+ PE Y+
PGP t+(++) 5 X+ R! tv- b++(+++) DI-- D+ G e h! r--- y+
http://www.databanks.50megs.com
http://www.geocities.com/dafrahn
Moray 3.3 does opengl previews too.
Bye,
Pabs
> used
> that
> a
> or
> useful
When did you look? Newest version has Open GL support, so wire frames are
only if you want them.
> to
> machine. I
> though
> objects
Well, even if you did something nifty, adding CSG makes it niftier. ;) For
example, no matter how you make your craft, using trace() in MegaPov you can
add windows to it using CSG. That is how HEDay did the Sabotage of the
Lincoln picture, I believe.
Geoff
benzier
Downloaded it in 1999, only just started looking at it in mid-Feb. If I can
learn to use it properly in the next couple of weeks, it'll be my next item
to register.
uses
For
can
Still learning these things. Really, I'm a beginner at raytracing. Only a
year of tinkering when I have time under my belt and finding next things all
the time. Hell, the past year I avoided long renders because yesterday I
finally found out how to set it to resume.
