POV-Ray : Newsgroups : povray.binaries.animations : first Fabrik IK animation : Re: first Fabrik IK animation Server Time
23 Mar 2026 19:34:51 EDT (-0400)
Date: 12 Dec 2018 01:49:35
Message: <XnsA9B64F9DC40DAseed7@news.povray.org>
in news:web.5c102131fed5bd3748892b50@news.povray.org jr wrote:
> and yet, accomplished.  looks quite impressive already.  Q - how do
> you keep state between frames?  is the animation using the fabrik.inc
> macros (only)?
Fabrik is only initilised once and 'returns' its own resulting
datastructure that I use for the new target. Scene below, if you run it
with the .inc in p.b.scene-files you'll get a better result than in this
clip as some speed up optimalisations are turned off. Still a few little
jumps left then.
ingo
//Pov-Ray   : 3.8
//Scene File: FABRIK.inc
//Author    : Ingo Janssen
//Date      : 11-12-2018
// +a0.1 +KFF300 -KC +W640 +H480
#version 3.8;
#include "FABRIK.inc"
#global_settings{assumed_gamma 1.0 }
#default{pigment{rgb 1} finish{ ambient 0.2 diffuse 0.9 }}
light_source{<1000,1000,-1000>, rgb 1}
plane{y,0 pigment{checker rgb 0.05 rgb 0.1}}
camera{location <0,4.5,-12> look_at <0,4.5,0>}
plane{z,0 pigment{checker rgb 0.05 rgb 0.1}}
#declare F = dictionary{
  ["Index"] : dictionary{
    ["Chains"] : array[5]{"Base", "Left", "Right", "Right1", "Right2"},
    ["SubBases"]: array[2]{"LRB", "RRR"}
  ["Proc"] : array[7]{"Right1", "Right2", "RRR", "Right", "Left",
"LRB" ,"Base"},
  ["Base"] : dictionary{
      ["Joint"]  : array[5]{<0,0,0>, <0,1,0>, <0,2,0>,<0,3,0>, <0,4,0>},
      ["Type"]   : "BaseSubbase",
      ["SubBase"]: array mixed[1]{"LRB"}
  ["Left"] : dictionary{
      ["Joint"]  : array[4]{<0,4,0>, <-1,5,0>, <-2,6,0>,<-3,7,0>},
      ["Type"]   : "SubbaseEnd",
  ["Right"]: dictionary{
      ["Joint"]  : array[4]{<0,4,0>, <1,5,0>, <2,6,0>,<3,7,0>},
      ["Type"]   : "SubbaseSubbase",
      ["SubBase"]: array mixed[2]{"RRR", "LRB"}
  ["Right1"]: dictionary{
      ["Joint"]  : array[3]{<3,7,0>, <4,8,0>, <5,9,0>},
      ["SubBase"]: array mixed[1]{"RRR"}
  ["Right2"]: dictionary{
      ["Joint"]  : array[3]{<3,7,0>, <2,8,0>, <1,9,0>},
  ["LRB"]  : dictionary{
      ["Index"]   : array[3]{"Left", "Right", "Base"}
      ["Type"]    : "SubBase",
      ["Centroid"]: <0,0,0>
  ["RRR"]  : dictionary{
      ["Index"]   : array[3]{"Right1", "Right2", "Right"}
#declare S = FABRIK(F);
#declare SL = spline{
  natural_spline
  0   , <-3,7,0>,
  0.25, <-1,3,0>,
  0.5 , <-3,1,0>,
  0.75, <-4,3,0>,
  1   , <-3,7,0>
#declare T = dictionary {
  ["Index"] : array[3]{"Left", "Right1", "Right2"},
  ["Right1"]: array mixed[1]{<5,9-6.5*clock , 0>}, //<5,9,0>
  ["Right2"]: array mixed[1]{<1,9-5.7*clock, 0>}, //<1,9,0>
  ["Left"]  : array mixed[1]{SL(clock)}, //<-3,7,0>
SetTarget(S, T)
PillMan(S)
