looping with friction (243879bytes) (second try) (Message 1 to 7 of 7)
Subject: looping with friction (243879bytes) (second try)
Date: 28 Aug 2001 14:54:18
Message: <3B8BE80B.6ABE0047@gmx.net>
I had a bit time to work at my sliding-macro. It now supports friction
and tests if the slider leaves the surface.
Source is in p.t.s-f
(I hope it works this time.)
(Sorry if this comes in HTML.)
- Micha
In article <3B8BE80B.6ABE0047@gmx.net>, Micha Riser says...
> I had a bit time to work at my sliding-macro. It now supports friction> and tests if the slider leaves the surface.> > Source is in p.t.s-f> > (I hope it works this time.)> (Sorry if this comes in HTML.)> > > - Micha
This is very realistic, the movement and the path the objects take! Is
it to be expected theoretically that the first and second object reach
the ground at the same time?
Regards, Sander
Subject: Re: looping with friction (243879bytes) (second try)
Date: 28 Aug 2001 16:01:04
Message: <3b8bf880@news.povray.org>
Sander wrote:
> > This is very realistic, the movement and the path the objects take! Is> it to be expected theoretically that the first and second object reach> the ground at the same time?
No, they do not and there is no reason why they should do. If the one which
passes the looping had a much higher velocity it would much earlier reach
the ground.,
- Micha
Date: 28 Aug 2001 18:08:32
Message: <3b8c1660@news.povray.org>
Worked fine for me this time. Really interesting anim - I was wishing they'd
bounce when they hit the floor ;-)
Andy Cocker
"Micha Riser" <mri### [at] gmxnet> wrote in message
news:3B8BE80B.6ABE0047@gmx.net...
> I had a bit time to work at my sliding-macro. It now supports friction> and tests if the slider leaves the surface.>> Source is in p.t.s-f>> (I hope it works this time.)> (Sorry if this comes in HTML.)>>> - Micha>
Date: 29 Aug 2001 00:58:54
Message: <3b8c768e@news.povray.org>
A nice image moving around then incrementing onto next! Or....ANIMATION
Sorry ;-)
Andy Cocker
"Bob H." <omn### [at] msncom> wrote in message
news:3b8c704f$1@news.povray.org...
> Wow, yet another totally interesting POV-Ray animation! Or... YATIPA>> Bob H.>>>
Date: 29 Aug 2001 03:39:36
Message: <3b8c9c38@news.povray.org>
"Andy Cocker" <big### [at] mariner9fsnetcouk> wrote in message
news:3b8c768e@news.povray.org...
> A nice image moving around then incrementing onto next! Or....ANIMATION>> Sorry ;-)
Better be.
