POV-Ray : Newsgroups : povray.beta-test : splines - documentation and reality Server Time
13 Oct 2026 19:31:58 EDT (-0400)
  splines - documentation and reality (Message 1 to 4 of 4)
Subject: splines - documentation and reality
Date: 10 Jan 2002 03:12:42
Message: <m7fq3u41ctia9e6i3tbnlstn6ek739vpke@4ax.com>
POV 3.5 b 9.icl on PII 233 128 MB with NT 4 Sp 6
documentation says about spline specification
#declare IDENTIFIER =spline { [SPLINE_IDENTIFIER]  [SPLINE_TYPE] ...
So identifier and type are both optional but can be together.
I checked that when spline S1 is declared and I declare spline S2 as "child" of
S1 but with different type then type declaration is parsed ok but do nothing.
But is is parsed ok so I don't know what is wrong parser, documentation or
engine. Conversion is definetly possible becouse when I force type in spline
calculation instead of definition then it is changed ok.
Below is test scene. Working with it I noticed another bug. I can't pass spline
calculation as macro parameter. To check it uncomment debug line. Works fine
when there is parenthesis around spline in call of VStr().
Playing with it I found also small feature request. I'll send it to p.general.
#version 3.5;
#include "stdinc"
global_settings {
  assumed_gamma 1.0
  location <0,.5,-4>
  direction 1.5*z
  look_at 0
light_source {30*<-1,1,-1> color rgb 1}
background{1}
#declare Points=10;
#declare Radius=.1;
#declare Step=.1;
#macro Force()
  #if(force_cubic)
    ,cubic_spline
#macro Draw(Spline,T,force_cubic) // let's draw spline
  union{
    #local c=1;
    #while (c<=(Points-Step))
//      #debug concat(Str(c)," - ",VStr(Spline(c)),"\n")
      sphere{Spline(c Force()) Radius}
      cylinder{Spline(c Force()),Spline(c+Step Force()),Radius}
      #local c=c+Step;
    sphere{Spline(Points Force()) Radius}
    pigment{color rgb 1}
    scale .2
    translate T*<.7,.5,1>
#macro List() // makes list of points for spline
  #local G=seed(0);
  #local c=1;
  #while (c<=Points)
    c,2*<rand(G),rand(G),rand(G)>-1
    #local c=c+1;
#local S1=spline{linear_spline List()}     // works as expected
#local S2=spline{cubic_spline  List()}     // works as expected
#local S1a=spline{S1 cubic_spline  List()} // type do nothing
#local S2a=spline{S2 linear_spline List()} // type do nothing
#local S1b=spline{S1 cubic_spline }        // type do nothing
#local S2b=spline{S2 linear_spline}        // type do nothing
#local S1c=spline{S1 3,2*y}                // works as expected
#local S2c=spline{S2 3,2*y}                // works as expected
Draw( S1  ,-2*x+y , no )
Draw( S2  ,-2*x-y , no )
Draw( S1a ,  -x+y , no )
Draw( S2a ,  -x-y , no )
Draw( S1b ,   0+y , no )
Draw( S2b ,   0-y , no )
Draw( S1c ,   x+y , no )
Draw( S2c ,   x-y , no )
Draw( S1c , 2*x+y , yes)
Draw( S2c , 2*x-y , yes)
// ABX
Subject: Re: splines - documentation and reality
Date: 10 Jan 2002 05:25:34
Message: <bqqq3ukvqrhpig97ndfi1du3k3k60lf9c5@4ax.com>
On Thu, 10 Jan 2002 09:12:14 +0100, W�odzimierz ABX Skiba <abx### [at] babilonorg>
also please note documentation not precise (in 6.1.9)
how parser behaves in above situation.
ABX
Date: 10 Jan 2002 07:55:51
Message: <Xns91928DF07F1C6seed7@povray.org>
in news:m7fq3u41ctia9e6i3tbnlstn6ek739vpke@4ax.com W³odzimierz ABX Skiba
The way I interpreted the changing of the spline type is that is is only
possible when you retreive one value from the spline.
#declare P1=<0,0,0>+Spline(1,linear_spline);
Not for copying a spline. I agree that in that case the syntax section
is not clear, is adding a pipe enough:
  spline {
    [SPLINE_IDENTIFIER] |
    [SPLINE_TYPE]
Then again, the current spline implementation is marked experimental and
has several bugs, so I'm not sure how it should/will work and what to
change in the docs. I'll put your remark in the todo list and wait for a
more final spline before changing the docs.
Ingo
Date: 12 Jan 2002 00:13:16
Message: <3c3fc5ec@news.povray.org>
W³odzimierz ABX Skiba wrote in message ...
"child" of
nothing.
spline
This should work, and doesn't.  For those of you who are working on the
official source code, the fix is the following changes to Parse_Spline in
express.cpp:
Replace
   EXPECT/*Check for spline identifier*/
     CASE(SPLINE_ID_TOKEN)
       New = Copy_Spline((SPLINE *)Token.Data);
       i = New->Number_Of_Entries;
       EXIT
     END_CASE
     OTHERWISE
       UNGET
       EXIT
     END_CASE
   END_EXPECT
with
       Type = New->Type;
       EXIT
     END_CASE
     OTHERWISE
       UNGET
       EXIT
     END_CASE
   END_EXPECT
and add
   New->Type = Type;
just before the line
return New;
fine
This is a known problem.  I'm fairly sure it is officially classified as a
"feature", and putting parentheses around the spline is the recommended
work-around.
Mark
