POV-Ray : Newsgroups : povray.binaries.animations : DivX Encoder? Server Time
27 Nov 2026 16:30:30 EST (-0500)
  DivX Encoder? (Message 1 to 15 of 15)
Subject: DivX Encoder?
Date: 28 Jul 2002 23:26:20
Message: <3D44B749.9000704@faricy.net>
Aargh, where can I get a program to encode a DivX from stills?  Divx.com
is no help, it just points me to programs that AFAIK re-encode existing
videos into DivX.
___     ______________________________________________
  | \     |_         website: http://davidf.faricy.net/
  |_/avid |ontaine           email: <dav### [at] faricynet>
Subject: Re: DivX Encoder?
Date: 29 Jul 2002 02:39:23
Message: <W+FEPUtFEf+3LwwCV5R4LXJYVNcv@4ax.com>
On Sun, 28 Jul 2002 22:32:25 -0500, David Fontaine <dav### [at] faricynet>
>videos into DivX.
If they're BMP's, you can do it with VirtualDub
http://www.virtualdub.com
(Other still formats don't appear to be supported, although it can take
various types of movies for input as well)
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xlsior.org
Date: 29 Jul 2002 07:01:46
Message: <3d45209a$1@news.povray.org>
"Marc van den Dikkenberg" <exc### [at] xs4allnl> wrote in message
news:W+FEPUtFEf+3LwwCV5R4LXJYVNcv@4ax.com...
'HOW' do you do it with VirtualDub? I'd like to know. Please share your knowledge on
the
subject.
I use VideoMach www.gromada.com. Will output in lots of formats, not just AVI
All the best,
Andy Cocker
Date: 29 Jul 2002 08:26:04
Message: <3d45345c$1@news.povray.org>
I use VideoMach as well.  Supports lots of input and output formats, easy to
use and very versatile.
-tgq
Date: 31 Jul 2002 11:59:25
Message: <3d48095d@news.povray.org>
> your knowledge on the subject.
Couldn't be easier. What I do is use Bink and Smacker
(http://www.radgametools.com/) to convert my POV-rendered PNG files to an
uncompressed AVI. Then I open that in VirtualDub
(http://www.virtualdub.org/). I apply any filters I might want, specify No
Audio, and then I set the compression settings. First, I pick "2-pass, first
pass", and apply some settings I'm happy with (http://www.doom9.org/). After
OKing everything, I save the file, making sure to defer processing for
later. This puts it in the job control list. Then I go back into the
compression settings and pick "2-pass, second pass". Save (deferred) again.
F4 for job control, hit Start, sit back and wait. When done, I delete the
original AVI and any stray files Divx left behind while encoding.
I hope that was clear. :) It has become quite routine for me.
Anthony
Date: 31 Jul 2002 13:18:20
Message: <3D481BC3.53541C77@209software.com>
WARNING: I downloaded a DIVX player and it put GATOR SPYWARE on my machine.
> videos into DivX.
Date: 31 Jul 2002 13:44:21
Message: <3d4821f5$1@news.povray.org>
Yes that's easy, but you can do it directly in Virtual Dub: Use the "logo"
filter to add a full screen BMP logo, select no transparancy, and select
"animation" with duration of 1 frame per BMP file.. Name the BMP files like
this:
etc.. The important thing is just to use 4 digits at the end of the name..
That's easy and you can output directly to Mpeg4.
Hugo
Date: 31 Jul 2002 16:18:41
Message: <3d484621$1@news.povray.org>
Thanks Hugo, that will save me having to generate uncompressed AVI first (although it
will
mean me rendering my images in bmp format, rather than space-saving png).
All the best,
Andy Cocker
"Hugo" <hua### [at] post3teledk> wrote in message news:3d4821f5$1@news.povray.org...
> this:
> Regards,
> Hugo
Date: 31 Jul 2002 16:21:12
Message: <3d4846b8$1@news.povray.org>
Thanks Tony, but that's not what I was asking (see Hugo's post). I already perform the
uncompressed AVI using VideoMach, and it was that step that I was hoping to make
redundant.
However, your answer was interesting regarding using a second pass for DivX encoding.
I shall
have to give that a try.
All the best,
Andy Cocker
"Tony[B]" <ben### [at] catholicorg> wrote in message news:3d48095d@news.povray.org...
> Anthony
Date: 31 Jul 2002 16:26:08
Message: <3d4847e0@news.povray.org>
Yes, it will, but you can safely remove/disable it by following the link here:
http://forum.doom9.org/showthread.php?s=fc9524abe613debfc536fd7fd1df4020&threadid=19583
All the best,
Andy Cocker
"Bryan Valencia" <bry### [at] 209softwarecom> wrote in message
news:3D481BC3.53541C77@209software.com...
> > videos into DivX.
Date: 31 Jul 2002 22:23:27
Message: <3D489D0C.4070603@faricy.net>
 > machine.
I got the regular DivX stuff and I have no reason to believe it put
spyware on my machine.  DivX Pro does, but it says it does, so there's
really nothing to complain about.
Date: 31 Jul 2002 22:37:58
Message: <3D48A073.9080001@faricy.net>
Well, I tried VideoMach, it seems like a great program, but I can only
use it for 30 days and then I have to buy it.  Might have another look
at VirtualDub, but it can't read my mpegs made by cmpeg or mpeg2encode.
As for the DivX codec itself, I was greatly disappointed by the quality
and size of the animations it produced, regardless of the settings,
especially compared with what cmpeg can output in plain mpeg-1.  I got
by far the best results with Indeo, but all the codecs seem to lack the
sort of options a program like cmpeg has, where it can make better
quality animations at the expense of processing time.  Even with DivX on
"slowest" encoding and 2 passes, Video Mach whipped through 160 frames
in a few seconds, and, not to my surprise, the animation was huge and
ugly.  I may just stick with cmpeg.
Date: 1 Aug 2002 01:42:34
Message: <3d48ca4a$1@news.povray.org>
news:3D4### [at] faricynet...
> Even with DivX on "slowest" encoding and 2 passes, Video Mach
> whipped through 160 frames in a few seconds, and, not to my surprise,
> the animation was huge and ugly.  I may just stick with cmpeg.
http://www.tmpgenc.net/e_main2.html with the plug-in for PNG is a nice
solution.  The plugin is in the p.b.u newsgroup  3a82f26c@news.povray.org
Date: 1 Aug 2002 10:53:39
Message: <3d494b73@news.povray.org>
You can only use it for non commercial use after the 30 days.
Date: 24 Sep 2002 12:48:36
Message: <3d909764@news.povray.org>
Or even easier, just load the first .bmp and VirtualDub will load in the
rest, set you frame-rate in Video options, select your encoding method
(1-pass quality based with quantizer set to 3.5 (95%) gives small and good
looking files (mostly, experiment with the divx settings to find the optimal
for your anim). Then just save as .avi!
like
> this:
> Regards,
> Hugo
