POV-Ray : Newsgroups : povray.binaries.animations : Problem? Server Time
27 Nov 2026 19:01:13 EST (-0500)
  Problem? (Message 1 to 16 of 16)
Subject: Problem?
Date: 7 Sep 2000 18:28:48
Message: <39b816a0@news.povray.org>
I am having some sort of problem with VideoMach. I can't see but half of the
frames in this animation. It seems to process all 36, but only ends up with
about 12. At least it seems that way to me. Does anyone see a full orbit?
Download 'Orbit.mpg' (80 KB)
Subject: Re: Problem?
Date: 7 Sep 2000 18:47:54
Message: <chrishuff-F72C57.17494007092000@news.povray.org>
In article <39b816a0@news.povray.org>, "Bill DeWitt"
> of the frames in this animation. It seems to process all 36, but only
> ends up with about 12. At least it seems that way to me. Does anyone
> see a full orbit?
With QuickTime Player and QuickTime 4.0, I see a full orbit with 36
frames.
Christopher James Huff
Date: 7 Sep 2000 19:49:32
Message: <39B82992.580EEF36@yahoo.com>
with win media player i don't see full rotation.
>    Orbit.mpg    Type: MPLAYER2 File (video/mpeg)
>             Encoding: x-uuencode
Date: 7 Sep 2000 21:05:47
Message: <39b83b6b@news.povray.org>
I've run into this problem a few times and I've seen it happen to a couple
other people.  Most likely the encoding bitrate is too high; the only thing
that's moving is the orbitter. I'd say use half the bitrate and see if you
see the same thing. It may work, but if it still fails use half of that, or
if it gets crappy go halfway back up. It's all trial and error.
"Bill DeWitt" <the### [at] earthlinknet> wrote in message
news:39b816a0@news.povray.org...
the
with
Date: 7 Sep 2000 22:27:51
Message: <39b84ea7@news.povray.org>
> frames.
    Hmmm... I've tried 4 players with no better success. I will see where my
QT is and try it. But I can't figure out why it stopped working. I did half
a dozen tests that worked and then changed the turbulence on the glow and it
stopped working...
    Maybe this is one of those hypothetical Windoze problems.
Date: 8 Sep 2000 05:29:01
Message: <39b8b15d@news.povray.org>
the
with
nope, just the same half you do
Date: 8 Sep 2000 08:22:45
Message: <39b8da15@news.povray.org>
"Jetlag" <bga### [at] microsoftcom> wrote in message
news:39b83b6b@news.povray.org...
    This seem to be a solution. By forcibly lowering the bitrate to 400/sec
I got to see the whole thing. But this is unacceptable. I have dozens of
mpgs made with Videomach that didn't have this problem.
    What bothers me is that the information seems to be in the file. I was
not able to find a way in QT to actually run a mpg, but if Chris got it to
play the whole thing, that means that it is the playing of the file that
fails, not the creation.
Download 'Orbit.mpg' (61 KB)
Date: 8 Sep 2000 08:59:22
Message: <chrishuff-0EC184.08005308092000@news.povray.org>
In article <39b8da15@news.povray.org>, "Bill DeWitt"
> was not able to find a way in QT to actually run a mpg, but if Chris
> got it to play the whole thing, that means that it is the playing of
> the file that fails, not the creation.
Or simply that QuickTime is more tolerant of errors in the file than
other software.
Date: 8 Sep 2000 09:30:38
Message: <39b8e9fe@news.povray.org>
    I think it is the second half of this statement that is the crux. I mad
a few more objects and it seems to work much better without dropping the
bitrate.
Date: 8 Sep 2000 11:43:44
Message: <39B90931.EE2F877B@spiritone.com>
With two different versions of windows media player I don't see the full
rotation.
Fer some reason QT4 doesn't want to open mpgs on my machine.... damn and blast.
Josh
>    Orbit.mpg    Type: WMPLAYER File (video/mpg)
eng### [at] spiritonecom
Date: 8 Sep 2000 11:47:37
Message: <39B95F61.78A0DD97@home.nl>
I see a full orbit with mtv.
Remco
Date: 8 Sep 2000 12:57:14
Message: <39b91a6a@news.povray.org>
    I want my mtv.
Date: 8 Sep 2000 22:24:29
Message: <39b99f5d@news.povray.org>
mad
> bitrate.
That is because more movement creates more for the MPEG to encode, so the
buffer does not underrun. When I first started encoding I thought that a
352x240 sized animation should get about 1.8 Mbits/s and then say 176x120
might need about 450kbits/s, and so on, and I could derive the needed
bitrate like that, but what I found is those numbers only work for
full-motion or very-near-full-motion. When I had an animation with very
little motion I needed to drop the bitrate a lot to keep from screwing it up
and making an unplayable file. Sometimes when it only screws up a little I
notice the play timer is WAY off, when it gets a lot of underruns Media
Player just chops it up. I won't say its Media Player's fault because I'm
pretty sure the MPEG's are going out of spec, but I also don't think its the
encoder's fault because it's just encoding with the parameters given (but it
should tell you that's its blown the buffer, and that it might not play
right).
I'm sure there's others around here that could explain this better because
I'm far from knowing what I'm talking about. But like I said before, finding
the right bitrate seems to be trial and error. I wish I could find some
program that I could run my animation through first, and it would return the
best bitrate, the sweet-spot so to speak, but I have yet to find it.
Enough of me blabbering, if you've encoded something, and now you find out
that it doesn't play right AND you've deleted the originals, you can get all
the unplayable data back by pushing it through VirtualDub. The program is a
free AVI mutilator, and there's lots of good stuff I could say about but
just go to http://www.geocities.com/virtualdub and see for yourself.  The
source is there too (one day I plan on shoving mpeg2encode into it, but
since I patched* MP+ to output MPEGs I don't need it that urgently anymore).
*I don't really plan to release though, it seems all I got was negative
feedback when I asked about it before.
Jeff
Date: 8 Sep 2000 22:58:08
Message: <39b9a740@news.povray.org>
    I didn't read that conversation, but I have been playing with VirtualDub
and so far I like it. What is your patch?
Date: 9 Sep 2000 02:30:30
Message: <39b9d906@news.povray.org>
VirtualDub
A while back I patched mpeg-1 output in pov, and I threw a post into
povray.animations questioning whether anyone would want such a thing.  The
general consensus was that no one would want it, and to be truthful there
are many drawbacks to such a thing. I keep an updated version of it for
myself whenever something new comes up, because I've found myself using it
regularly.  The reason I didn't just upload it somewhere is because it was a
very sloppy implementation, memory leaks everywhere, it crashes on
pov-script errors, and other crazy stuff. I was going to rewrite it if
people seemed interested.  Someday I may add raw AVI output, which would
prove more useful than mpeg-1, for most windows users anyway. It wouldn't be
able to write codecs of course, but no one would want that anyway, for the
same reasons no one would want mpeg-1. But it's a long way from happening.
After school and work its either coding or sleeping, and sleep wins most of
the time.
Date: 9 Sep 2000 05:33:56
Message: <MPG.142421ccea37f1a1989692@news.povray.org>
Bill DeWitt says...
Same here with Windows Media Player, but MainActor's Player shows it all.
MainActor's Video Editor reads your mpg just fine and re-saves it as an
mpg of about double size (176 kB) that plays OK on WMP... Funny that all
the information IS there but doesn't show. Some misplaced 'end of file'
sign?
Did you try CMPEG?
Regards,  Sander
