POV-Ray : Newsgroups : povray.binaries.animations : wripple (124k bup) Server Time
7 Apr 2026 20:08:02 EDT (-0400)
  wripple (124k bup) (Message 11 to 13 of 13)
Subject: Re: wripple (124k bup)
Date: 2 Feb 2001 06:31:03
Message: <3a7a9a77@news.povray.org>
Remco de Korte schrieb in Nachricht <3A7A893D.1E61F9DA@xs4all.nl>...
>I may use this in a larger scene (animated) so I'm sure I'll optimize it a
bit
>in that case, but I'm also considering using heightfields.
I don't know for sure, but does the new pattern image type work with
function-pigments? If so, you could generate the heightfields for the
animation "on the fly" with the formulas you have here. Should be faster
than an isosurface, shouldn't it?
Marc-Hendrik
Date: 2 Feb 2001 08:39:40
Message: <3A7AB70D.88F9C72E@xs4all.nl>
> bit
> Marc-Hendrik
If I use heightfields I'll generate them with an external program. That'll take
only seconds.
Remco
Date: 3 Feb 2001 06:33:46
Message: <3A7BEC8E.92E473FC@xs4all.nl>
Oopsie!
I accidentally posted the wrong isosurface from the wrong source. I just noticed
it now when I wanted to use it.
Here is the original (non optimized) code:
isosurface{
  function{
    y*(1
      +sin(x+z+sin(x)-clock*pi/8)
      *sin((x+z+cos(x)-clock*pi/8)*2)/2
      +sin(x*.75+z*.5+sin(x)-clock*pi/16)/4
      *5
      +noise3d(x+z,y*2,z)/2
  threshold 1 sign 1
  bounded_by{ box{<-20,-12,-20><20,12,40>} }
  pigment{rgbt<.2,.7,1,.5>}
//  pigment{rgb 1}
  finish{phong .7 phong_size 120
  reflection .5
  brilliance 4
Sorry,
Remco
