POV-Ray : Newsgroups : povray.binaries.animations : Dini's surface Server Time
1 Nov 2026 10:50:00 EST (-0500)
  Dini's surface (Message 1 to 5 of 5)
Subject: Dini's surface
Date: 20 Aug 2002 12:49:08
Message: <3D6272FF.5C5EF47A@pandora.be>
Dini's surface (or a twisted pseudosphere) is a surface of negative
constant curvature.
The equations depend on two parameters. This animation (animated
giffile) has been obtained by fixing one of the parameters and varying
the second parameter.
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
Download 'dinianimop.gif' (78 KB)
Preview of image 'dinianimop.gif'
Subject: Re: Dini's surface
Date: 20 Aug 2002 13:00:10
Message: <3d62759a$1@news.povray.org>
> constant curvature.
This is beautiful, looks like a flower.
Could you post the function, please?
Sebastian H.
Date: 21 Aug 2002 05:57:22
Message: <3D636407.D98B21D4@pandora.be>
> > constant curvature.
> Regards,
> Sebastian H.
The parametric equations for the Dini surface are:
#declare fx=function(x,y) { a*cos(u)*sin(v) };
#declare fy=function(x,y) { a*(cos(v)+ln(tan((v/2))))+b*u };
#declare fz=function(x,y) { a*sin(u)*sin(v) };
u varies between 0 and 4*pi, v varies between 0.0001 and pi/2.
The parameter b was fixed at 0.2 and the animation was obtained by
varying the parameter a from 0.1 to 1.1.
I didn't use the "parametric" possibilities in Povray 5.5, because I
found the rendering was to slow but furthermore the sharp peak in the
images was cut off. I used the method explained by Tore Nordstand,
http://www.uib.no/People/nfytn/mathgal.htm
using smooth triangles, but adopted his program to use #declare fx =
function.... etc.
I also had to change other thing in his program.
As I'm not at all an advanced user of Povray I had to trie a lot about
placing the camera and the lightsources!
Friendly greetings,
Herman Serras
Gent (Belgium)
Date: 22 Aug 2002 06:51:43
Message: <3d64c23f@news.povray.org>
> function.... etc.
Thanks!
New stuff for some some playaround...
Always a question of how you like it best ;-)
Sebastian H.
Date: 26 Aug 2002 04:01:32
Message: <70ojmuc3trap6b1peb79v3ot0bt7inmoac@4ax.com>
On Tue, 20 Aug 2002 19:02:58 +0200, "Sebastian H." <seb### [at] webde> wrote:
http://mathworld.wolfram.com/DinisSurface.html
ABX
