POV-Ray : Newsgroups : povray.binaries.animations : balls 4x4x4 grid (249+198k) Server Time
1 Nov 2026 11:34:37 EST (-0500)
  balls 4x4x4 grid (249+198k) (Message 1 to 13 of 13)
Subject: balls 4x4x4 grid (249+198k)
Date: 2 Jun 2002 05:40:10
Message: <3CF9E7F2.777F427@gmx.de>
I tried some larger grids of masses with my simulation system.  It of
course takes much longer, several hours on an Athlon 1 GHz.
ball_sim10.mpg shows what happens if you decrease the connection stiffness
too much.  The grid is not self stabilizing under extreme deformations.
Adding 3d diagonal connections might help, but this would slow down
calculations even more.
Last updated 02 Jun. 2002 _____./\/^>_*_<^\/\.______
Download 'ball_sim9.mpg' (249 KB) Download 'ball_sim10.mpg' (198 KB)
Subject: Re: balls 4x4x4 grid (249+198k)
Date: 2 Jun 2002 08:46:43
Message: <3cfa13b3@news.povray.org>
sim9 - 'crump'
sim10 - 'flumpfppfpfffffff..'
PGP Public Key
Date: 2 Jun 2002 08:49:08
Message: <3cfa1444@news.povray.org>
This is all very impressive, but I'd rather see a regular box dropped,
or a dice or similar, which doesn't deform. Oh, and something which
isn't cubic would be interesting too! :)
Few things we know from our everyday behave like gel...
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated May 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 2 Jun 2002 09:53:59
Message: <3cfa2377@news.povray.org>
If you want to do some bigger things like this you'll have to port your
scripts from SDL to something faster like C/C++ or something else.
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Date: 2 Jun 2002 10:34:34
Message: <3cfa2cfa@news.povray.org>
I really like this. Again, it would be interesting if you replaced this with
a mesh so we could see the box shape more clearly. I really like #10. That's
what I expected to happen to #9. :)
Date: 2 Jun 2002 10:42:38
Message: <3cfa2ede@news.povray.org>
> if you replaced this with a mesh so we could see
Or in the case of a 4x4x4 grid: 6 bicubic patches. Should look fun... :D
Rune
Date: 2 Jun 2002 12:05:52
Message: <3CFA425F.B6F30166@gmx.de>
Thanks.
More complicated shapes are just a matter of creating their starting
geometry, no deformation at all is impossible with this approach, few
deformation usually requires accurate computation but I will try something
like that.
Date: 2 Jun 2002 12:08:33
Message: <3CFA4301.E8DCCD39@gmx.de>
I know, but i would lose the possibility to rely on POV-Ray for generating
the enviroment collisions when having a separate program.  I probably will
wait until i get the source of POV-Ray 3.5 and make a patch...
Date: 2 Jun 2002 12:11:23
Message: <3CFA43AB.69B8FA1C@gmx.de>
"Tony[B]" wrote:
> I really like this.
Thank you.
I'm working on that, it will also be helpful for collision calculations to
have the outline mesh.
Date: 2 Jun 2002 12:15:11
Message: <3cfa448f@news.povray.org>
#10 won't look so good with a mesh. If you look closely you'll see that the
most contorted part of the cube becomes inverted (inside-out).
Apache
ICQ: 146690431
Date: 2 Jun 2002 15:06:47
Message: <Xns9221D6C7D3ED3gergelyvamoraviaitco@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3CF### [at] gmxde:
Hmm, my 5x5x5 piece renders significantly faster. But it does look good.
I believe the cause of this might be the way your system handles
connections, but I can't be sure until I see the source. :)
Cheers,
Gergely
Date: 2 Jun 2002 15:39:22
Message: <3cfa746a@news.povray.org>
> that the most contorted part of the cube becomes inverted (inside-
> out).
Hm. You're right. But if we knew where the outline/border of the box is, it
could be used for self collision detection.
Date: 2 Jun 2002 16:19:25
Message: <3CFA7DC9.AF6D2933@gmx.de>
Thanks.
The main influence factor is the number of integration steps.  I used 30
per frame with a Heun integration method (i.e. 2 evaluations per step).
