POV-Ray : Newsgroups : povray.binaries.animations : Fun with mirrors (174kb) Server Time
1 Nov 2026 11:35:40 EST (-0500)
  Fun with mirrors (174kb) (Message 1 to 24 of 24)
Subject: Fun with mirrors (174kb)
Date: 15 Jul 2002 01:14:57
Message: <3D325B36.3010709@yahoo.com.au>
Just mucking about with trace. Enjoy.
MJL
Download 'laser1.mpg' (174 KB)
Subject: Re: Fun with mirrors (174kb)
Date: 15 Jul 2002 02:42:29
Message: <3d326ed5@news.povray.org>
I don't think a laser ray casts a shadow.
Date: 15 Jul 2002 02:59:18
Message: <3D3272C6.50737CBF@gmx.de>
Maybe try using photons...
Last updated 12 Jul. 2002 _____./\/^>_*_<^\/\.______
Date: 15 Jul 2002 04:11:04
Message: <7r05ju4oqcjeq3konij6ckhm379keru0o5@4ax.com>
On Mon, 15 Jul 2002 15:18:46 +1000, Mark James Lewin
Cool... but no_shadow would really help :)
Peter Popov ICQ : 15002700
Date: 15 Jul 2002 13:02:02
Message: <puqJ0HAkppM9EwaU@econym.demon.co.uk>
Should laser beams cast shadows?
Mike Williams
Gentleman of Leisure
Date: 15 Jul 2002 17:35:14
Message: <3d334012@news.povray.org>
That's pretty original, nice! Well, I had to view it several times to really
catch the laser.. I'd like to see this animation on a darker background (the
plane) and a stronger laser - that actually looks like 'light'.. And a bit
bigger resolution.. But then I'll probably save the anim to my personal
"hall of fame" !  ;o)
Hugo
Date: 15 Jul 2002 19:04:44
Message: <3d33550c@news.povray.org>
> Enjoy.
I sure did :) That was fun!
-Peter
Date: 15 Jul 2002 20:09:56
Message: <3d336454$2@news.povray.org>
very nice, quite captivating :)
PGP Public Key
Version: 6.0.373 / Virus Database: 208 - Release Date: 02/07/2002
Date: 15 Jul 2002 21:06:06
Message: <3D337268.5040401@yahoo.com.au>
Photons and media is much slower than using trace to place a few cylinders. I
tried that approach a while ago but couldn't stand the render times.
MJL
> Christoph
Date: 15 Jul 2002 21:06:38
Message: <3D33728A.5030105@yahoo.com.au>
Thanks.
MJL
Date: 15 Jul 2002 21:08:10
Message: <3D3372E5.2020600@yahoo.com.au>
Thanks. I re-rendering to remove the laser shadow. The laser is also stronger and
the resolution slightly higher (still mpg though). I'll post when finished.
> Regards,
> Hugo
Date: 15 Jul 2002 21:08:35
Message: <3D337300.9050508@yahoo.com.au>
Peter Hertel wrote:
>>Enjoy.
Glad you liked it!
MJL
Date: 15 Jul 2002 21:09:04
Message: <3D33731E.6020202@yahoo.com.au>
Cheers!
MJL
Date: 16 Jul 2002 00:38:06
Message: <3d33a32e@news.povray.org>
Sweet deal!  How about with radiosity and a high ambient on those cylinders?
A setup like this with a story/concept behind it would have made a great
entry in the overly complicated machines IRTC round.  Looking forward to the
updated version.
Skip
Date: 16 Jul 2002 00:56:35
Message: <3D33A863.5000807@yahoo.com.au>
Thanks!
MJL
> updated version.
> Skip
Subject: Fun with mirrors 2 (279kb)
Date: 16 Jul 2002 01:03:23
Message: <3D33A9EF.3050507@yahoo.com.au>
POV-Physics 6.5.9.6 - Fake laser beams will cast shadows unless created with
no_shadow sources... doh. Thanks to everyone who pointed that out.
Here is an update, no shadows, slightly higher resolution.
MJL
Download 'laser3.mpg' (279 KB)
Subject: Re: Fun with mirrors 2 (279kb)
Date: 16 Jul 2002 03:50:39
Message: <3d33d04f@news.povray.org>
I saved it.  :o)  It's better, but still doesn't really look like 'light'..
But how did you calculate the position of the mirrors?
Hugo
Date: 16 Jul 2002 10:01:44
Message: <3d342748$1@news.povray.org>
No.  Light will not block the passage of light.
Cheers!
Chip Shults
Date: 16 Jul 2002 14:28:53
Message: <3D3465E0.9030001@caltel.com>
Neat animation. Did you use two trace statements to get the beam to
bounce off the mirrors and stop at the more diffuse objects?
I've got a couple suggestions, since the beam is a little hard to see:
  -dim the lights in the room
  -give the cylinders an emitting media with a cylindrical density. The
density pattern can be rotated using the Reorient_Trans macro, I think.
Now if you're a real glutton for punishment, you can introduce convex
mirrors and substitute some of the cylinders for cones :)
> with no_shadow sources... doh. Thanks to everyone who pointed that out.
> MJL
Samuel Benge
sbe### [at] caltelcom
Date: 16 Jul 2002 20:38:24
Message: <3D34BD68.5010407@yahoo.com.au>
I know :-( This was meant to be a quick experiment, but maybe I'll try to improve
the laser beam.
Most were easy (90 degree deflections). The others used simple trig.
MJL
Date: 16 Jul 2002 20:43:37
Message: <3D34BEA1.9020002@yahoo.com.au>
Yes, pretty much.
I thought of doing that, but this was meant to be just an hour or so of
entertainment. I'll see if it improves things though.
Ha! If you do this, you may as well shoot photons and ditch the cylinders
altogether. You could use lenses then too.
Date: 17 Jul 2002 13:41:23
Message: <3d35ac43$1@news.povray.org>
Cool. Isn't it supposed to explode at the end?
or is that just all the more S for your ER?
Date: 19 Jul 2002 03:22:06
Message: <Mbw3PSWDONM9w+QTzXQNgbRxC8=U@4ax.com>
On Tue, 16 Jul 2002 15:06:55 +1000, Mark James Lewin
Looks good -- although it seems to me like the laserbeam is hitting the
little mirror on the center left for quite a while without a reflected beam
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xlsior.org
Date: 19 Jul 2002 03:22:07
Message: <erw3Pdjo5jPu1WMQ5UF4B43Facea@4ax.com>
On Wed, 17 Jul 2002 13:40:17 -0400, "Greg M. Johnson"
It it would be powerful to explode something at the end, it wouldn't be a
very smart idea to reflect it straight back at the laser emitter, like it
does at the very beginning of the animation. :-)
