The etiquette around here is to post in MPG-1.
I dl'ed your file but Quicktime only showed me white space.
Nikodemus Siivola wrote:
> paperplane2.avi Type: AVI (video/avi)
> Encoding: x-uuencode
Subject: Re: Animated paperplane v0.1 - paperplane2.avi (1/1) - folding.mpg (0/1)
Date: 26 Feb 2001 14:49:43
Message: <3a9ab231.15612347@news.povray.org>
"Greg M. Johnson" <gre### [at] my-dejanews com>:
Ooops... here comes mpeg1 - actually a different, IMO better version.
(Cancelling the AVI.)
-- Nikodemus
Subject: Re: Animated paperplane v0.1 - paperplane2.avi (1/1) - folding.mpg (1/1)
Date: 26 Feb 2001 14:49:59
Message: <3a9ab373.15933411@smtp.hut.fi>
Download 'folding.mpg' (233 KB)
In article <3a9ab231.15612347@news.povray.org>, tsi### [at] cc hut fi
Ah, thanks!
I was also unable to view the previous version, but people didn't seem
to like it much when I said something about it before, so I didn't say
anything.
How did you do the folding? Nested unions of triangle objects, or a mesh?
The only practical way of managing mesh triangles that I can think of
would be to use declared transformations and the vtransform() function
in MegaPOV...is this what was done?
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
Date: 26 Feb 2001 17:14:01
Message: <3a9ad1f8.23747989@news.povray.org>
On Mon, 26 Feb 2001 16:42:50 -0500, Chris Huff <chr### [at] mac com>
Basically,
1. Declare control points in plane
2. Manipulate control points (folding macros based on vaxis_rotate()
and stuff.
3. Declare mesh with triangles composed of control points
The .inc file is in povray.text.scene-files, but I cannot wouch for
it's readability - did a little cleaning up before posting, though.
The folding macros do all the real work. Additionally, there is a
little cheat that applies to two control-points: if they have negative
x-coordinates, their x-coordinates are set to 0 - just to keep the
paper from "tearing".
However, for the past hour I have been thinking of another mehtod:
1. Declare folds (just degrees for each known fold).
2. Declare control points using folds as parameters.
3. Declare mesh with triangles composed of control points.
Kind of neater, I think. Maybe for the next paperfolding thing I
make... I'll have to look into it.
Yours,
-- Nikodemus
Subject: Re: Animated paperplane v0.1 -- 3 attachments (65KBU)
Date: 26 Feb 2001 20:16:08
Message: <3A9AFF6D.BC7DD671@xs4all.nl>
I did a similar thing some time ago.
I've attached some small examples.
Apologies for the awful quality but
the first AVIs were a bit too large
for my taste and when I converted
those to MPEGs they were half the
size but had similar quality to
these AVIs which are in turn less
then half the size of the MPEGs.
If the codec is a problem I could
post the larger (file) versions .
Since I needed to have images on both
sides I couldn't use a mesh (or at
least I didn't know how), so I used a
thin box with imagemaps, cutting and
folding. This is a recursive process
(isn't it?) and it took ages to render.
Come to think of it, I believe I
posted a message about this before...
Remco
http://www.onwijs.com/
Download 'pplane1.avi.dat' (17 KB)
Download 'pplane2.avi.dat' (26 KB)
Download 'pplane3.avi.dat' (22 KB)
Date: 27 Feb 2001 13:47:39
Message: <3a9bf64b@news.povray.org>
Nice ...
A bit of a strange thing happened to my player though:
When I clicked the first AVI, my machine connected to microsoft, and after a
couple of minutes said:
"Cannot play back the video stream: no suitable decompressor could be
found."
I tried again, it did the same. I tried a third time, same response.
So I clicked on your second AVI. It connected to microsoft and installed me
a new Codec. The AVI played fine. I clicked on the third AVI ... Fine.
I clicked on the first again, it plays now.
? Microsoft site busy ? or damaged codec name in PPLANE1.AVI ?
N.B. I didn't have to download a Codec for you previos post.
Clever animation though, and whatever the problem was, I appear to be able
to play them all now.
Duncan Gray
(warning: may contain traces of nut)
In article <3A9AFF6D.BC7DD671@xs4all.nl>, Remco de Korte
These are unviewable on my system, how big are the MPEGs? Are they
really 4 times as big? Maybe it's the software or settings you are using.
I haven't found any good software for creating MPEGs on a Mac, I'm stuck
with QuickTime MooV format (which is a good format, but only available
for Mac and Windows). I don't know anything about the Windows software
available...
Date: 27 Feb 2001 16:38:57
Message: <3A9C1E48.F3403C84@xs4all.nl>
> available...
Of course I exaggerated, the MPEGs aren't
really 4 times as big (more like 3 times).
There was also the point of the strange
formats. MPEG did some weird thing to the
edges which makes the result look even
worse.
