I applied the proximity texture to a box as my blob man walked through
it. Not quite as cool as I expected....
Render time: 43 hours. If I ever did this again, I would use a
combination of object and pigment patterns, as this is apparently only
showing proximity to a SURFACE of the object: I expected a "0" value for
all spaces inside the object....
Download 'proximity05.mpg' (430 KB)
Looks good, though. Like he's walking through a heat sensor.
> proximity05.mpg Type: WMPLAYER File (video/mpeg)
> Encoding: base64
eng### [at] spiritone com
In article <39b80e5c@news.povray.org>, "Greg M. Johnson"
You didn't read the documentation. :-)
sides INT_SIDE
Use this keyword to decide which sides of the object to calculate the
pattern on.
0 Only the points inside the object are calculated.
1 Only the points outside the object are calculated.
2 All points are calculated.
I'm not surprised at the speed, though...didn't you try the blob pattern?
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
READY-BREK !!!
If this were a compliment or a teasing pun, it went over my head...
"Rick [Kitty5]" wrote:
> READY-BREK !!!
> Rick
> sides INT_SIDE
> pattern on.
So how do I make it the regular kind of gradient for points outside the
surface, but 0 everywhere inside? I don't remember what I used and don't see
an answer in what you copied. I'm thinking I have to do this with a map first
on the object pattern...
My blob guy has about 200 components and my walking INC is so complicated that
I often forget how to use it if I let it sit for a week. I don't want to try
to import it into another pigment with its own complicated syntax. I started
out trying to get a kind of shroud of turin effect with the face because it is
so detailed.
I was reminded of the shape of an Football player, and this comment
reminds me of a Football huddle... (That's American Football, BTW)
Josh
> > READY-BREK !!!
> > Rick
Hi Greg. Ready-Brek is a nice sort of porridgy, (oats), breakfast, (just
add hot milk)! But the advert that goes with it on UK TV, features a young
lad and his sister, IIRC, that go to school on a cold morning, with a nice
warm *glow* around them after having their READY-BREK. It does remind me of
that also :o)
Nice ani, btw. ~Steve~
"Greg M. Johnson" <gre### [at] my-dejanews com> wrote in message
news:39B8D7C4.E782A159@my-dejanews.com...
> > READY-BREK !!!
> > Rick
On Fri, 8 Sep 2000 20:16:57 +0100, 25ct wrote...
> that also :o)
Oh, and it might be a UK only reference :)
But I like the pseudo false colour thermograph effect.
Bye for now,
Jamie.
In article <39B8D992.C5E1300B@my-dejanews.com>,
> the surface, but 0 everywhere inside? I don't remember what I used
> and don't see an answer in what you copied. I'm thinking I have to
> do this with a map first on the object pattern...
Just add "sides 1" in the proximity pattern block. The object pattern is
not necessary, and would be a waste of time(both coding and rendering),
since the same calculations are already done in the proximity pattern.
> > pattern?
> complicated that I often forget how to use it if I let it sit for a
> week. I don't want to try to import it into another pigment with its
> own complicated syntax. I started out trying to get a kind of
> shroud of turin effect with the face because it is so detailed.
You don't have to rewrite anything...you do know that with MegaPOVPlus,
you can use blob objects to control the blob pattern, don't you?
Of course, in MegaPOVPlus, you would *have* to use the blob pattern,
since the proximity pattern isn't in working order right now...
"Josh English" <eng### [at] spiritone com> wrote in message
news:39B811D7.1C7E2EB8@spiritone.com...
Reminds me of MRI (magnetic resonance imagery) except that it's reaching way
beyond the boundary of the actual guy. Really cool effect.
I think it would look cooler if the person were incorporated into the scene,
walking through the proximity box.
You see a black 'doorway', perhaps with a techie frame. Slowly the blue
appears, and colours increase. Suddenly a hand reaches through the door,
surrounded by the coloured halo. The rest of the body follows, and when it's
through, the door fades back to black.
I like it!
Simon
I was thinking of some kind of techie frame to catch an invisible man, or
somehow turning this into a way to make someone melt or through a doorway, if
this were set up as a heightfield as the visible character actually walked
though. As I said I originally thought i could make a shroud of Turin with the
details from the face...
> I like it!
> Simon
