POV-Ray : Newsgroups : povray.binaries.animations : Animated HF Server Time
13 Oct 2026 08:59:07 EDT (-0400)
  Animated HF (Message 1 to 7 of 7)
Subject: Animated HF
Date: 26 Apr 1999 09:04:33
Message: <37245651.0@news.povray.org>
I'm writing a macro to create animated oceans, so I post this very first
animation (I know the texture is not good for ocean, but very good to debug
and anyway the macro will not provide the texture!)
Comments, advices and criticisms warmly welcome
Philippe
PS : run it in a loop
Download 'wave.m1v.mpg' (620 KB)
Subject: Re: Animated HF
Date: 27 Apr 1999 11:11:38
Message: <3725C619.E753ABC6@inapg.inra.fr>
Wew, this looks very promising.
After that sorry "FIRST POVRAY OCEAN" business I was planning to have a try
myself, since the maths may be less complicated than I thought (see
http://www.imagewks.com/imageworks/docs/research/research_nate2.html).
I was wondering what was the best way to proceed :
- creation of textures to be used as height fields
- mesh generation
- isosurface (with a parameteric definition of the waves) in the Superpatch.
I tried the last two approaches and I went as far as creating a wave macro that
makes a simple wavy surface mesh but I stopped there. The problems I have to
solve are 1) the mesh /isosurface size and parsing and 2) how to introduce
randomness in the waves. If you want the source it's available.
Gille Tran
> Philippe
>    wave.m1v    Type: Vmpegwin File (video/mpeg)
>            Encoding: x-uuencode
Date: 27 Apr 1999 15:53:40
Message: <372607b4.0@news.povray.org>
>- mesh generation
Superpatch.
that
to
The solution I'm currently investigating is :
1) I start with a still image (multifractal or fractionnal Brownian motion)
and then
2) I add 2 sine waves of different Ampitude, Frequency and Direction and
then
3) I add a Three (x, y (or z) and time) dimensionnal correlated noise (don't
know yet what will be the final form)
The sample I've posted is made of Part 2 only (the smoothest ocean possible
The code for part one is written and working (!!!?)
The final idea for part three is in my head I just have to squeezzzzzz my
brains to take it out !
Of course I'm interested in your Code, I hope I will come with an idea for
your point 2, because it is my current concern
Philippe
Gilles : J'adore ton site (J'aime aussi Dali, Magritte et Tanguy, ce n'est
donc pas une surprise)
Date: 28 Apr 1999 01:56:01
Message: <372694F1.53E4F7B5@Kopp.com>
> - mesh generation
The problem with these two techniques is that they are both finite.
With the mesh, you could potentially use a higher resolution mesh near
the camera that fades out to a very low resolution towards the horizon.
I think you could probably make an infinite (or at lease very big) ocean
surface which doesn't repeat using this technique.
I'd love to see it.  :-)
-Nathan
Date: 6 May 1999 12:19:27
Message: <3731B3CD.D37E1F61@xs4all.nl>
> >- mesh generation
> Superpatch.
> that
> to
> and then
> then
> Philippe
I don't know how much this differs from the approaches mentioned here, but I've
also seen a sea/ocean-surface with heightfields generated with an algorithm
similar to the famous fire-algorithm you'll find all over the demo-scene. The
effect is actually quite nice.
While I'm at it: it's not really a topic in this thread but the idea of making
the most realistic ocean is a bit pointless because the ocean (sea) will look
different all over the world. If you compare the Mediterranean to the Northsea
for instance, one is clear-blue the other muddy-greyish (which apparently means
the water is cleaner...)
Remco
PS if you like I can dig up an example of the animated seasurface I mentioned.
Date: 6 May 1999 13:41:55
Message: <3731c653.0@news.povray.org>
making
look
Northsea
means
I'm interested in the movement, not the "material", as you've seen on my
sample, and, anyway I'm not running after photo-realism but after
credible-realism where the ocean can only be part of a scene.
mentioned.
I'd love too, thanks a lot
Philippe
Date: 6 May 1999 23:47:39
Message: <3732492E.D0A050F3@xs4all.nl>
> making
> look
> Northsea
> means
That's why I said this was "off-thread"...
> mentioned.
> Philippe
Here it is...
I'm sorry but I had to ZIP the file.
I had to shrink it to a miniature and even then I was afraid it'd be too large.
You can view it at double the size, it won't matter much. It's also supposed to
be a loop.
Remco
Download 'zee.zip' (612 KB)