I didn't want to post 3 200K AVIs which
looked very acceptable and DivX didn't
help much but this Intel Coded (263 I
believe) shrank the sizes so incredibly
I thought I'd give it a try.
Anyway, I've attached one MPEG.
Remco
Download 'pplane1.mpg' (46 KB)
Remco de Korte <rem### [at] xs4all nl> wrote in <3A9AFF6D.BC7DD671@xs4all.nl>:
Dunno if it is the codec or my computer, but unfortunately I was unable to
view these...
I think that with MegaPOV you could, since all the triangles should have a
normal vector - and therefore you could use the inside texture thingie. I
think. Haven't tried.
Actually, it could possibly be done with meshes even in normal POV-Ray, but
it would have been a bit messy: You can apply textures to individual
triangles, just make a "hollow" paper, where the top and bottom surfaces
meet only at folding points, and are something like 0.000001 apart at
maximum.
Darn I hope I could see this. Before I decided to go the mesh-route I was
considering something similar, along with a plenty of other options. How
did you handle the points where the paper is folded several times over the
same spot?
Yours,
-- Nikodemus
Date: 27 Feb 2001 18:09:23
Message: <3A9C3389.D6DF4BE7@xs4all.nl>
> view these...
I have already posted an mpeg version.
I didn't really remember what codec I used.
I created the AVI with Fast Movie Processor
and I just found it also supports the (a?)
MPEG4-codec. It could just be I used this,
but FMP gave the file an AVI extension just
as well. Perhaps you can view the files if
you change the extension?
Me neither. At the time I made this I didn't
have MegaPov yet.
> maximum.
The problem with this approach is that you can
have folds crossing each other so it would be
rather difficult to calculate the triangles
(at least to me).
> same spot?
That's the problem. What I did was a more or
less recursive process. You start out with a
thin box, cut it in half and fold them on top.
Then you take this result, cut it in two parts
and fold those together, etc. Obviously with
only a few folds this will result in a whole
clutter of CSG for POV-Ray to wade through.
Anyway, I did get the imagemaps right and that
was the whole point.
There is something else, which I saw you also
handled really well: the thickness of the
paper and the room between folds. I don't know
how you did it but it took me quite some
trial and error to get it right.
> Yours,
> -- Nikodemus
Kind regards,
Remco
In article <Xns90567D065894tsiivolacchutfi@204.213.191.228>,
> have a normal vector - and therefore you could use the inside texture
> thingie. I think. Haven't tried.
The interior_texture feature should work fine with triangles, the side
that is "outside" or "up" is determined by the order of the vertices. As
I recall, "up" is the direction from which the points wind clockwise.
I cannot really claim to know this stuff - like I mentioned, the paperplane
was my first animation (discounting the tutorial) - but try VideoMach. It
is a successor of the Fast Movie Processor, and it supports .png as input
format, and mpeg1 (among others) as output. And most importantly for me
it's easy to use...
>> POV-Ray, but it would have been a bit messy: You can apply textures to
>> individual triangles, just make a "hollow" paper, where the top and
>> bottom surfaces meet only at folding points, and are something like
>> 0.000001 apart at maximum.
>(at least to me).
What I did was first fold the a real paperplane, unfold it and draw the
creases on graph paper. Then it was time for some head-banging and
trigonometry to find out the points where the creases cross each other or
the edge of the paper. This process was much aided by rendering each
relevant set of triangles (one set per area delimeted by creases) in a
different color while having the "paper" in it's unfolded state. Easy
visual verification for having the points right.
Thanks! It wasn't the hard part, really. Once I had the points (vectors)
declared I used a simple macro to rotate the relevant points around the
fold-lines. The hard part was the topology of the paper: which fold folds
when, where and around what.
Also, I cheated:
A) only the "right" side of the plane is really modelled, the left side is
just a copy of the right scaled <-1, 1, 1>. B) a couple of points along the
center-line are checked to see if they have crossed to the wrong side. If
they have, they are returned to the center line. If I didn't do this the
paper would "tear" on a couple of points.
Yours,
-- Nikodemus
Thanks! Will have to try.
- Nikodemus
<3A9C3389.D6DF4BE7@xs4all.nl>:
Was finally able to view it: very nice! I can see why you wanted it done
with pigments...
- Nikodemus
Date: 28 Feb 2001 09:09:20
Message: <3A9D0675.BC87BFAE@xs4all.nl>
> Also, I cheated:
> Yours,
> -- Nikodemus
Cheater! 8)
It's a good trick, though. I was glad I figured out how to do it the hard way
and after that I could leave the rest up to my system (which needed a couple of
days to render the whole bunch).
BTW the method I used wasn't really very hard once I figured out how to do it.
Just find the line on which to fold, cut the model and rotate the parts around
this line. I also figured out how to more or less automate the correction for
the thickness of the paper. It's the long render times that were a problem
during the tests.
Remco
