Very sorry in advance for the sorenson 3 format, but I haven't got
the mpg thing on a Mac down to a science yet...
Here's an animation using MechSim in MegaPov 1.0. I've been having
a great time fiddling around with it. The topology alone uses up a
couple hundred lines of text, but I like the result. For a while, I
thought the bridge would slowly stabalize and just sit there??like a
bridge??but it's so much more interesting this way. :) I guess I forgot
to take into account the lateral stiffness and structure. (I think it's
because of rounding errors since it should be perfectly symmetrical over
the z-axis.) Oh well, as long as no one was on the bridge at the time.
-Ricky
Download 'almostlq3.mov' (379 KB)
That's odd, my --'s seemed to have shown up as ??'s. Whoops.
- Ricky
Girdie!
In article <3e1f8f8f$1@news.povray.org>, Greg M. Johnson wrote:
> Girdie!
Girdie? I'm not familiar with that one...
-Ricky
"Reusser" <reu### [at] chorus net> wrote in message
news:3E1F7C43.A714ADED@chorus.net...
> -Ricky
Well it's not quite Tacoma Narrows... but close :)
On Fri, 10 Jan 2003 20:06:59 -0600, Reusser <reu### [at] chorus net>
wrote:
> For a while, I thought the bridge would slowly stabalize and just sit there??like a
It falls over nicely
Galloping Gertie, I believe Greg was referring to. A suspension bridge in
Tacoma, Washington, USA during the 1940's which waved in the wind until it
broke apart.
http://www.nwrain.net/~newtsuit/recoveries/narrows/gg.htm
I'd have thought it was spelled girdie too, since it is about steel girders.
Apparently the name was borrowed from a poem.
Farewell,
news:100120032134054096%reu### [at] chorus net...
> > Girdie!
> having a great time fiddling around with it. The topology alone uses
> up a couple hundred lines of text, but I like the result. For a
> there??like a bridge??but it's so much more interesting this way. :)
> I guess I forgot to take into account the lateral stiffness and
> structure. (I think it's because of rounding errors since it should
> be perfectly symmetrical over the z-axis.) Oh well, as long as no
excellent stuff - lets just hope thats not fixed in a furture mechsim, can
you imagine the hassle of trying to model a bridge that did that
PGP Public Key
In article <3e2010ce@news.povray.org>, hughes, b.
> broke apart.
Okay, that makes sense. Chalk one up for resonance. Wait, no. I
didn't model a car, man, and *sniff* dog to be on it when it fell. But
I did think of the Tacoma Narrows and wondered how I could have wind
blow across it (like a cloth with a face, wind vector, dot product),
but that would be pretty tricky without altering the source. I was
also trying to think of a way to set a tolerance for each
connection--exceed the tolerance for stress and it disappears. It
would make a lot more sense for it to break as it falls rather than
bend and distort to no end. Just thoughts.
-Ricky
Subject: Re: Suspension Bridge (Sorenson 3)
Date: 11 Jan 2003 11:31:17
Message: <3E2046D5.2D96627A@gmx.de>
Can't view it, sorry.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
In article <3E2046D5.2D96627A@gmx.de>, Christoph Hormann
First of all, THANKS for MechSim. I just love it! Second, I'm sorry
for the format. It's just Apple's Quicktime (v. 5+ I think), but I
know Windows (or just non-mac) people don't particularly like
Quicktime. Can you view regular Sorenson? (not Sorenson 3) I could
repost if that would work. Like I said, I've had bad luck with mpg.
Sorry.
-Ricky
Aha! Searched through old povray.macintosh messages and found the link for
the exporter I had a long time ago. After fiddling with the settings for a
while, I got an acceptable result. Still, it is pretty low-quality since
it's re-compressed. I stand corrected.
I'll also take this opportunity to let any other mac users out there
know that (if you don't already have it) there is a divx codec for OS 9 and
10 at
http://www.3ivx.com/download/macos.html
-Ricky
I never catch on. Here you go.
-Ricky
Download 'almostlq3.mpg' (157 KB)
Date: 11 Jan 2003 13:47:01
Message: <3E2066A4.F34AE00F@gmx.de>
Looks good. Attaching the pillars and the ends of the bridge at the
ground will probably be a good idea. A real world bridge will surely also
fall when it is no more attached to the ground. :-)
This seems to be lacking any fundations. Big blocks of concrete in the
ground might help.
Philippe
